Question about LG Dishwashers
I have an error code of 1E on my LG dishwasher what does this mean and how do I fix it?
  • 725 Answers
1E error is Not reached to the normal water level in spite of 10 min. water supply
POSSIBLE CAUSE REMEDY FOR ERROR OCCURRENCE The Water Supply Tap is closed. The Water Supply is shut off. The Inlet Hose is kinked. The Water Pressure is very low. (below 10 psi) Inlet Valve is OK? The filter of Inlet Valve is clogged by impure water. The Hall sensor is OK? The Impeller of Air Guide is bound.
Remedy Take action on Water Supply device. Measure the electric resistance of Inlet Valve. (950-1300 ) Clean the filter of Inlet Valve. Check the frequency of Inlet Water by the Test Mode. Replace the Air Braker.
Posted on Sep 27, 2009
Showing a 1E error code
You need to post more info like a model number
Aug 29, 2016 | LG Dishwashers
1E error code
Search Results
    E1 error on LG Dishwasher - YouTube
    ? 2:40
    www.youtube.com/watch?v=2qcwAyHI9ik
    Aug 24, 2012 - Uploaded by 62spindrift My fix for E1 error on LF Dishwasher. ... Dishwasher Pump and Motor Assembly Replacement - LG ...
Sep 30, 2015 | Dishwashers
I have a LG dishwasher that exhibits occasional groaning, 1E error and poor cleaning. Sometime it works fine but lately it's getting more common.
Since you have replaced the water inlet valve and still have the 1E error code, this leads me to believe that your water pressure could be too low.
1E error code means that your machine is not filling with enough water to operate correctly, so check the supply system completely and also the filters where the supply hose enters the machine.
The poor cleaning could be food clogging the lower filter screen, the groaning is the circulation pump cavitating.
Apr 28, 2015 | LG LDS4821ST Stainless Steel 24 in....
WHAT DOES ERROR MESSAGE 1E MEAN AND HOW DO WE FIX IT?
On LG's, a 1E error message usually means there is a problem with the water inlet valve. Check your shutoff valve under the sink, first, just to make sure someone didn't accidentally turn it off. If it's on, then it's most likely the water inlet valve located under the dishwasher.
Oct 18, 2014 | LG Dishwashers
Cycle wont start washing, it flashes 1E on the screen.
( 1E) IT MEANS THAT U HAVE AN ERROR . CHEEK YOUR CYCLE WASHING SET UP
Mar 26, 2012 | LG LDF6810ST Stainless Steel Built-in...
I have the same problem !!!
I have the same thing happening to my dishwasher what do I do
Aug 18, 2009 | LG 24 in. LD-12BW5 Free-standing...
LG DISHWASHER LD-12AW2
ae unknown code,,,but ie that means uinit is taking to long to fill,,your inlet screens are clogged or the water pressure is to low...kinked hose...onthejob
Jan 19, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG Dishwasher LDS5811ST 1E error code
I had a LG certified repairman come out and fix. The electrical wires within the door were melted into the "tar" (sound deafening spray) and one wire actualy sheered. Apparently the drying cycle heats the tar and the wires become embeded and melt into the tar. This is what was causing the error code. After the wire was tested and spliced everything worked great. Long term...The door/electrical harness was replaced by LG.
Oct 08, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
LG LDF7811ST 1E code
Are you sure it's 1E and not LE error code??  The symptoms you mentioned indicates that it is an LE error code and the motor has an issue.  You will need to call a qualified LG technician to diagnose and resolve the problem.
Jun 28, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Dishwashers Logo
523 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
