Question about Logitech Z-340 Computer Speakers
Pinouts for Logitech z340
Guido, did you ever figure out the pinouts?
How do I determine the battery pinouts for my Dell Inspiron 1526
the pin outs for the batteries in general are:
1 +Batt - Battery output voltage
2 SMB_SDA - System management Bus Serial data
3 SMB_SCL- system managemant bus Serial Clock
4 Batt_temp - Battery temperature monitor
5 battery_present or Battery ID
6 GND - ground
the SMB_SDA & SMB_SCL are used by IO controller chip in mainboard to communicate with the battery( battery type , charge level), and you can not use other model laptop batteries because it will not match with the bios whitelisted battery type.
no way you can fake the battery, instead you can flash the bios by modifying the flashing programs config.ini file so that it ignores the battery
Jun 24, 2014 | Dell Inspiron Computers & Internet
I need the pinouts for a nintendo wii headset (usb pinouts)
The USB interface is standardized. Knowing the pinouts isn't useful for creating your own headset, but here are the pinouts anyway:
http://pinouts.ru/Slots/usb_pinout.shtml
Feb 03, 2013 | Nintendo Wii Console
Connecting usb
Usually red white green and black unless the motherboard has a cable connect lead already
The USB Pinout:
Pin
Name
Cable color
Description
VCC
Red
+5 VDC
D-
White
Data -
D+
Green
Data +
GND
Black
Ground
http://pinouts.ru/SerialPortsCables/usb_cable_pinout.shtml
http://pinouts.ru/Slots/USB_pinout.shtml
http://pinouts.ru/connector/4_pin_USB_A__USB_B__mini-USB_jack_connector.shtml
hope some of these will help you
Feb 24, 2012 | Foxconn 6100K8MA-RS Motherboard
Pinouts power supply for hp d530 ultraslim
Hi lantzgema,
I looked up the specs of your d530 and all I could find out is that you have a 150 power supply, calling HP technical support was no help at all.
I did find some pinouts you can look at and determine which one exactly you have. Hope this help out.
http://pcsupport.about.com/od/insidethepc/a/atx-pinout-24-pin-12v-psu.htm
http://pcsupport.about.com/od/insidethepc/a/sata-pinout-15-pin-psu.htm
http://pcsupport.about.com/od/insidethepc/a/molex-pinout-4-pin-psu.htm
http://pcsupport.about.com/od/insidethepc/a/atx-pinout-4-pin-12v-psu.htm
If this is still not what you have there are other pinouts at the same website.
Dec 28, 2010 | Computers & Internet
What is the pin layout for the rs232 connector on the F5U409v1 adapter from belkin.
The pinouts are in numerical order
1 2 3 4 5
6 7 8 9
Pin signals:
1.Data Carrier detect
2.Rx
3.Tx
4.Data Terminal Ready
5.Signal Ground
6.Data Set Ready
7.Request to Send
8.Clear to Send
9.Ring Indicator
Dec 20, 2010 | Computers & Internet
X-220 cable is slightly damaged and not making constant contact with sub-woofer mate. Is there a repair where I can replace or cut open & fix the 9 pin cable? To me, the obvious problem is that the...
nothing is wrong with the woofer the connect is broken at the strain relief and the cable needs to be replaced.
You can replace the connector if you know the pinouts. You will need the connector and the schematic.
you may be able to find the pin outs configuration here.
http://pinouts.ru/
As for the connector this may take a search online.
Aug 07, 2010 | Logitech X-220 Computer Speakers
VGA connector on a Dell e770s 17 inch monitor has been cut. Need to know where the wires go on a 15 pin db connector?? Can anyone help...Thanks gvp
Found out the information thru this page. Its a diagram of the 15 pin VGA Pinout and where the pins are supposed to go and what there fuctions are, hope this helps. Page is courtesy of pinouts.ru
http://pinouts.ru/Video/VGA15_pinout.shtml
Aug 29, 2009 | Computers & Internet
JFP1 Pinouts for Acer Veriton 5600g Motherboard
Here is a common pinout, yours may be different....
Mar 19, 2008 | Intel Motherboard
Logitech Z-340 Computer Speakers Logo
490 people viewed this question
Top Logitech Audio Players & Recorders Experts
gunzmith
Level 1 Expert
Henry  Thomas
Henry Thomas
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
