Question about Quantum Fireball Lct20 (QML20000LD-A) 20 GB Hard Drive
Does not show up in my computer when I plug it in and turn it on. Computer says it is installed, but I can not find the drive.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 201 Answers
Same like my previous post. 1st of all, check your PC is it has 2 HD or not, if there are 2 HD then make sure 1 is set to Master and another 1 is Slave or Cable Select. If there is only 1 HD, then have to set it to Master.
After this, enter the BIOS to see whether the PC can locate the installed HD or not.
If it is not, then make sure the HD is connected single with IDE cable (do not share with CD-ROM or the other HD, if it is share the unplug the other 1).
If the problem still then may be u can check the HD either is still functional, find a IDE to USB converter in computer shop and connect your HD to your PC and see either the HD can be detected or not as an external HD. If no, then the worst case show your HD is spoil already.
YBC (/\)
Posted on Oct 07, 2009
How to connect to a pc
Install the software first, then connect the usb and power cables, then turn on the unit.
Here is a section of the installation manual :
Software Installation
1. Do not connect this device to computer yet.
2. Insert the utility CD into computer's optical drive, and then the installation window should
automatically appear on the screen. If the installation window doesn't show up, go to "My
Computer" and browse the CD. By executing the "index.html" file, the installation window
will appear.
3. Click on "Private Folder Manager"/ "Playlist Manager", and then follow the on screen
instructions for installation.
4. After the software had been successfully installed, see [Connecting to USB] for cable
connection.
Connecting to USB
1. Connect the plug of AC adapter to the connector marked "DC IN", plug the other end into
an electric outlet.
2. Connect the USB cable to the USB connector. Then connect the other plug to computer's
USB port.
3. Press the Power switch and then the blue LED will light up.
4. The computer will detect this device and you can start accessing the drive.
Jul 13, 2011 | Argosy HV372T Mobile Video HDD Media...
When I plug in my JFV30 my computer does not pick it up, why and how do i fix this. I am using windows 7
First, unplug the drive. Then download the drivers for that particular flash drive here: http://driverscollection.com/?file_cid=39278936334676929bc3679940f
Once those drivers are downloaded and installed, restart your computer and plug in the flash drive. With any luck it should be working.
Mar 12, 2011 | Computers & Internet
My WD My Book Essential 1TB External is not showing up on 'My Computer'. It was working perfectly in the morning, then when I rebooted my machine it no longer showed up.
disconnect your WD ext HDD. and reboot your computer. then connect again. if still not showing. go to device manager (right click my computer then properties -- click device manager). expand by clickin "Disk drives" category here it will show all the hard drives installed in your computer including your WD ext HDD . if you see yellow sign on your external drive right click and remove then go to Action menu click on Scan for hardware. it should detect and install the driver again. if still the same or maybe its not on the list of Disk drives.. try to change another USB cable .. i hope this will help
Jan 03, 2011 | Western Digital My Book Essential 1TB...
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
My external hardisk is showing in device manager but it is not showing in disk manager
**Turn your computer off, then unplug the USB cable and then the power to the drive. Restart you computer, plug the power into the hard drive, wait 10 seconds and then plug the USB into the computer. This clears the hard drive buffer. See if the drive shows up in disk management. Before formating, turn off your antivirus. **
**1. Test your drive on another pc
2. Check your bios settings
Feb 03, 2010 | Toshiba MK6034GAX (HDD2D17) 60 GB Hard...
I have 3 maxtor 3200 storage units. A few days ago my computer would not start up so after unpluging the 3200 and everything else I got the computer to work again. Plugging in the mouse,keyboard,zip drive...
could be a software issue could be that the when you unpluged them you didnt unmount the drives from the system and now windows is not finding them for this reason the best way to "try" to fix this issue is to plug them in one at a time go into device manager and uninstall them from the computer then turn the computer off unplug the drive turn the computer back on without the unit pluged in turn the computer off again plug the unit in restart the computer this will work on 75% of the drives that can't be seen
Jan 25, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
External drive doesnt show on computer wen i plug
install proper driver for your external device
Jan 18, 2010 | Electronics - Others
Maxtor personal storage 3200 problem!!!
First, try another USB Cable. If that does not work properly then I would suspect the box or the drive has failed. If you just bought it, return it to the store and complain. They may replace it. As for your data?
Now if you want to become techie you can remove the hard drive from the box and attach it to you computer either copy the files back if you do not have them on your computer or format the drive if you have your files. Then put the drive back in the box and try to get a refund or buy a different external. I like a metal box with an AC cord plug. Best of luck.
Jun 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
No icon showing in My Computer for slave HDD
On XP computer install your seagate barracuda 400g. start the computer. when xp is already boot right click My Computer then select manage. When Computer Management dialog box appear click disk management. Look for the drive that is unallocated and format the drive and follow the instructions.
Feb 17, 2009 | Acer Computers & Internet
SimpleTech 250GB External Hard Drive Installation problem
I suspect it's not getting enough power from the USB cable. Might need external power.
Dec 06, 2007 | SimpleTech SimpleDrive 250GB, 7200RPM,...
Quantum Fireball Lct20 (QML20000LD-A) 20 GB Hard Drive Logo
260 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
