Question about Uniden 2.4 GHz Expandable Phone System with Digital Answering Machine
Red message light is blinking on my Uniden phone and voice mail icon appears on screen when I have no messages. How do I get rid of the blinking light and the VM icon?
  • 2 more comments
  • SailorBlue Sep 20, 2016
    Lots of good solutions on this thread. Read mine located below too.
  • Laraine Lanaghan
    Laraine Lanaghan Dec 09, 2016
    Menu>Global Settings> select VMWI reset. Yes
  • Ian Warren
    Ian Warren Aug 11, 2017
    awesome advice fixed it in a "flash" bad pun!!!
  • Vanessa White
    Vanessa White Jan 23, 2018
    Awesome worked for me too
Our just started to do the same thing. Drove us crazy because there were no messages. I couldn't find the manual so I looked up the manual on their website. Here's how to fix it....IT WORKS! With the phone in "stand by", open the menu and select Global Setup.Select VMWI reset. Then select yes.
Posted on Mar 11, 2012
  • 17 more comments
  • Uncle Wylie Jul 09, 2012
    That worked and sved me from looking it up. Thanks
  • LeRoi Cynthia Dabney
    LeRoi Cynthia Dabney Oct 02, 2012
    it works for us thank you
  • laydeejan200
    laydeejan200 Apr 21, 2013
    Thanks, holding down the button worked for me...
  • Dorothy Smith
    Dorothy Smith Jul 16, 2014
    Thank you this was driving us crazy too, and your advice works
  • hymie kideckel
    hymie kideckel Aug 14, 2014
    No more flashing light or envelope icon!!! Thanks so much. I should have looked you up 2 weeks ago when I bought the thing.
  • mbrown Jun 18, 2015
    Too simple, I owe you a cup of coffee.
  • Anonymous Nov 01, 2015
    Thank you so much it worked :) woohoo!!!
  • Anonymous Feb 09, 2016
    Thank you!
  • Rosina Sharma
    Rosina Sharma Oct 02, 2016
    YESSSSSS, thanks a ton
  • Anonymous Nov 11, 2016
    VMWI reset didn't work for me. Any other suggestions? Am I doing it wrong?
  • Linda Malditha
    Linda Malditha Aug 15, 2017
    Brilliant thanks finally someone knows the correct way! All fixed
  • J. Maatouk
    J. Maatouk Oct 23, 2017
    Perfect, VMWI reset worked like a charm... Thanks.
  • Steve Palestini
    Steve Palestini Nov 13, 2017
    Call your phone, go to message options, clear messages.. Solved!!
  • David
    David Jan 25, 2018
    My VMWI reset worked once, but not the second time
  • Brianna Cameron
    Brianna Cameron May 12, 2018
    Worked for me. Thanks
  • Brianna Cameron
  • Marg Cooke
    Marg Cooke May 18, 2018
    Many thanks, that b.......g light was driving us madder.
  • Robbie Bogard
    Robbie Bogard Jun 13, 2018
    Worked! Thx!
  • Sue Cox
    Sue Cox Jun 25, 2018
    You just push the find button on base unit for about 5 seconds. It says paging, let go of button and red light no longer flashes.
Hold down the "find handset" button on the phone base until the beeping stops. This will reset the message indicator. I just had this problem and downloaded the manual from uniden.com.
Posted on Jan 25, 2010
  • 4 more comments
  • Maddy
    Maddy Sep 03, 2017
    Totally worked!! No more blinking red lights on either of my Uniden handsets! Thank you!!
  • David
    David Jan 25, 2018
    DECT 6.0 1735. Where on the base is the "find handset" button - no such button.
  • David
    David Jan 25, 2018
    OK found HS and followed your instructions
    but blinking led is still blinking
  • David
    David Jan 25, 2018
    Changing the VMWI Reset doesn't stop the blinking light from blinking.
  • David
    David Jan 25, 2018
    Well now - turns out to be a Telstra supplied message bank I didn't realise or know I had. Once the message bank was set up and all four messages deleted, the blinking light NO LONGER BLINKS. Yeah!! Now i know.
  • Kelly Paul Feb 24, 2019
    Thank the global thing worked for me but wondering what i just set up ( re: khartison195 post)
  • 4 Answers
Thank you ScorpionQwn! You are my hero! That blinking light was driving me bonkers.
