Question about Whirlpool Dryers
Whirlpool gas dryer heats intermittenly usually heats when dryer
Is cold. It heats intermittenly from time to time
  • 67 Answers
Replace your valve coils
Posted on Sep 29, 2009
Gas Dryer wont stay lit.
It may be your dryer vent piping. If the piping from the dryer to the outside of the house is clogged with lint (which happens periodically) the dryer cannot get rid of the heat generated by the gas burner. When the temperature reaches a certain level the high limit switch opens and shuts the burner off. The switch closes again after the dryer cools down. Check the lint filter and all the vent piping for any obstructions and clean out thoroughly. This should solve your problem. Hope this helps.
Jan 14, 2014 | Whirlpool Cabrio WGD6400SW 7.0 Cu. Ft. Gas...
Heat wont stay on
Replace the 2 gas valve coils, check the link below to have an idea of how they look like.
Maytag Dryer Gas Valve Ignition Solenoid Coil Kit 279834
Jan 14, 2014 | Whirlpool LGB6300 Gas Dryer
Gas Dryer Heat wont stay on.
Must be something in the blower section. You need to get into the dryer and clean it up. Air restrictions cause overheat condition. When the temp gets so high the limits shut it down. Lots of videos on you tube that show how to get into. You can google gas dryer dan webster or roper dryer no heat dan webster and I have some videos posted how to get into these.
Dryer's heating element is working intermittenly
faulty conection or heat sensor have it checked out by your local repair man
Aug 11, 2011 | Whirlpool LGR5636PQ Gas Dryer
Intermitten heat only, what could it be?
this could well be a partly blocked out let pipe and filters or a partly blocked air inlet pipe or grill have a good look at both of them,,, if its not any of them its likley to be an over heat sensor playing you up
Oct 25, 2009 | Whirlpool GGQ8831L Gas Dryer
Amana gas dryer mod #NGD5240TQ0 intermitten heat
i went to a local appliance store asked them for assistance. they were more than helpful and sold me the parts i needed. fixed the problem for under $30.00. i also didnt have to pay for their ADVICE !!!
Aug 22, 2009 | Amana Dryers
I have a Whirlpool gas dryer, LGR5636JQ0. It will
if the vent is clogged or duct in back of machine is will over heat and safety will shut off heat pull maching out check ducts and exhaust prt on machine
Jul 06, 2009 | Whirlpool LGR5636L Gas Dryer
Initial heat then goes cold
Very common change the gas valve coils and you are good to go easy repair i can ship them to you free and tell you how to do it in no time... call me whirlpoolpartssurplus.com
Jun 26, 2009 | Whirlpool LGB6300 Gas Dryer
Gas Dryer does not continue to heat.
Check the Following to address this issue--
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Jun 02, 2009 | Whirlpool Dryers
Intermitten heat
We have a Neptune Gas dryer,my husband changed the belt cause it was making noise,now the heat hardly works,i put the dryer on for 40 minutes and usually it is dry,now i did that twice and clothes is still damp,would you know what the problem is please help
Jan 12, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
54 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
