Question about Tappan MGF500PBW Gas Kitchen Range
Pilot keeps clicking even when burner operates;
I had a liquid spill on the range that led to the clicking.
  • 999 Answers
The valve switches are wet and shorting causing the ignitor to stay on. It may stp once they dry out and if not replacement is the only option.
Eric
Posted on Sep 28, 2009
    President:
  • 1,015 Answers
Unplug the range and wait 24 hours for the liquid to dry up. The clicking will stop when it is dry. The liquid has shorted the ignition switches causing the igniters to click.
Posted on Sep 26, 2009
Burners light but ignition keeps clicking
use a blow drier to dry the igniter and knobs.
May 21, 2014 | Jenn-Air Kitchen Ranges
Gas burners clicking noise not lighting
Have you dis-assembled the burner assembly and cleaned them out?
Dec 23, 2013 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Click sound that kick starts the flame is continuing even after the flame has been made how do I stop the clicking sound of the pilot?
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Aug 16, 2011 | GE Cooktops
Spilled liquid down inside knobs- alarm sound has finally stopped, but the ignitors continue to click. any suggestions?
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 12, 2010 | GE Cooktops
Stove top burner ignitors will not turn off
This tip I wrote to help people with the problem of the spark not shutting off...the clicking non-stop is a common problem.
Gas Range2_bing.gif Repair Burners Keep on Clicking
heatman101
Apr 30, 2010 | KitchenAid KGST307 Gas Kitchen Range
Electric ignitor
You may have spilled some liquid on one of the burner switches or one of the switches is shorting. Wait for a day or two and if the clicking doesn't stop - check all switches with an ohmmeter. The one which shows any continuity in normal (not "lite") position needs replacement.
Apr 01, 2010 | Tappan TGF657 Gas Kitchen Range
GE range electric lighter will not stop lighting
Is your range gas with electric ignition? And are the igniters constantly clicking with the burners off? If so it sounds like you may have spilled liquids into the electric switches at the burner control knobs causing them to short. This is a common problem and the best fix is to unplug the range from the power and let the range dry out for 24 to 48 hours. Sometimes using a hairdryer can speed up the drying process. If you did not spill or get any liquids into the burner ignition switches then there is a posibillity that one of the switches is defective. You would need to test each igniter switch with a continuity tester and the burner knobs in the off position(power unplugged for safety) to see which switch is defective and replace that switch.
Mar 22, 2010 | GE Kitchen Ranges
2 of my burners keep clicking, even when completely off
Did you recently clean the range? If you get liquid into the igniter switches(located behind the gas control knob) or into the contacts where the igniters are located then it can cause a short and make the igniters to operate even when the knob is off. So if that is the case then the only fix is to unplug the range for 24 hours and let the liquid dry out. If the liquid is not the problem then it could be the igniter switches in the gas control knob are broken and stuck in the closed(on) position.
Jan 14, 2010 | Thermador PD366BS Dual Fuel (Electric and...
My roper stove keeps clicking even when all knobs are off!!!
spilling water around spark control switches closed to burner control valves could cause that...may stop clicking in a day or so..or if on low flame setting the orfices on the burner head are carbon restricted? clean orfices with torchtip cleaners..
Jun 24, 2009 | Roper FGP210 Gas Kitchen Range
Tappan MGF500PBW Gas Kitchen Range Logo
252 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Sal De
Craig Butler
Craig Butler
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
