Question about Cameras
Although there are only ten (10) pictures on the camera, it displays the information that the 2GB Memory Card is Full. Some have told me that it should take at least 300 pictures. Is there an easy solution?
    President:
  • 423 Answers
If you can check the card in a computer using a card reader, you will probably find multiple folders, possibly created by using the card in another camera. Erase any folders that appear to have been created by anything other than your camera. There should only be one folder on the card, the one with the most recent date of creation (check in properties of the folder). If you perform a "format" of the card, it will wipe out any data and start with a "clean slate". You should then see the true capacity of the card in your particular camera.
Posted on Oct 05, 2009
Transfer pictures to internal memory from memory card
Although most cameras do have an internal memory, the space is very limited. Most of the time you can store on or two pictures. When you shoot in lowest quality, perhaps 10.
If the internal memory is full you can move the pictures from the internal memory to a SD memory card. Not the other way around.
For this see the manual (English) page 33
Jan 20, 2014 | Sanyo VPC-E760 Digital Camera
Display reads "images recorded in internal memory" but there are none and I can't take more than 4 pictures until the camera says the memory is full. Also the memory card says it is full after 7 pictures,...
hi, the memory card you are using is to small for the camera it has not got enough memory on it you need to get at least a 1gb memory card or 2gb memory this will then allow you to take between 500 and 1000 pictures the 16mb card you have in is not worth using it will only hold a couple of pictures so go to the well known auction site and buy a 2gb memory card of the same type such as sd card or micro sd or mini sd it should tell you on the 16mb card what type it is then just buy the same type but with either 1gb or 2gb or even 4gb of memory this will then let you take 1000s of pictures
the 16mb card is no good in your camera get a bigger card and your problem will be solved
let me know if you have any problems with the new card ok
Aug 15, 2010 | Fuji FinePix A800 Digital Camera
I have a Z1015 IS kodak camera and inserted a 128 MB memory card in it. I shot 25 pictures when it told me the card was full. Yet I used the card on a kodak 135 camera and it took over 200 pictures. Am I...
Sounds like you have the picture quality on the Z camera set to a higher setting than on the 135. Higher Quality photos are much larger and will fill up a small 128MB card very quickly. Get a 2GB card.
Jan 02, 2010 | Kodak EasyShare Z1015 IS Digital Camera
Memory card problem
If you go to the support section of the Kodak web site, you may be able to download manuals to your computer.
Dec 08, 2009 | Kodak EasyShare C330 Digital Camera
I get a display saying File No. Full and the camera won't take any pictures
You have reached the max picture level in your camera internal memory. You will have to connect your camera to your computer, download the pictures and in your camera menu reformat the internal memory. Go buy a memory card. Memory cards of 1 to 2GB will hold hundreds of pictures.
Jul 03, 2009 | Fuji FinePix S5000 Digital Camera
Reformatting sd memory card for canon camera an 8gb card and it told me I coudn't print pictures on my HP photosmart 380 series printer unless I reformatted my memory card??
If your camera is indeed an SD200, am sorry to say an 8GB SDHC will not work in this camera. The camera will fail to recognize it, and will do this by giving various problems as you've run into. The overall problem is that the camera was designed before the SDHC format came out (SDHC cards although the exact same in appearance are different in format than standard SD cards). The largest size card that the SD200 will recognize is a 2GB standard SD card.
Jun 10, 2009 | Canon PowerShot SD200 / IXUS 30 Digital...
Have blank 2GB card, camera tells me memory full. How do I get camera to accept the card and send the picture to it no the camera?
this camera takes only cards wich are formatted first on the camera.It will display an error message if you do not use a formated card.See your manual page 59
Apr 14, 2009 | Samsung NV7 OPS Digital Camera
I can't transfer pictures from my camera to my computer.
By far the best solution is to buy a memory card reader, If your PC is usb2 you will be stagered by the increase in speed.
if there are pictures on the internal memory you can use the copy feature to move the images to a memory card.
If you dont have a memory card get one also, the DX6490 will take upto 2gb cards, if in the uk mymemory has 2gb cards for 7.99ukp..
A couple of things to check is that the camera is the only USB device attached to the PC as some devices interfear with each other. and you may want to try another usb cable although its a kodak's own cable type so your unlikely to hve one spare from something else.
Beyond that, try reseting the camera (although im not sure if internal memory pictures will be lost) I dont have my test unit available and cant remember where/iff the dx6490 has a restet option, the other way to reset is remove the main battery for a few hours, if the clock is wrong when you re insert the battery its reset...
best of luck
Feb 19, 2008 | Kodak EasyShare DX6490 Digital Camera
2 GB memory card for digital camera
The number of pictures that a memory card will store will depend completely on the file size of each picture. 750 pictures on a 2gb memory card would be around 2.5mb average each picture, which is more than adequate for basic shots - with a higher resolution the picture size can easily exceed this. Here is the link for the user manual for your camera; http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00261/DX7440_GLB_en.pdf Check page 20 - explains how to change the picture taking settings including the resolution/ file size. Also check page 53 - it explains the storage capacity of different memory cards at different resolutions. The manual suggests that the camera can only deal with a maximum card size of 512Mb, so it is possible that although a 2Gb card appears to work, the camera can only utilize the first 512Mb of the card. Hope this helps, please ask again if not :)
Apr 11, 2007 | Kodak EasyShare DX7440 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
