Question about Garden
How do you attach a Mower Deck to a John Deer LT 155 Tractor I can not line up the rear deck with the pins, spring, washer, and cotter pin. Tme manuel said to install right side first. This is a s8 inch deck
  • 472 Answers
HOOK THE BACK UP AND THEN THE FRONT
Posted on Sep 30, 2009
How do I drop the lawn cutting attachment from under the tractor for inspection and lubrication?
It' pretty easy to do once the pins are removed. Make sure cutting deck is flat on the ground, on a piece of plywood. Once disconnected, raise mower deck height adjustment handle to highest position, and slide deck out from under tractor. If it's a wreck, try SearsParts online... I got a whole new deck for my LOYTH20F42T for about 125.00 delivered.
Oct 23, 2014 | Husqvarna Garden
John deere 855-70 manual
On ALL Deere riding lawn mowers, 1st, position the deck under the tractor. Depending on the belt drive: either PTO (the yellow button on the dash panel), or tension engaged-(a lever on the right side of the operator\'s seat), you loop the drive belt from the front of the deck to the pulley, always in the lower front area of the tractor\'s engine. If it has "beltguards" too close to the pulley, you must loosen the retaining bolt for the guard, it will allow the belt to squeeze by and onto the pulley. Then, 2nd but don\'t forget to retighten after slipping the belt on, push the "Deck heighth" lever fwd to drop the deck "hangars" at the rear of the deck into position to "pin" the eyelets with the supplied pins, washers and keepers: usually a cotter pin or a lynchpin that inserts thru a hole on the smooth bolt-pin. The easy part\'s over, but don\'t panic. 3rd, lift the front of the deck onto a block, allowing a heighth to apply the "adjusting rod" into the front of the mower chassis. Screw the retaining nut onto the threaded (long bolt) and remove the block. You\'re done. Next, and very important, RAISE & LOWER the deck, engage the belt tension, (here you may have to clear the area and start the engine to engage the PTO drive, if it\'s electronically controlled belt-drive), this assures nothing is "misaligned" or improperly positioned. Now, if the machine is on a flat surface, lower the deck to a point just above the ground and measure the distance in four (4) corners of the deck and record the ht. Make the adjustments to LEVEL the deck. Now you\'re ready to start the engine from the operator\'s seat, slightly increase the engine from idle to 1/4 throttle speed so that engaging the drive belt won\'t kill the engine. Ensure the belts run smoothly, the blades turn, and the engine doesn\'t "bog". Lower the deck to a desired cutting ht., now MOW the grass!
Jan 28, 2014 | Garden
2000 craftman lawn tractor 917.270822 blades will not engage
If your blades won't engage when you raise the lever to engage them AND that lever moves freely without the normally expected resistance, then you've lost the cotter pin that connects the lever rod to the mower deck assembly. Very easy fix! Using the mower deck raise/lower lever, lower the mower deck to "down" position. Now, lay on your side along the right side of the mower and look up (use a flashlight) under the mower at the top of the mower deck while moving the blade engagement lever "up" (which pushes the connected rod down). At the end of the rod, you will see a hole where the mower deck and rod connect. Align the hole at the end of the rod with the matching "pin" on the mower deck (you'll see it) and insert a new cotter pin to secure them together. Use a nail if you don't have a cotter pin. Voila! you are done. The blade engagement lever will now engage/disengage your mower blades successfully. Just remember that mower deck must be down, or lowered, before you engage the blades!
Jun 22, 2012 | Garden
I have an Allis -Chalmers 416 tractor with mower deck I need to know how to install the deck (I have lost the manual) It is an older model serial number 26002395 Can you help
There are 2 holes at the front on the frame you need to put a pin and cotter pin through each side to hold the front of the mower. Then there will be a hangin piece of straight metal about 2-3 inches long with a hole in it that you need to hook up the chain to also with a pin with a hole in it and a cotter pin. This will allow you to raise and lower the deck with the electric lift. If you need pics let me know i'd be happy to help.That's all there is to it besides putting the belt on.
Jan 21, 2011 | RTO Allis Chalmers Tractor 7010, 7020,...
I have john deer sabre 18 horse i have a snow blade but cant get on right
My name is Dane and I'll try to help you with your problem. I have given you the basic instructions here for mounting most john deere snow blades.
Here is a link to the parts diagram for the blade too.
http://www.searspartsdirect.com/partsdirect/part-model/Sabre-john-deere-Parts/Riding-mower-tractor-Parts/Model-15538G/1828/1509200/10060752/00034
You need to remove the mower deck from the machine, and you may have to remove the front bumper as well.
First, install the mounting brackets on the tractor. Align the holes in each mounting bracket with the holes in the tractor frame. Install using the kit that comes with the mounting bracket. Don't tighten this yet.
Next you should install the pivot support. Insert the pins on the right and left hitch plates into the notches on the mounting brackets. Install the pins and tighten the screws on those mounting brackets now.
Next you should Install the blade. Align the holes in the pivot support with the second holes from the end of the push channel assembly. Insert the channel pin and washer and secure with the spring locking pin.
