Question about Consew 206RB
I need help installing speed reducer pulleys. Have parts - no instructions it is a Consew 206RB 5 It is complete with head, motor and table. Speed for me seems turbo charged.
  • 6 Answers
SOURCE: Consew 206rb-5 timing
Those 2 buttons do NOT set the timing . The button on the left is to change the stitch length . the one on the right is to engage the safety clutch after it has been tripped .
Posted on Dec 30, 2008
SOURCE: 206RB 18 years old
Bob, I have a Consew 206RB-2 about the same age as yours. I have both manuals and will copy for you. Will need postage and copie paid. Let me know
Happy Consew Sewer, Thalei
woollymamitts@yahoo.com
Posted on Feb 03, 2009
SOURCE: consew 206rb-1 thread was caught in the boobin area i removed
Had the same problen today, Remove your bobbin, the part where the bobbin is in should move a little, if it does not you have string you can not see behind that part. To get it out turn the machine backwards, it will really turn hard, but will turn, do this until you can see the thread come out or until the piece that holds the bobbin will move a little. good luck
Posted on Apr 28, 2009
SOURCE: I need a manual for a consew 206rb-1???? anyone
I have one and will copy it for you. Leave your phone number or give me your address.
Royce
Posted on Apr 22, 2010
SOURCE: I need a downloadable Operating Manual for the Consew 206RB-5
I can not get the top thread to pick up the bobbin thread on a machine I have just bought .It was sewing fine and then the bobbin ran out. I have tried every which way but nothing works which way should the bobbin be winding
Posted on Feb 20, 2011
How to Change stitch size
It is the knob above your reverse lever. Heres a copy of instruction manual.http://www.consew.com/Files/112347/InstructionManuals/206RB-5.pdf
Apr 16, 2015 | Consew 206RB
Need a manual for Consew 206RB. Any takers?
Servicing the Timing is NOT a home fix
Feb 26, 2014 | Consew 206RB
How do you slow down the consew 206rb
You don't say if it is a clutch motor or a servo motor. They answer to your question is yes you can slow it down by either motor (usually a knob or switch) and by pulley. If you don't have a servo motor I would strongly urge you got contact Cobra Steve at leather sewing machine company (google it) Tell him you want one of the smart servo motors with needle position-er (needle up and down automatically)
His smart servo motors are also modified so they work very similar to home sewing machines... with graduated speed based on how hard you press the pedal.
But if you must and want to stick with a clutch motor... you might try this fellow's hack.
http://www.adafruit.com/blog/2007/11/08/hacking-an-industrial-sewing-machine-by-adjusting-the-clutch-motor/
Oct 25, 2012 | Consew 206RB
Why is the hand wheel of my new consew 206rb-5 so tight? the machines hums when sewing, like beeind forced, is this part of the breaking in?
contact the one you bought the machine from & tell them how
tight the hand wheel is & see what they recommend
Jun 04, 2012 | Consew Sewing Machines
Hi, I just acquired a consew 206RB machine but not the manual. It starts very fast so,I'd like to know if it has a speed control. Thanks
I slowed mine down by replacing the pulley on the head with a larger pulley that I bought at the local hardware store. All of the internal parts slowed down by the same amount so after 20 years it still works fine.
I used a 6 inch pulley (about $10.00) with a 1/2 inch center hole. Finding the right size of drive belt was the hardest part of the whole operation.
There are only two screws that hold that pulley on. One of them is a set screw very near the small center hole that stops the pulley from spinning on the drive shaft.
I'm using a 206RB-1 for house furniture
Nov 17, 2010 | Consew 206RB
Just got a new Consew 206 but can't figure out how to install the knee lift onto the head. Can you help me? thank you.
First make sure your oil pan is installed. Sitting at the machine the opening should be to the right. Turn the table upside down. Then move the rod with the two brackets over the opening in the oil pan. The opening should be just below a part with a roller bearing on it. When the knee pad is moved the rod on the shaft comes in contact with the roller bearing and lifts the lever for the walking foot. The front bracket should be about 1 inch from the front of the table and the long rod centered roughly in the left third of the opening in the oil pan. Use a magic marker to mark the holes for the brackets then pre drill your holes. Test moving the rod because if it is too tight in the brackets it won't move when you move the knee pad. I used the part with the curved rod to make contact with the roller bearing. The part for the pad goes in front. Since there were no instructions and Consew was no help I figured it out by trial and error. Hope this helps.
Aug 14, 2010 | Consew 206RB
Just got the Consew 206RB-5 Are there any instructions how to put together the table and the machine i just got? Thanks
You need someone to do it because you have to get the motor and the belt in the correct place, you can't do it by instructions over the web
Aug 10, 2010 | Consew 206RB
Royce
Jan 22, 2010 | Consew 206RB
Can not start at a slow speed with foot pedal need to now how to adjust start speed
THE FOOT PEDLE IS NOTHING BUT A REASTAT. A REASTAT IS A WIRE WRAPPED AROUND A CONDUCTOR THE WINDINGS START OUT FAR APART AND GET CLOSER TOGETHER THE FARTHER YOU PUSH THE PEDLE DOWN . THE FAR APART WIRES ARE THE SLOW SPEED THE CLOSER ONES ARE FASTER SPEED
THESE WIRES WILL WEAR OUT OVER TIME OR CORRODE OVER TIME AND CAUSE THIS PROBLEM. TRY SOME ELECTRICAL CONTACT CLEANER AND SPRAY THE FOOT PEDLE INSIDE ANY WHERE YOU CAN AND LET DRY. MOST CONTACT CLEANERS ARE NONE CONDUCTIVE AND DRY IN MINUTES
Aug 15, 2009 | Consew 206RB
Consew 226 Speed
buy smaller motor pulley this will reduce machine speed
Jun 16, 2009 | Consew 226R-1
Consew 206RB Logo
265 people viewed this question
Top Consew Sewing Machines Experts
SewTechWayne
SewTechWayne
Shehu Pro
Shehu Pro
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
