Question about Kenwood VR-7070 Receiver
Constant buzzing sound in all speakers
I have constant buzzing sound in all of my speakers. Everything has been hooked up the same for years and it just started buzzing. Every once in a while the sound will go completely crazy and the volume will spike and be very loud. I turn off the receiver and turn it back on and then it works again but the buzz is still there.
I have tried unplugging everything. Taking the reciever to another room of the house and just plugging in the speakers with no other components connected and there is still a buzzing sound comming out of the speakers .
not sure what to do.
    Scholar:
  • 43 Answers
Sounds like either a transformer or amplifier problem. You haven't reversed polarity on the speaker connections? or changed the speaker sizes, Ohms, ect? Probably a resistor, diode, or condenser in the amplifier causing feedback through the speaker system. It's doubtful both speaker coils went out at the same time. Possible, but doubtful.And you mention that the volume "SPIKES" from time to time. Could be as simple as corrosion on the volume "pot". Basically a Rheostat that allows more signal the farther you turn the knob. If so, you can clean that yourself with a spray product available at any Radio Shack. It is for cleaning electonic components and leaves no residue. You could have this checked at any competant electronics shop, but BEWARE, the "Bench Fee" to test may be more than the value of the system. I would ask what the "bench fee" was to determine a problem, and then what the labor costs would be to repair either a transformer or amplifier with resistors, diodes, capacitors, ect. Electronic equipment tends to "break down" over time and use, and sometimes you can replace a component cheaper than repair. If part of a rack system, then you may want to retain this sub-part and repair may be your choice. I would ask about the fees to test, and the costs of labor to repair, before turning it over. How old is the system?
Posted on Sep 26, 2009
I have a kenwood vr-505 receiver that has a content buzzing through the speakers. I have unplugged everything and hooked it all back up but the buzzing still persists. Is it fixable?
is the buzzing constant frequency
or is it a hum like 50 or 60HZ mains
if its a buzzing like zzzxzxzxzzzzzzzzzz this is a bad connection in the mains and i would turn everything off
and get your supply checked out
Nov 30, 2014 | Kenwood Audio Players & Recorders
Buzzing sound in my car speaker after installing stereo with install kit
That is alternator noise install a 12 volt noise filter inline with the power to the deck.
Jun 28, 2017 | XO Vision XD103 FM and MP3 Stereo Receiver...
Hi, I have a pair of Polk RT1000i powered towers and one now makes a constant loud humming or buzzing sound. It is not hooked up to the receiver. It does it as soon as its pluged into the wall. Any...
the volume on the speakers are too high. try to put make the speakers the master volume(whatever device you plug in into your speakers make that device's volume go all the way up and then adjust the volume on the speakers to what ever volume you desire.had the same problem with my computer speakers
Jan 16, 2010 | Polk Audio RT1000I Speaker
Constant noise from Mirage NanoSat 5.1 System Subwoofer
sounds like an earth fault either with the plug circut or more likely with the power board of the unit.
Jan 06, 2010 | Mirage NANOSAT 5.1 System System
Constant Buzz coming from SX-255r
Power source harmonics. Or its power supply regulation. Check also if input line is touching something.
Apr 03, 2009 | Pioneer SX-255R Receiver
Re: Sony 771 ... constant buzzing sound in background
Sounds like feedback. Check your speaker connections at the speaker and the main unit.
Jun 26, 2017 | Sony MHC-771 Shelf System
Carver pm-1.5 power amp has constant buzz in speakers
carver pm-1.5 power amp has constant buzz in speakers, try removing ground jumper on back
Sep 13, 2008 | Audio Players & Recorders
Buzzing sound coming from speakers
You maybe be able to turn the internal speakers off through the tv's menu...either in the Audio section or in Settings
Mar 15, 2008 | Proview PA-32JK1A 32 in. LCD Television
Buzzing sound
You haven't specified where the buzzing sound is coming from, if it is coming from speakers, changing capacitors in the audio section will fix the problem, especially the filters. Now if it sounds like a hissing sound from back of the tv, the CRT base socket is the culprit. It is an easy thing to fix, and the base is cheap, but make sure you purchase the exact same type of base or it will harm the CRT. Good luck.
Jan 22, 2008 | Samsung TXN2775HF 27" TV
Sound card broken? No normal sound and a constant buzz...
Sounds like you tried everything possible. Based on what you have stated that you tried already I would agree with your diagnosis of a bad sound card.
If this was my Laptop I would be looking for a nice set of USB speakers and Microphone or a headset.
You can either keep the speakers turned down or you may be able to disable the onboard sound through a BIOS setting.
Or even better. Here is a USB sound card with speaker and microphone jacks. Pretty Cheap too.
http://www.wolfcamera.com/product/EP4497467.htm
Jan 06, 2008 | HP Pavilion dv9000z Notebook
Open Questions:
Kenwood VR-7070 Receiver Logo
298 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
