Question about Sony VAIO VGN-N150G/W PC Notebook
Many errors and slow startup and performance.
  • 30 Answers
The best solutions is to defrag the do a disk clean up. if this does nto work try a restore point. Last but not least you may have to reinstall
Posted on Sep 26, 2009
Testimonial: "Good advice. "
    Sergeant:
    Champion:
  • 232 Answers
Firstly you could have too many program starting when you boot your PC .
click start , then click on : set program and access defaults and click on add and remove window components .Uncheck the items that you do not use .
this will automatically increase the start up of your PC .
after that make sure to delete the temp files by clicking start
click control panel
go to internet options
click on delete brownsing history .
Last thing , defrag your PC which will make it work faster too .
restart your PC and you should be away .
Make sure to do this often to keep your PC running fast and healthy .
How to Optimize Windows Startup?
  1. Intro: How to Optimize Your Slow Windows Computer. ...
  2. Step 1: Remove Malware, Spyware, and Adware. ...
  3. Step 2: Run Error Checking. ...
  4. Step 3: Clean Up Unnecessary Files. ...
  5. Step 4: Uninstall Unused Programs. ...
  6. Step 5: Disable Visual Effects. ...
  7. Step 6: Set Energy Settings to High Performance. ...
  8. Step 7: Make Sure Windows is Up to Date.
Oct 20, 2016 | Computers & Internet
My Acer Aspire 5742 runs so slow even after a reboot, what can I do? Thanks. Kevin.
Hi Kevin...you can install a free software like cc cleaner and run to remove cookies and temp files on ur PC
->perform a defrag of the Hard disk
->you can increase virtual memory
->you can disable some unwanted programs at startup
->can do a registry cleanup if it works well and good if not
my email address is jalander.reddy@gmail.com please email me when ur free and ur convenient time so that i can take and work on ur PC and try to optimize ur PC performance..n it wud be for free.
Oct 01, 2013 | Acer Aspire One AOA150-1784 Netbook
The computer is too slow
follow the steps below
- Delete programs you never use
- Limit how many programs load at startup
- Defragment your hard drive
- Clean up your hard disk
- Run fewer programs at the same time
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that made your system slow
Sep 22, 2013 | Computers & Internet
My new fujitsu lifebook SH877 is slow.
Follow these instructions
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that cause of system slow
Sep 18, 2013 | Fujitsu LifeBook Computers & Internet
Erre code0x80070005
0x80070005 error symptoms can include program lock-ups, slow PC performance, freezes and crashes, startup and shut down problems, ... Designed for Windows 7 and Some Vista
Apr 04, 2013 | Acer Computers & Internet
Slow boot HP Pavilion zv6131us
Eric,
There are a lot of factors that can be a cause to slow boot up times. Sometimes it is a lengthy process to figure out what or why the boot time takes so long.
In Windows XP the first step that I would perform is to click on Start>Run and then type: "msconfig" and click OK. (Don't put in the " marks.)
Once you are in the System Configuration Tool, click the Startup tab. Disable all of the items in that list. Then click the Services tab. Check the Box for "Hide all Microsoft Services" and then disable all.
After clicking "OK" you will be prompted to reboot the computer. Do so. Time the boot/startup time. If it has significantly improved, then half of the troubleshooting is done. Next, you will need to go back into MSCONFIG and go to the services tab and enable a few of the services. Then apply and reboot. Make sure to write down which services you've re-enabled and make sure to time your bootup.
Through the process of elimination, you should be able to find out which service is slowing the system down. If you have rechecked all of the services and the system is still booting with an acceptable speed, then begin checking the startup items. Do the same process of checking just a few items at a time, writing down which ones you are checking. After rechecking just a few, apply and reboot, timing the boot up time.
Through this process you should be able to find the services or startup items that are slowing your computer down. Once the offending services or startup items are identified, you will need to make a decision of whether to leave that item out of the startup process or possibly reinstall that program.
If you find the offending item, and are unable to identify it by name, you can always go to Google and type that item's name into the Google search and it may give you an indication for what that startup item is, or what it is part of.
Sometimes, if you have a virus or malware, you may find the items listed in startup. If you do find a suspicious item, then you will need to make sure to run a full malware scan to remove any of those items that are unwanted.
Hope this has helped steer in the right direction to find out why your computer is running so slowly!
Nov 20, 2011 | HP Pavilion zv6131us Notebook
My pc is running really slow... can u please help me????!!!!?????
There are a number of reasons but mainly 2 kinds causing a PC running slow. Outdated hardware or poor system maintenance. If possible, try upgrade hardware configuration such as add more RAM etc. Otherwise try this program Speed up PC to diagnose & fix the slow pc for issues. Best regards!
Jul 17, 2011 | Computers & Internet
My computer runs very, very slow.
go to > start >run > type" msconfig" .
it will open "system configuration utility" window
go to > click "startup" tab, and disable all startup items exept any antivirus.
click apply and ok. it will ask for restart. press ok. these methods will resolve some computer's slow issue. best of luck. keep smiling...
Jan 15, 2011 | Dell Dimension 2400 PC Desktop
Acer Aspire 5740 works very slow
It seems that your computer is loaded with a lot of programs during startup. This means that before windows can formally start, it has to load all those software into memory which can readily translate into slow performance.
To boost your computer performance, you have to decide which software to load at start-up (or boot time) and which should be loaded when necessary only.
To make this easier, I recommend that you download "CCleaner" software, a free software that can manage all these. With CCleaner, you can easily "disable" a software that is configured to load at startup.
These is no risk in unloading a software from startup since you can just open them when you need it. Startup programs comsume a lot of resources making your system to perform slowly.
Also, with CCleaner, you can cleanup the registry with all the mess that your programs do.
You can download it HERE.
Jun 05, 2010 | Acer Aspire 5610-4648 Notebook
Sony VAIO  VGN-N150G/W PC Notebook Logo
71 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
