My new Liteon DVD iHAP122-9 is set as master over an CDRW which is set as slave. My DVD will not format or do anything except play cd and DVD's.
    Problem Solver:
  • 8 Answers
All u need to do is to reaccess the data ribbon........
jus open ur cabinet n have a look at the ribbon........
if its a thick n small ribbon then its a SATA n if its a thin but flat ribbon then its a ID3 ......... in a id3 ..... one end is in the motherboard so the 1 connected to other end is set as master while the one in the centre is the slave........
in SATA for for port no. near the socket in the board....... arrange ur slave in the port of which the no. is more than that of the master....... for eg. if master is in port 3 then slave will be in port 4 or 5
Posted on Sep 27, 2009
  • 63 Answers
Well your cdrw shouldn't be set as slave at all.
How to set NEC NR 7800A as the master
the First thing you need to do is make sure the jumpers on the back of the drives are set ,one to slave and one to master. there will be a mark either on the case by the jumpers or on a label on the drive. On systems I build
I set the top one to master and bottom one to slave. It makes it easier to hook up the cable to them. The end of the cable goes to the top one and
the other one to the slave.
May 15, 2010 | NEC NR 7800A CD-RW Burner
LG cdrw ced 8080b slave position
if the cd was set to secondery or slave on your motherboard usually it follows the hard drive on the tape or ribbon if you want to keep the cd as a master you will have to install a new ribbon and connect it to the secondary on the motherboard, motherboards have a primary where you can connect a harddrive and cd and then a secondery and do the same as long as you designate master and slave for each drive so as not to confuse the system later ones also have another option sata which gives you more options
Aug 22, 2009 | Computers & Internet
My motherboard can't read any bootable dvd
you have to check
1) new DVD master/slave setting, it should be set to slave cause your old one set master
2) go bios setting check IDE device should display the DVD device at slave position.
3) start windows it should be there
Dec 15, 2008 | AOpen Computers & Internet
G4 350 mhz agp powermac
Can you try installing the new burner as a slave and the zip as the master?
Had a pc once that refused to boot at all with a new DVD burner in it, alongside a DVD-ROM. The burner was replacing a CDRW drive, swapped the drives master and slave settings over and it worked.
Oct 15, 2008 | Apple Power Mac G5 Desktop
Cdrw
In the past it was recommend that the burner be the secondary master. Do to problems like you mentioned. Try making the DVD the slave and the burner the master. Be sure that when you boot up that in the posting that it see the drives right. If the CMOS/ BIOS is set for fast boot you can press the ese or tab to see the post without changing the CMOS/BIOS on most models.
Apr 01, 2008 | Computers & Internet
My LH20A1p186c Lite on dvd writer will not do anything. A simple swap into my comp with 3 cables and the comp. does not recognize the new hardware. In fact both dvd and old cd player appear tp be one...
Check the Master Slave jumper on the back of the drives. If using 2 drives on 1 cable, make sure one is set to master and the other is set to slave. The jumper positions usually are labeled on the top of the drive as "M" and "S"
If you have them set to the same, both drives won't work.
If the drive is sharing cable with a hard drive, try changing the M/S setting.
Mar 31, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
Liteon DVD writer & re writer
You can not use cable select without the correct cable. Most "stock" cables are not. So...
An IDE port supports -2- drives (CD, HD, DVD, Etc). If you have 2 drive connected on the ribbon cable then one must be set to master and the other to slave (the little jumper clips on the back). If it's the only drive on that cable, set it to master. Some drive may say Master Only and Master with a slave.
Geno
Feb 16, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
Setup Problem
Is the Master/Slave jumper set correctly on the back of the drive?
If the drive is on a cable with another drive of any type, one must be master and the other slave.
Also, double check that the ribbon cable is plugged in correctly.
Geno
Jan 24, 2008 | Lite On LiteOn 16x Black internal oem DVD...
Jumper
Does the cord going to your CD-RW hasve asnothe plug further down the line most computers can connect 2 cd type drives!!!
Jan 02, 2008 | Pioneer (dvr-a06u) DVD±RW Burner
Computers & Internet Logo
136 people viewed this question
David Payne
David Payne
