Question about Tomtom ONE GPS Receiver
Tomtom one v2 will not turn on tried soft reset
Tomtom one v2 will not turn on tried soft and hard reset still no joy charging light will come on tho when plugged in
Tap the bottom left hand side of the screen and the volume bar should show. then use your finger to slide the volume up.
Posted on Sep 27, 2009
Put on charge for two hours still wont turn on
make soft reset make sure batt is full hold on/off button for more then 15 seconds your tomtom will start again.
Feb 15, 2010 | Tomtom XL V2 GPS Receiver
Tom Tom 130 will not power-up ( no working screen) when power button is activated.
If your device is not starting up properly, follow the steps below:
soft reset:
How to soft-reset my navigation device Answer In rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting.
To reset your TomTom device, do the following:
Check that the battery is charged properly.
Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
Reset your device.
Press and hold the On/Off button until your device restarts. This can take more than fifteen seconds.
Oct 09, 2009 | Tomtom ONE 130 GPS Receiver
Broken tomtom one 3rd edition
Try resetting the unit. Little black button labeled reset on bottom.
Jul 27, 2009 | Tomtom One Europe v2 GPS Receiver
Tomtom wont charge.
If it is charging via a USB connection on your computer there is nothing wrong with the TT. It doesn't matter if you are trying to charge via USB, mains, or car charger the connection is the same for all in your TT. I would look elsewhere for the problem. More than likely your car charger is faulty.
Jun 07, 2009 | Tomtom ONE GPS Receiver
My Tomtom XL won't turn on. No reset button apparent
The reset button is on the bottom of your device. On my older model XL it is just above the sd card slot. If you have the newer model XL 330 then you have to hold down the on/off switch for 20 seconds to do a reboot. If you have not used it in a while let it charge for 30 monutes before doing a reset.
Hope this helps
May 12, 2009 | Tomtom GO 720 GPS Receiver
When i turn it on it freezes.
Hello, I own a TomTom also. I have listed the procedures from TomTom Home and hope this will work. First try a soft reset (Reset button is located at the bottom of the TomTom device next to where the DC plug plugs in). Make sure your batteries are fully charged up or the USB cord is plugged in.
  1. Soft reset your device. *
  2. If your device still does not start up, then reinstall the TomTom application using HOME
If you have backed up your TomTom to your computer, then you can reinstall the TomTom application from your backed up data. *    In rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. A reset does not delete any data.
Jan 16, 2009 | Tomtom ONE 3rd Edition GPS
Tomtom 910 sat nav.
Complain to Tom Tom ,you may have a lemon,look for law suit soon
Mar 25, 2008 | Tomtom GO 910 GPS Receiver
Tomtom 910.
Mar 23, 2008 | Tomtom GO 910 GPS Receiver
PC does not recognise TomTom
Dont use a HUB, connect it directly to the PC.
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
contact them about the problem...
http://www.tomtom.com/support/support.php?ID=2
Sep 03, 2007 | Tomtom One Europe v2 GPS Receiver
Frozen tomtom
Is there a reset button? See this from PocketGPSworld.com: Reset hole The Reset hole is hard to find, you need to first remove it from the mount, turn it upside down, and within the mounting base area of GO you will see two interface slots (currently only one is being used) and towards the front of the unit on the base you will see a little hole marked reset. This is just like soft resetting a Palm or Pocket PC, it requires something small like a paperclip, and nothing was supplied with GO to enable you to easily reset the device.
Feb 25, 2007 | Tomtom GO 510 GPS Receiver
Tomtom ONE GPS Receiver Logo
324 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
