There is something wrong with my camera when I insert the batteries and I take a few pictures the screen turns red and says batteries are depleted camera shutting down, I turn the camera on again for a few seconds it does it again I don't know if there is something wrong with the camera or something wrong in the battery department. I hope someone can help me out. The camera is now 2years old no more warranty.
-   drains batteries way too soon, even rechargable nicads-   Guest
Dec 21, 2008
-   My Camera is doing the same thing, it keeps saying change batteries. I even put rechargeable batteries in and it says the same thing. HELP-   Guest
Jul 16, 2008
-   my camera is too, Although i use the new bateries or adaptor. There 's " bateries's depleted" on the red screen, After that it turn off automatically.Sometime in the few case it shut down but the lens's still outside.I do not know why?-   huukhanh0309
Jan 29, 2008
-   I have the same exact problem.-   redsox_bite
Are you using Rechargeable batteries or Alkaline batteries?
My guess is you are using Alkaline (disposable batteries). There are very few digital cameras that well run on alkaline batteries. Most (inlcuding the HP cameras) require rechargeable NiMH or lithium.
A pair of rechargeables with charger will be $20 bucks at most but it will take far more pictures and will last you at least 500 charge/discharge cycles.
The M407 shares a problem common to many cameras using only two AA batteries. Because of the low voltage, the camera must draw quite a bit of current to have the same power as 4-battery or Li-ion powered models. This higher current results in more voltage losses at all connection points, such as where the batteries touch the camera contacts. As a result, this camera is more sensitive than most to battery condition. On top of it all, I suspect the M407 may be a battery hog to begin with.
I've had decent results with both of the following solutions: (1) Use only "new", "good" NiMH rechargeables that have low output impedance, so that their voltage does not drop so much as a function of current. Sanyo Eneloop batteries (white case) are among the best for this camera. (2) Use lithium primary batteries, which have both low output impedance as well as a slightly-higher output voltage. These work very well, but are a more expensive solution because they are not rechargeable. Great for the person who only pulls out the camera every month or so, though, because litium primaries have a great shelf life.
A camera rep told me that use about 2500mi (?) batteries instead of the 900 I was using otherwise the batteries will be depleted with just one picture. Digital cameras or any other digital piece of equipment needs the extra power. Make sure that your charger will charge the 2500 power ones fully.
Hi, I am using HP Photosmart M407. I am having problem while copying or transfering fotos from...
(More)
Hi, I am using HP Photosmart M407. I am having problem while copying or transfering fotos from camera to my laptop. I cldnt able to either see or copy some of the fotos from camera. What might be the problem. I could able to see the same fotos in the camera bt when tried to transfer the fotos I have this problem
I have just inherated this camera and I don't know how to use it, Can I get a manual or is there...
(More)
I have just inherated this camera and I don't know how to use it, Can I get a manual or is there something on line? it is a HP photosmart M407. I would really like some kind of instructions, any help any one
My HP Photosmart M407 digital camera won't upload photos. I've uninstalled and reinstalled the...
(More)
My HP Photosmart M407 digital camera won't upload photos. I've uninstalled and reinstalled the Image Zone software several times. It comes up and freezes.
My HP PHOTOSMART M407 has a broken battery retainer door. Where can I buy a replacement door? Mail...
(More)
My HP PHOTOSMART M407 has a broken battery retainer door. Where can I buy a replacement door? Mail order, please?
