Question about Dryers
Dryer heats intermittenly usually works when cold and gets worse as temperature rises.
  • 986 Answers
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Sep 26, 2009
The blower heater is not working started intermittenly and then it completely stopped. you can kinda hear a small weeze when turning the nob over
If you are saying that you get no heat coming out of the vents but still are getting air flow.... I would check your antifreeze level with the vehicle at a cold temperature.
Jan 13, 2016 | Cars & Trucks
My 2009 Peugeot 308's heating is baffling me when i drive at normal speeds say 30 and above the engine temperature gauge never rises and the heater doesnt work but when im in traffic or parked with th
Thermostat may not be working properly, hot coolant has to circulate via the heater core in order to get heat. Normally operation temperation should be 180 to 200 degrees.
Nov 21, 2013 | Peugeot 308 Cars & Trucks
Redring california. low pressure/temperature
no model number or any way to identify this item?
Sep 20, 2017 | Home
When I start the car, the temperature guage goes to the normal position, the air coming from the heat vents is cold. When I accelerate the temperature coming out the vents rises and when I decelerate the...
the temp senser is probably shot but easy to replace. i would start there its location is usually the radiator cap and some times on the side of your engine block. as far as fluctuation in temp upon rpms is unfixable, that is just something i call character.
Feb 10, 2011 | 2000 Lincoln LS
After a cold start, I don't get cabin heat for about 15 minutes. The heat gauge starts at C (cold), rises to normal operating temperature, then rises to just under the H (hot) for about 30 seconds, at...
Check for low coolant, you might also have a sticking thermostat. Alot of fords get air pockets, make sure if it needs coolant to let it run for about 10-15 min with the radiator cap off.
Oct 15, 2010 | 2003 Ford F150 Regular Cab
When ambiant temperature rised why unit trip?
Make sure the fan that blows air across the condenser is running. If not this will cause the discharge pressure of the compressor to rise and will shut down the unit. It will get worse as the temperature goes up.
Apr 30, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Dryer works intermittenly shutting off after
tempiture sensor is bad or blockage in air flow. Element over heats and shuts off for safety issues
Mar 09, 2010 | Dryers
Just had new ruud heat pump installed 5 days ago, it blows cold for the first few minutes and then warm but not warm enough, called installer he said thats the way heat pumps work and he will stop out when...
In most newer operations, the indoor fan motor will come on first before the actual heat comes on.
However if you shut off the power and Remove usually
the upper panel. Located on the inside on the right hand side there is information that will tell you what
the temperature rise should be between the supply air and return air.
Usually this requires a thermometer that you can insert about 5ft away from the furnace, for both
the return air and supply air.
If the temperature rise calls the unit to be between 25
and 45 deg F, Adjusting the blower speed lower should give you warmer air maybe as much as 10deg, but 5 deg seems more probable
Jan 25, 2010 | Ruud UBHC Air Conditioner
Intermitten heat
We have a Neptune Gas dryer,my husband changed the belt cause it was making noise,now the heat hardly works,i put the dryer on for 40 minutes and usually it is dry,now i did that twice and clothes is still damp,would you know what the problem is please help
Jan 12, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
12 people viewed this question
Top Dryers Experts
