Question about Uniden DXAI8580-2 5.8 GHz Twin 1-Line Cordless Phone
MY PHONE THE LOWER BUTTONS ON THE KEY PAD DOES NOT WORK
MY PHONE THE LOWER BUTTONS ON THE KEY PAD DOES NOT WANT TO WORK OR DOES THE HANG UP END BUTTON
My straighttalk samsung galaxy precedent keeps locking when I try to set up my voicemail. It says "press power key at top to unlock" but when I do it hangs up the call. How can I set up my...
Change the settings. In the main menu tab, under accessibility, uncheck the "power button ends call" This will fix the problem. It allows you to pull down the dial pad.
Sep 22, 2011 | Cell Phones
Tip
Smart phone hanging
If you want your smart phone not to hang or freeze too much, try to close the applications with back button don’t use end key “red button”.
on Apr 14, 2010 | Cell Phones
My pantech matrix cell phone buttons arent working
You can finda different way to end call/ If you got to like call settings, it asks how you want to hang up. I only have to sldie my phone closed. can't help with teh resyt.
Jun 07, 2010 | Pantech Matrix Cell Phone
I have a Verizon Moto Q. The buttons are not working properly. When I hit the start button, back, the arrows, or center select button, mail button and certain letters it just enters numbers or letters and...
Hi, from the question you posted, there are three likely problems to the phone. One it's either the key button pad is bad which needs to be replace, the interface of the key button pad is dirty which needs to be cleaned, or the glass I.C which controls the key button is bad which also needs to be replaced.
But i think what the problem is the cleaning of the key pad button interface because the buttons are working but they only misrepresent whatever function you try to perform on the phone.
You just need to get a mobile phone technician or an electronic repairer around you to help service and clean the board and key pad button interface, and the phone will start working fine..
Take care
Mar 26, 2010 | Cell Phones
How to fix lg kf750 secret touch pad .the top and bottom buttons arnt working
1)My lg k750 touch screen has become a nightmare only lower one works at will the rest are dead so what do i do? less than one year old
2)outbox hangs messages how is it solved
Oct 20, 2009 | LG KF750 Cellular Phone
Top 4 keys
you need to take the phone to a mobile tech and have them service the key pads on the phone or replaced them...this will work. :)
Aug 15, 2009 | AT&T Blackberry Curve 8300 Smartphone
How do I turn the phone on?
It depends on the type of phone. It is usually the red hang-up button, or a separate button near the bottom of the phone. This is usually represented as red, with a circle and a line inside.
Apr 11, 2008 | Cell Phones
Samsung- SGH-D820 key problem
Contact problem more common with any phone. Simply problem, somtimes you have to take a part the phone clean it, dry it to fix that.
You can buy a special cleanig solution for wather dammage from ebay if you realy want to fix this alone.
But if you hawe waranty, use ti!!!
Nov 11, 2007 | Samsung SGH-D820 Cellular Phone
Key pad is frozen
is your phone been dropped or wet? check local service center near our place.
Sep 20, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Uniden DXAI8580-2 5.8 GHz Twin 1-Line Cordless Phone Logo
59 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