Posted on Apr 20, 2010
    New Friend:
My uniden phone red light is blinking and it shows an envelope and there is no message it says empty. How can I fix this?
Posted on Feb 08, 2013
The menu/ Global Setup. Select VMWI reset. Then select yes,,,worked for me, but then within hours the red light returns! Why? Nothing has happened, no new phone calls, no new messages, nothing. Yet the red light blinks and blinks and blinks. I reset, then the same thing happens again. Wonder what's going on?
Posted on Jun 21, 2012
  • 2 more comments
  • SailorBlue Feb 13, 2013
    Make sure all voice mail messages are cleared from your phone company's mailbox. Check with your provider on how to do this if you can't figure it out. Basically it's usually, you call your own number and get into the mailbox that way. Clear all stored or especially unheard messages, that will make the little blinking light on your phone go away and all icons saying you have a message but you don't on your home answering machine.
    That should do it~!
  • Tracey Bokor-Moore
    Tracey Bokor-Moore Jul 14, 2015
    Yes you are a hero. Thank you. Not in manual that i could find
    Yeah these sort of things can drive you batty! Especially when it blinks all night long in your eyes while sleeping. There's always the black tape fix! LOL
  • robert anderson
    robert anderson May 30, 2018
    Thank you for this solution. all the others suggest the VMWI reset but there is no such thing in my global set up.
Holding down the "find handset" button worked for me. Thanks!
Posted on Apr 09, 2012
The light will also blink on the handset if there is a message on the base unit... look there to see if there are messages.
Posted on Apr 04, 2012
My 2 year old was playing around with the phones, and he must of pressed it. It has been driving me CRAZY, finally it is fixed. I held down the FLASH button for 5 seconds, and it shut off.
Posted on Apr 11, 2012
  • Beverlyshephard
    Beverlyshephard Nov 23, 2014
    Thank you Phillip!! It worked!! We moved and couldn't find my manual, was driving me crazy every time I passed and saw the blinking red light! Thanks!
I unplugged mine and immediately plugged it back up and it worked for me!
Posted on Aug 06, 2014
  • Miriam Kotsonis
    Miriam Kotsonis May 27, 2017
    I had tried all the fancy solutions without success. This one (should have thought of it but didn't) worked like a charm. Thanks so much!
  • 26 Answers
I had no problem for a year. A month ago, it started. That insipid flashing red light. I have tried every answer on this post. The VMI reset lasted 10 minutes. The find button did nothing. emptying the already empty message envelope did zip. I pulle the batteries and waited 30 seconds. No effect. So finally, and don\'t ;laugh, I cut a small piece of electrical tape and covered the damn light. Now I don;t see it flashing out the corner of my eye. Peace at last, peace at last!
Posted on Aug 28, 2014
  • Nelda
    Nelda Sep 12, 2017
    I am like you I have tried all the hints above none worked I have 7 phones and they all blink whan i have no message I am expecting important messages but i never know if I truly have one or not cause it blinks all the time.
    New Friend:
Phone is blinking the number 88 what is the problem
Posted on May 19, 2014
  • Helen weden May 10, 2015
    On the yellow cordless waterproof uniden I set the mailbox to "direct link". I think I messed around with the settings a year ago. It has stopped blinking now.
    I replied to Susan by mistake. My solution is for flashing red light. Thanks
SOURCE:
How do you know if you have a voice mail message
Yes, the was bothering me for some time. I think the indicator is a little green light that blinks in the extreme upper left hand portion of the phone...not on screen, above it....but the blinking light may indicate a missed call or a voice mail is present.
Try this. Go into your phone icon, press and hold '1' and listen to any open messages. Delete each. Next go into your Call Log and delete all call history. Now exit.There should be no green light flashing in the upper left hand corner of phone. You have just cleared everything.
Next call your phone but hang up before leaving a message. Note the blinking green light in the upper left hand corner apparently indicating you missed a call. Go into your Call Log. It will say one missed call. Exit the call log and note that the blinking light is now off. You have acknowleged the call in the call log so the light goes off when you exit.
