Question about Kenmore 756A-30BH Mechanical Sewing Machine
It dose not pull tight
I have an old kenmore 6 and it just quite funtioning properly, it will not pull ht e stiches tight so they just pull out, i have tried ajusting the tension with no luck
  • steven_addin Sep 27, 2009
    yup i figured it out, the bobbin tension was the problem. Thanks!
  • Joe R. Downs Jr. May 11, 2010
    Have you tried adjusting both the BOBBIN tension and the UPPER tension? And are you using the correct thread, needle and stitch length? Cleaned the feed dog area, bobbin area, and the track the thread moves in around the tensioner? Thread dust builds up there and can cause loose thread and stitches.
    Scholar:
  • 43 Answers
Bobbin tension, and clean out the feed dog and bobbin area of the thread dust, make sure the tension is set correctly on the upper, and sew, sew, sew.
Posted on Sep 28, 2009
Singer 7470 computerised sweing machine is breaking top thread every after1-2 feet stiches plz suggest me wt to do top gthread is not too tight , i cleared all the lint in the bobbin thread is gd qlt
The needle thread breaks
1. The needle thread is not threaded properly
2. The needle thread tension is too tight
3.the needle is bent or blunt
4. The needle is incorrectly inserted into the needle holder
5. The needle thread and the bobbin thread are not set under the presser foot when starting sewing
6. The threads were not drawn to the rear after sewing
7. The thread is either too heavy or too fine for the needle
Jun 15, 2015 | Singer Sewing Machines
Tension setting for small straight stitch on a Kenmore 10 Stich model 385 1249380 sewing machine.
Please go to Kenmore model 385 1249380 sewing machine sell shop and ask the machanic or shopkeeper.
Jan 01, 2014 | Sewing Machines
Loose stich on bottom of fabric
Hi. The problem is that your upper tension is too loose. It needs to be tighter in order to pull the bobbin thread up.
Robbie
Apr 17, 2010 | PfaFF Creative 7570
The stich is not tight
CHANGE UR STICH SIZE AND TIGHT UR TENSION DISK
Apr 04, 2010 | Riccar R651 Mechanical Sewing Machine
The top needle unthreads after just a few stiches. I have a Singer 2950 and am new to sewing.
Are you saying that the thread is breaking?
CAUSES of upper thread breaking
needle is in backwards
improperly threaded
tension to tight
needle bent or blunt
thread to coarse for size of needle
needle too long for machine
burr on needle
tension discs worn so that thread works in grove
neele too fine for size of thread and fabric
lint or dirt around bobbin case holder
irregular sewing speed
AND THE BIGGEST PROBLEM IS:
threads not properly pulled back under pressure foot when starting to sew
This means, Have enough of the upper and lower thread pulled to the back and hold for the first 2-3 stiches,
Do this every time and it will become second nature and you will do it automatically
Aug 28, 2009 | Singer 2950 Mechanical Sewing Machine
I HAVE Kenmore 385 165 24 bobbin case is loose and I can not get even one stich. Do I miss a srew to hold it in a place? Thanks for help.
if the bobbin case is loose and pops out when started. it is not inserted correctly
make sure you hold the clasp when inserting case and hear the slick into place
make sure upper thread is threaded right and the bobbin thread is even
bring bobbin thread up and pull both threads to the back about fou inches
hold threads and stich a few stiches by hand or foot pedal befor letting fo of the thread.
Aug 26, 2009 | Kenmore Sewing Machines
Stitching is too loose
hi! this particular problem is common when tension and stiches adjustment does not match and complied to fabrics your trying to sew,there a is hard way to find manual specialy to old ones. but if you want it may help you some i got here on manual sears 1803.if your control look similar to this in figure5180e2c.jpg there are stitch control one for straight stitching and one
on special stitching.the small dial near needle is tension dial.You can set tension on # 3 to 5
stitch dial as in figure7a4913a.jpgif you are
sewing a straight stiches set to # 8 to 12 trial are needed somtimes to acquired smooth sewing,Be sure no mechanical problem regarding in machine operation.try to sew a cotton fabric for trial then if sewing another fabrics sudden adjustment should be done.If your machine is equipted by auto tension just select on the fabrics.well small information can sometime helpfull ...nice sewing
Mar 18, 2009 | Kenmore Sewing Machines
Kenmore sewing machine model 15817740
I rooted around and finally found the manual and all the attachments for the buttonholer. Thanks anyway.
Apr 12, 2008 | Kenmore Sewing Machines
Looping thread on backside.
I have a 26 year old Elna and this is the only weakness it has. Before sewing, try this. Turn the wheel manually and watch the upper thread pick up the bobbin thread. Pull both back to the left. Make sure they are plenty long. This helps me prevent the tangling in the dogfeed. My Elna has a universal tension on the bottom and I haven't ever had a problem with it unless the top tension is too tight.
Apr 07, 2008 | Elna 1010
Kenmore 756A-30BH Mechanical Sewing Machine Logo
81 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
