Question about Whirlpool GBD307PDS Electric Double Oven
Whirpool double oven shutdown during self cleaning operation and now is completely dead and the top oven door will not open. I have checked the circuit breaker and it is in the closed position and power is coming through the breaker. Any suggestions as to the cause of this problem?
  • 6 more comments
  • sunmanor Jan 19, 2008
    Ran the self-clean cycle, it went through completely, then I came back to see how it was. The display was blank, and I thought it was just me. I checked the breakers, and nothing. Any idea as to what this is? I checked some other places and I think it might be the thermal fuse thing, but I don't know. I'd rather have a clue before I call service......Thanks in I wish I'd left it dirty!
  • Anonymous Apr 14, 2008
    Model 27245 - Went thru cleaning cycle and can't get the door open - help
  • violet_rain0 Oct 22, 2008
    ya i had the same thing happen start the self cleaning oven then no power what so ever, i checked the fuse to see if it was trip n it wasnt, had a handy man out who told me to contact whirlpool, can anyone tell me is it cheaper to have them repair the problem or replace it or is this something i can do myself?
  • Anonymous Nov 10, 2008
    This model has been recalled and you can call Whirlpool service at 866-770-6751 for free repair.
  • Candace Alonzo Dec 22, 2008
    I had three separate problems with my whirlpool double oven. First, about after 2 weeks of using my brand new oven, it had an error message. A repairman came to fix it and worked fine. Months later another error message and a repairman came to fix it. He also mentioned not to run the self cleaning frequently because it can cause it to malfunction. He said wait at least 6 months between cleanings. I did so and my oven shut off during a cleaning cycle about 2 hours into the session. My husband tested the thermal fuse and it was not operating so we are suspecting it is the thermal fuse. As I have been reading the comments it seems that I am not alone. I called whirlpool and they are sending a technician out at their cost for labor and service call. I will need to pay for the part. I will see what the problem is this time and if it indeed the thermal fuse.
  • hawkerb Mar 31, 2009
    Is this the part I need for the thermal fuse? My oven shows something different...but I can not find it at the back of the oven like it says...
    AP3110028 for a model # RBD306PDB7???
  • lbobbi May 11, 2010
    any ideas on where to find the specs to find the thermal fuses? Which fuse is most likely yhe culprit and should be checked first
  • Anonymous Mar 16, 2014
    What could cause this problem?
I had the same problem. Need a ohm meter to check the thermal shut down circuit on the back of the oven and the thermal fuse to the display panel. Need to be carful to shut off the Electric to the oven so as not to zap yourself.
I found the parts I needed at
Posted on Apr 14, 2008
  • 196 Answers
Too bad someone didn't answer this sooner. Caused be poor air circulation in the unit. There is indeed a thermal fuse used in this unit. This problem has been around for a while and no real solution has been found. The closest "fix" is to remove the fuse, turn it around and only hook it down with the screw that faces the panel. The other screw hole is then bent to a 45 degree upward slant. This give the fuse a little breathing room.
Posted on Jan 26, 2008
What can I do for F5-E1 situation
Check this article as the cause could be the control board, the door lock mechanism or the Membrane Keypad!
Whirlpool Oven Common Problems and Causes
Jan 08, 2015 | Ovens
Oven Was Self Cleaning. Bottom Oven Opens Top Oven Does NOt
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jun 21, 2010 | Whirlpool RBD305PD Electric Double Oven
I used the self cleaning for the top oven of my double whirpool Accubake ovens today. It worked fine during the process. But now, after it has cooled down. The panel is not lit up with the clock etc. and I...
There is a non-resettable fuse on the back of the oven that will have to be replaced. The oven will have to be removed from the wall and the back panel removed from the oven to access the fuse.
Nov 22, 2009 | Whirlpool RBD305PD Electric Double Oven
Oven shut down during self clean. Door won't open
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
Aug 21, 2009 | DCS (WOTD-227) Double Oven
Dead Whirlpool Double Oven
This happened to us the first time we used the self-cleaning feature. The repairman said we had to replace the whole electronic panel -- but when he put in the new panel it didn't work either. It turned out he just needed to replace the oven shutdown thermal fuse I believe. We finally got up enough courage to try the self-cleaning again and the exact thing happened. The door is locked and the electronic panel is dead again. So when we get it fixed we will never use the self-clean again.
Nov 05, 2008 | Whirlpool RBD305PD Electric Double Oven
Cleaning cycle failure
Please call KitchenAid/Whirlpool directly and ask to speak to the 'executive management team'
I had this fault for the second time and this time I spoke to the Exec Management team who said they were unaware of this as a common fault. My stove was ‘fixed’ free of charge – the fuse was replaced, again.
Please everyone who has had or is having this problem call again – this problem needs to be fixed, replacing the fuse each time or not using the self clean function is NOT a fix.
Mar 29, 2008 | KitchenAid Architect® KEBS277S Electric...
Cleaned then Dead
nextwave, looks like you have a safety thermostat (TCO) on the back of the oven. Should have a red and red/white stripe wire going to it. If this opens it will cut the power to the display, part number is 316003606. The hardest part of this gig is pulling the oven out to change the t-stat out. Catriver.
Jan 19, 2008 | Frigidaire PLEB27T9DC Electric Double Oven
Oven shut down during Self-cleaning
tde, sounds like your thermal fuse (TC0) opened on the back side of the oven. If this opens, it will shut the oven down. This happens alot during self cleaning on built ins. Sometimes I have to re-route the tco to a different area to prevent this from happening. Your part number is 4451442. You will have to pull the oven out far enough to remove the back paneling and replace the back.
Oct 24, 2006 | Whirlpool RBD275PDS Electric Double Oven
Whirlpool GBD307PDS Electric Double Oven Logo
820 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
