Question about Sub-Zero 680 / F
Frig door does not stay closed - Sub-Zero 680 / F
    Scholar:
  • 43 Answers
When you say that it will not stay closed, what exactly do you mean? That the door seal does not meet the cabinet, that there is a gap? Is the door warped? Does it appear to be out of line with the hinges on the top and bottom? Is the space around the door when shut and looking at the front pretty much equal all the way around? I mean, when shut, does it appear that there is about 1/4 to 1/2 inch of the cabinet showing all around the door when shut? Has someone swung or leaned or tugged on the door, or closed the door or tried to close the door and something was keeping either the top or the bottom pushed out? There are adjustments on the hinges, at the attachment points to the cabinet and to the door itself. You may be able to adjust the hinge plates in or out and up and down to make the door seal better. And the box should be about half a bubble out of level, front to back, or with a slight angle front to back, in order to help the weight of the door seal to the cabinet of the refrigerator. If the door is warped, you may be able to determine which way it is bent, out at top, out a bottom, side to side, ect. and take it off the hinges and gently attempt to straighten this bend. If you are careful, and can determine there is warping at the top or bottom, you may be able to "straighten" the door while attached to the hinges. Gentle pressure is the procedure, GENTLE, GENTLE. Don't get the BIG HAMMER out and go to banging away. Just a push up here, and a tug down there, and you may be able to cure this fairly easy. You must first determine which way the door is warped, and then move it back the other way. It should seal the gasket to the cabinet, not so much attach the door to the cabinet edges, but a firm seal that takes a tug to open. And no air gaps. Are the products inside the refrigerator "sweating". This is the drawing of warmer room air into the cabinet and condensation forming. The door needs to seal in order to keep the cold air in, and the outside air OUT. I an extreme warping, you may have to replace the door, or use bungee straps to keep it shut. which will be a pain, removing those every time you need in it. I would try and determine where it may be bent or warped, and gently bend it back the other way a little at a time till I have the seal connecting all the way around. Once there, QUIT. No more bending. When the seal connects all the way around, you are finished. Problem solved. I wish you luck and hope that you can solve this fairly easy. Remember, be Gentle. It will warp easily. And no hanging on the door!
Posted on Sep 26, 2009
My GE Monogram Frig door will not stay shut, it's lost its vacuum seal!
Check the fridge for out of level. Magnets on the weather-stripping hold the door closed. If there is something stuck on the seal, or too much weight in the door in an un-level fridge it will not make good contact. Try cleaning the rubber, and removing everything from the door after leveling. A good seal will stay closed even if the fridge is off.
Feb 23, 2015 | GE Monogram ZISS480DRSS Stainless Steel
What to do about LG french door refrigerator that does not keep food cold
I would suggest you check the seal and the hinge. This frig has a piece that folds in and out flush for the two doors to seal, you might check that as well.
Aug 11, 2014 | LG LRFD25850 French Door Refrigerator
Frig door is not staying closed
My wife read that if you put a thin layer of Vaseline on the rubber seal it will help keep the door closed. I tried it on an upright freezer and it worked for us. Best of luck.
Jul 20, 2011 | Whirlpool Refrigerators
When I close the frig door, it blows the freezer door open. The same when I close the freezer door, it blows the frig door open.
That is because the unit is sealed. If the doors are staying opened I have posted a how to fix it linked just below.
Doors
May 26, 2010 | KitchenAid Superba Architect KSCS25INSS...
Freezer Door will not stay closed, opens about a half inch after removing pressure.
You can try and adjust the front legs of the frig raising the front about one or two inches. This will but more pressure on the door seal.
Sometimes if you slam the frig door the freezer door will try and open. Tilting the frig back will help solve this problem.
Dec 31, 2009 | Kenmore Refrigerators
Bottom freezer door opens when top door is open and then closed
the door pops open because freezer and frig. are connected together via duct. air pressure builds when you swing ref door closed. apply a small amount of vasoline to the surface of the hinge side of both gaskets. this will aid in door closure. also the unit may be not level
Jul 02, 2009 | Refrigerators
Freezer door won't stay shut
This indicates that you do not have good airflow and return airflow between your freezer and refrigerator sections. That is why the pressure from closing one door is causing the other one to pop open.
Check the drain tube on the back of the machine to make sure it is not clogged or blocked with frozen water inside. Also check any return air flow vents inside the unit for clear ice.
Jan 18, 2009 | Refrigerators
INTERIOR FRIG LIGHT
replace the switch before the seal, nothing wrong with gasket., you may need to raise the refrig door a bit by , remove the door and install a small spacer to raise the door slightly for better contact
Oct 22, 2008 | Frigidaire FRT21H8 Top Freezer...
FRENCH DOOR FRIG FREEZER DRAWER WILL NOT STAY CLOSED ON RIGHT SIDE SETTING OFF DOOR ALARM THERE IS NOTHING IN THE WAY TO PREVENT IT FROM CLOSING PLEASE HELP LORRAINE SOUKUP
had the same problem with this fridge. had the local company that it was purchased from replace the hinge on the top of the door two times--closes a little better, but still does not catch properly.
May 10, 2008 | Refrigerators
Refrigerators Logo
278 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