Install the lift handle. Slide the lift handle rod into the end hole in the push channel assembly. Insert the lift link pin in the pivot support bracket into the lift handle rod. Add the washers and locking pin.
Now, Iistall the blade pivot rod. Either end of the blade pivot rod goes through the blade pivot shaft. The other end goes through the lift handle tube. Secure both ends with locking pins.
Lubricate the lift handle rods and pivot points.
Install the rear tire chains and wheel weights.
I hope I've helped. If you found this information useful, please leave feedback as deserved. Thanks! Dane
Dec 03, 2010 | John Deere Garden
Mower deck clutch cable removal (model 917.28722). Detail provided in manual does not seem to match product. Need to remove this in order to remove deck and replace belt. Belt has squealed since new.
You should not need to remove the deck or the clutch cable just to change the belt.
  • ensure mower clutch lever is in the off position
  • lift the front of the tractor approx 24 or more inches.
  • lower the mower deck as far as it will go
  • locate & remove the cotter pin from the right (discharge) side mower lift arm where it attaches to the rear of the mower
  • release the lift arm from the mower deck to allow it to drop (it will hang from the other 3 points)
You should now have plenty of clearance to change the belt. Remove the belt from the engine pulley first and replace the new belt on the engine pulley last that will make it easier to change the belt.
If this is helpful please vote yes, Thank You!!
Aug 28, 2010 | Craftsman 42 in. Precision Cut Plus 24hp...
The belt dry rotted and flew off without me being able to remove it myself, now I need to know how to install the new drive belt.
To install the drive belt you will have to remove the drive belt first.
Follow the procedure: ---
Park the tractor on a level surface. Set the parking brake and remove the key from the ignition. Study the belt replacement guide decal located underneath the left foot board for proper belt routing instructions.
Remove the mowing deck by first moving the attachment clutch lever to the disengaged position (toward you). Move the attachment lift lever all the way forward to lower the mower housing to its down position.
Crawl beneath the tractor and roll the drive belt off engine pulley (it hangs directly beneath the engine). Remove small retainer clip that holds the clutch spring to the pulley bolt located at the center of the mowing deck. Remove the large retainer springs (two of them), then slide the belt collar away from the mower housing and off the housing bracket.
Disconnect the anti-sway bar rods from the chassis brackets by removing the retaining cotter pins. Disconnect front links from the mower deck by removing retaining cotter pins. Disconnect the suspension arms from the rear mower deck brackets by removing the two cotter pins.
Move the attachment lift lever all the way to the forward position to raise the mower suspension arms to the full up position. Slide the mower deck out from beneath the tractor.
Crawl beneath the tractor and roll the drive belt off of the stationary idler pulley and the clutching idler pulley. They are both located immediately adjacent to the engine pulley. Be sure the belt is already away from the engine pulley, as well.
Push the drive belt slack toward the rear of tractor. Remove the drive belt from the Trans axle pulley by taking it over the trans axle pulley while compressing the movable belt keepers surrounding it. Remove the old belt from the tractor by pushing it clear of the center span keeper (located beneath the Trans axle pulley).
Install a new drive belt by following the reverse of the instructions for removal. Test the tractor and mower for normal operation.
 Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jul 19, 2010 | Garden
Craftsman 42'' mower when clutch-brake is engaged and released...the level does not return to original position which prevents mower from running at selected speed. my manual does not provide diagram of...
Seems that your clutch needs adjustment, no biggie here. Get your needle nose pliers and a spare ¼ inch bolt or pin. A small Philips screwdriver will also work. The needle nose pliers are for removing the cotter pin and the screwdriver (or bolt) will hold the brake lever in place while you make the adjustment. Then, check under the right side of the deck (side where the grass discharges) right under the plastic mat where your foot rests and next to the tractor's frame you will see the brake lever with the long spring attached. Have a helper move the brake/clutch pedal so you have a better idea of what's going on down there. Then:
1. Remove the cotter pin, washer, and brake spring from the
adjustable nut
2. Disconnect the adjustable nut from the brake lever assembly
and the parking brake latch.
3. Align the hole in the brake lever with the hole in the frame. Hold
the brake lever in place with your 1/4 inch pin, bolt or the screwdriver.
4. Pull the clutch rod forward until tight. Turn the adjustable nut
until the nut will fit through the hole in the brake lever.
5. Assemble the adjustable nut to the parking brake latch,
brake lever and brake spring. Fasten with the washer and
cotter pin.
6. Remove the 1/4 inch (6 mm) pin, bolt or scredriver.
That should return everything to normal. Assuming that there are no broken or bent parts in your clutch mechanism.
I hope you find this solution helpful. Please rate it and thanks for using Fixya. Good luck!
Sep 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cabel clutch
I think you're asking where the clutch cable attaches to the deck. It slips over the top of the mounting bolt on the idler pulley with a cotter pin through the hole on the top to keep it in place. It is the pulley that swivels to tighten the belt. Hope that helps..........
May 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
