Question about TMI Products VizuaLogic 82A-99000-6005 Chevy / GMC Pick-Up / Avalanche / Suburban / Tahoe 99/00 - 02 Med. Neutral... Car Video Player
I have a 1999 chevy tahoe its not a 4 wheel drive. i just recently installed 22inch wheels and tires. when a make wide turns they rubb in the front. what do i need to do?
    Scholar:
  • 43 Answers
Wheels are to wide. Trim the valance like I did, see if spacers help, or depending on how much they rub, if it's hitting plastic not metal just wait till your tires wear down just enough to clear. Every time I get new tires (305/70r16) they rub slightly on the plastic when I go up/down curb into driveway and bounce. I have a three-inch body lift too. I have the widest tires that basically fit (11.5 in or so) on a 99 Tahoe with 3"inch lift. They wear slightly and the rubbing stops. My wheels have stock offset. You may need a steering stabilizer if your truck doesn't have one already and those big heavy wheels will make the ride worse and potentially affect your steering components negatively. The steering knuckles are easy to wear out with long-term vibration.
Posted on Jan 30, 2010
Chevrolet suburban LT 1500 LT won't disengage from four-wheel-drive
Chevrolet Suburban Questions - 4 wheel drive does not ...
www.cargurus.com > Questions > Chevrolet > Suburban
CarGurus4 wheel drive does not work - When I put the Sub in 4 wheel drive, low of high, ...Asked by Robert_Holland_073 Dec 17, 2009 at 04:06 AM about the 1994 Chevrolet Suburban K1500 4WD ... it can seize up and then the trans case may ingage but the hubs won't be locked in so it ... 1999 Chevrolet Suburban K2500 LT 4WD.
Chevrolet Tahoe Suburban 4 Wheel Drive Indicator Lights - Car ...
forums.edmunds.com > Chevrolet > Chevrolet Suburban
Oct 2, 2007 - 31 posts - ‎19 authors
My 1999 Tahoe (odo reading 137,400 miles) won't go into 4 wheel drive. .... I have a 98 suburban 1500 4x4 LT 5.7 L with 165,000 miles ... I recall once forgetting todisengage 4WD and I could feel a terrific binding when I ...
Step by Step Troubleshooting 4wd 4x4 88-98 Chevy GMC ...? 21:32https://www.youtube.com/watch?v=Su9Dkrfd_ZgJan 20, 2014 - Uploaded by rwdellingStep by Step Troubleshooting 4wd 4x4 88-98 Chevy GMC Truck. rwdelling .... Mine is acting like it is NOT pulling with the fronts,won't engage. ... Have you ever adjusted or the shift cable on your 1500 Chevy ... GM 246 transfer case, 2000 Chev Suburban- Duration: 20:09. by spelunkerd 286,045 views.GM Troubleshooting Part 13 - 4WD vacuum actuator & cable ...? 5:11https://www.youtube.com/watch?v=CbEF6PyJdU0Feb 3, 2011 - Uploaded by mr diyguy123I tacked on this video about the 4wd sys. ... I have a 1994 ChevyS10 ... My S10 won't let you go to 4 LO when your in gear. ... the front end to keep them disengaged. when you put it in 4wd, the vacuum actuator pushes a gear ...
Dec 25, 2015 | Chevrolet Cars & Trucks
I have a 2006 Chevy Tahoe 2wd. When I drive in it makes a grinding noise from the front axle. I replaced the brakes and both hubs and the noise is still there. I checked the brakes for uneven brake wear...
Could be a wheel bearing. jack up the front end and secure with a jack stand or two. grab the tire at 12 o clock and 6 o clock and see if you get movement. also since it is 2 wheel drive the tire should be easy to spin. While it is jacked up spin it as fast as you can and see if you hear the noise. Some shops have a little motor with a wheel that they do this with. Hope these help.
Feb 11, 2014 | 2001-2006 Chevy Tahoe 2WD Front Wheel...
Will i have a problem installing 225/60/15 winter tires on my 1999 chevy tahoe
I pulled up your vehicle information in our fitment guide and tires in the 225/60/R15 and 225/60R16 sizes are not load rated for your vehicle. They are also quite a bit smaller than the tires that came on your Tahoe when new. Running a tire that is too small (even if it was load rated) will have an effect on your vehicles performance. We do not recommend installing either of these sizes for safety and performance reasons.
If your Tahoe came with 15" wheels we would recommend looking into the 235/75R15 size.
If your Tahoe came with 16" wheels we would recommend looking into the 245/75R16 or 235/75R16 sizes.
If you are still searching for some winter tire options please feel free to shop our website at www.discounttire.com or contact one of our local Discount Tire or America's Tire stores. We would love to help you find a great winter tire that will fit your Tahoe correctly and help keep you and your passengers safe.
Dec 14, 2013 | 1999 Chevrolet Tahoe
I have 05 tahoe when making sharp turns feels like front end is sliding
If its 4 wheel drive, you may want to check your u-joints / cv joints. also check to make sure the tire isnt rubbing on anything at a sharp angle. A bad wheel bearing will also cause a familiar issue
Feb 10, 2012 | 2005 Chevrolet Tahoe
Front Axle making noise and jerking while turning
It is probally in 4 wheel drive. It is supposed to **** while turning in 4 wheel drive because all 4 tires are trying to turn at the same speed and when you turn one tire slows down and the other tire speeds up but it cant in 4 wheel drive so it skips or jerks. If there is also a clicking noise the CV joint might be going out.
Jun 11, 2011 | 2000 Chevrolet Tahoe
Why does my chevy tahoe steering wheel and entire truck shake when drive at any speed?
If it is doing this at slow speeds as well, have your tires inspected for seperation. Sounds like you have a "bubble" in the tread.
May 22, 2011 | 1999 Chevrolet Tahoe
4wd light says service
Does the 4-wheel drive work ? Most of the time, it is a reminder to have your fluid changed. Other times, it could be a vacuum leak in the line that engages the 4-wheel drive. Check both of those first.
Apr 04, 2009 | 1999 Chevrolet Tahoe
Warning light for 4-wheel drive
I had this problem on my 1995 Montero. The 4-wheel-drive indicator lights wouldn't stop blinking when I switched from 4-wheel drive to 2-wheel drive. It turns out that I had a slow leak in one of the front tires. After I fixed the leak and made sure the pressure was the same in both front tires, the problem went away.
This made sense to me because if one tire is much lower in pressure, it's closer to the ground, i.e. has a smaller radius, and therefore rotates more quickly. The manual says to drive in a straight line when disengaging 4-wheel drive but with the lower tire pressure on one side it was the equivalent of driving in a circle.
You could try checking your tire pressures and see if that makes a difference. Hope this helps.
Sep 06, 2008 | 1999 Mitsubishi Montero Sport
1997 chevy tahoe 4 wheel drive transmission
Needs rebuilt converter is bad, a progressive problem that caused overheating most likely. www.TransmissionGarage.com
Jul 14, 2008 | 1997 Chevrolet Tahoe
Car Audio & Video Logo
77 people viewed this question
Top TMI Products Car Audio & Video Experts
greg benton
richie46
Tommie Jones
Level 1 Expert
Are you a TMI Products Car Audio and Video Expert? Answer questions, earn points and help others
