Question about Estate TEDX640JQ Electric Dryer
Replaced the coil and still not heating up on my estate dryer
Estate dryer replaced the coil and still not heating up somone told me you can by pass something and it should fix it but what is it
    President:
  • 1,489 Answers
The thermal fuse (aka thermal limit switch) is probably blown. It is not a good idea to bypass this fuse -- if the dryer overheats, it will not cut off the heating element -- fire is likely in that scenario. If you want to troubleshoot the problem, let me know,
Charlie
Posted on Sep 26, 2009
I have a whirlpool estate dryer and it will not heat up
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Jan 22, 2011 | Estate Dryers
My estate dryer is not producing heat throughout the entire dry cycle.It does initially, but not all the time.Saw heating element glow and flame up shortly after , but will not stay on and dryer will run...
Nov 25, 2010 | Estate TGDX640JQ Gas Dryer
Replaced ignitor, still no heat
if igniter is good, do you hear 2 clicks when it starts, one then one about 10 to 20 sec later?  if not, the coils on the gas valve are bad or gas valve is bad.  coils can be replaced separately from valve to save a lot of money...
Jul 29, 2010 | Estate TGDS680EQ Dryer
Dryer does not heat up anymore. It is an electric dryer.
Check the heating element or coil inside the dryer, you should check it visually for breaks, but a much better way is with an ohmmeter with the machine unplugged from the outlet. Touch one lead on each of the coil connectors you should have low resistance, if it is open then replace the coil. hope this helps. good luck
Mar 14, 2010 | Estate Dryers
Estate gas dryer heats up but then flame goes out after around 30 seconds. Replaced the gas valve coils and the thermal fuse, but problem continues
It's likely the problem with the airflow. High limit thermostat is turning the gas valve off. Clean/replace the vent and lint trap.Check if there is anything stuck to the grille inside the dryer.
Oct 13, 2009 | Estate TGDS840JQ Gas Dryer
ESTATE GAS DRYER IS NOT DRYING IT STARTS WARM
Yes replace the solenoid coils. Easy fix and cheap too. Do it yourself for under $40.
Sep 11, 2009 | Estate TGDX640JQ Gas Dryer
Estate dryer electric, heating element gets hot but motor does
shut off power to dryer. take front off dryer,remove belt from motor and idler pully (if there is one) try turning the motor shaft by hand. if it doesn't turn ,take off back of dryer and remove blower housing and see if anything is blocking the impellers.. if not any of these then you may have to get professional help it may be a bad motor or timer
Jan 22, 2009 | Estate EED4300SQ Dryer
I have a estate electric dryer with no heat.
check the heater coil and limit switches....if either are bad you wont get any heat
Dec 25, 2008 | Estate TEDS840JQ Electric Dryer
We have an Estate Whirlpool clothes dryer/Model #MY60-G which was purchased (I think sometime in 2002?). It spins, but after it is on for a little while the heat stops and the clothes never dry. We were...
gas dryer ? replace the 2 coils on gas burner the 2 black round dohickys..electric possible bad operating thermostat remove back round object on blower housing
Jul 08, 2008 | Whirlpool Dryers
Estate TEDX640JQ Electric Dryer Logo
143 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