Call the phone again. This time leave a message. Note the blinking light again. Go into your call log again. Note the missed call. It would be nice if there was an icon or something HERE that indicates if this call left a voice message....but there does not appear to be. Exit again. This time note that the light continues to blink even though you entered the call log and acknowleged the call. I believe it continues to blink because you have a voice message. Exit.
Go into the call log again. Delete the missed call from the call hsitory. Exit. The light still blinks, I believe still indicating a voice message.
Go to your phone icone. Press '1' to check messages, delete the message and exit. The blinking is now gone.
So it appears a blinking green light indicates a missed call. If it still blinks after exiting the call log, you have a voice message.
If someone figures something else out let me know because this stinks!
May 28, 2014 | AT&T GoPhone Radiant
How do you access your Voice mail. My red light keeps blinking, and i have a VM on my screen
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Mar 22, 2011 | Uniden DECT 6.0 Cordless Phone ID
All messages have been deleted but message button keeps binking?????//
Most of the time your home phone service has a digital voice mail like your cell phone does. If the answering machine is set for an amount of rings that is too long the digital voice mail service will answer before your machine. The new cordless phone indicators do show messages on your digital voice mail as well as the answering machine. Depending on your home service, most of the time when you press talk and you hear a different non standard dial tone(mine pulses 3 times before going to solid dial tone) you have a digital message. You need to delete this message before the indicator light will stop flashing. Then set up you digital voice mail for a longer pickup time! This should get rid of this problem.
Mar 07, 2011 | Uniden DECT 6.0 Cordless Telephone...
My uniden cordless phone says vm on the screen. What does that mean?
It is voice mail and some time you checked voice mail on your cordless phone but light will keep flashing that you need to check your voice mail. if it does not fixed then You need to also delete the voice mail from any voip device and it should turn off blinking lights and will clear vm message.
Feb 17, 2010 | Uniden Lands Phones
Indicator light won't stop flashing
I have a Uniden 5.8 GHz and the message indicator light will not stop flashing. The phone screen says I have a voice mail but I don't. Does anyone know to fix it?
Feb 04, 2010 | Uniden 5.8GHz Cordless Phone
I have a uniden dect1580 6.0 and the red light in the left hand corner blinks all the time.
That is the message waiting indicator, it is telling you that your Call Notes (Or whatever your service provider calls it's voicemail) has a message waiting. If you do not have a message waiting, you can turn the light of by following these steps:
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes and
appears in the handset display. In the event your message waiting light gets out of sync with your phone company’s
voice messaging system, you can manually reset it back to the “No messages waiting” state.
Press and hold FIND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
A beep sounds and the message alert tone is reset.
Jan 21, 2010 | Uniden Cordless Phone
We have a Uniden DECT1588 Series system that we have just purchased. We are connected to a Voice Mail Service through Bell. We can receive the messages from the answering service but the light on the hand...
OK. You have a phone set with an answering machine, yet you continue to pay MaBell for Voice-Mail. Is there any compelling reason. That was my feeling when I first read your question but I thought you might not like what I had to say, so I consulted the Uniden FAQ and here what they have to say.
If you Uniden phone has a digital answering machine, and you also have voice mail through your phone company, the message indicator light will not light up when you have a message in your voice mail system. We recommend you discontinue your voice mail and use the Uniden internal digital answering system.
Jan 04, 2010 | Uniden DECT 6.0 Cordless Phone ID
Message Light
There are unheard messages on the voicemail system offered by your telephone company. Please contact your telephone company for instructions on accessing their voicemail system.
Jun 27, 2009 | Uniden DECT 6.0 Cordless Phone ID
Voice message icon showing but no message
You can contact orange and have them refresh your voice mailbox but if that doesn't work you can connect your phone to iTunes on a computer and restore the software. Set up as new and see if the issue persist. If it is fixed you can try to restore from your back up. If the issue comes back when you put your information on there, then you will need to set up as new
Apr 13, 2017 | Apple iPhone 3G
Voice mail message waiting light does not light
Press down the "find handset" button until the paging beep stops (about 5 seconds) and this will reset the indicator lights on the handsets.
Sep 20, 2008 | Uniden TRU8865-2 Expandable System...
Uniden 2.4 GHz Expandable Phone System with Digital Answering Machine Logo
39,854 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
