Question about Garden
Start the engine it runs on choke and then dies
I have an echo leaf blowr and it worked perfect until I ran out of gas. I refilled it and now it start easily but will only run if the choke is wide open. if i move the choke to normal it dies or if I accelerate the motor it dies.
  • 148 Answers
Check fuel mixture. Be sure you used the can with MIXED fuel and not straight gasoline. If fuel is OK then check mixture screws on carb (the two that are side-by-side). If no limiter caps present on mixture screws, turn them one-quarter turn (1/4) counter clockwise and try again. DO NOT go crazy with these. If they have limit caps on them take the unit to a servicing echo dealership.
USA Dealer locator found here.
Hope this helps!
Posted on Sep 28, 2009
Backpack gas blower
Monching, You will have to hope there is not too much damage done already from running straight Gas. Empty all straight gas from blowers tank and refill with proper minimum 50:1 gas oil mix. Start blower and run on 1/2 throttle for a few minutes to be sure its going to be OK. If seized, you will have to try and unseize and if lucky it may run if not too much damage internally. You should run a heavier oil to gas mix 32 or 40:1 in an engine that's been seized. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
this is what happens when someone run straight gas in two cycle engine
Fixing seized up echo weed eater
Stihl FS120 Grass Trimmer RAN WITH NO OIL IN GAS Blown Top End
https://www.askmehelpdesk.com/tools-power-equipment/ran-leaf-blower-without-oil-36071.html
Jul 12, 2016 | Craftsman 25cc 2-Cycle Gas Blower/Vac
Hi I have a PB1000 echo leaf blower, I have spark and compression,although there is no primer bulb on this model, so the fuel must have to be vacumed with fuel pump. I used the choke and it still...
Try a tiny spray of Starter Fluid in your machine. If it runs for a second then dies,,,, it would indicate that you have a Fuel problem. Broken gas line of gummed carburetor. Ethanol gas is known for ruining both gas lines and carburetors.
Aug 29, 2013 | Garden
Have Echo PB 1000 leaf blower that quits running when engine gets hot
Issues like this could well be a ignition unit breaking down when it gets hot.
Jan 20, 2013 | Garden
Started PB620-ST yesterday with some difficulty. However, ran until fuel empty. Refueled today, but will not start. Spark at plug ok. Fuel flowing, but seems to overflow into air filter compartment. ...
Sounds like your flooding the engine; I did the same thing. Wait a while to let the gas drain back to the tank. Use your primer bulb once and your choke for only ONE pull; then shut off the choke. Pull start without the choke 2-3 times and it should start.
Apr 30, 2011 | Echo Gas Blower 185 MPH 900 CFM Blower...
Engine starts easy. Engine can only achieve high
eitrher a clogged fuel filter thats in the tank, old gasoline or the fuel pump daiphragm in the carb has hardened
Oct 30, 2009 | Echo Inc. 25.4 CC Backpack Blower
Forgot how tostart it
Ensure you have the correct Fuel / Oil mix for your machine first.
Find the choke knob and turn to the closed position.
Find the Primer Bulb and pump it until it is full of fuel, once the bulb is full give it 3 pumps (If the primer bulb is already full of fuel just give it 3 pumps)
Make sure the ignition switch is in the "I" position and not the"O" position.
Pull start! (should take no more than 3-4 pulls before it fires)
Once it fires it may die instantly.... if so cancel the choke and pull start (should fire again on first pull)
If it does not die and it keeps running, cancel the choke while maintaining the engine's rev's.
Hope this helps.
Oct 12, 2009 | ECHO, Inc. Shred n Vac
I can't get it started. It was my Uncle's who
Tips for starting gas powered garden tools.
1.) Drain old gas and replace with new gas.
2.) Make sure oil/gas mix ratio is correct 50 parts gas 1 part oil.
3.) Pull spark plug and replace with a new one or clean the old one.
4.) Pull start with full choke until engine turns over. Then take choke off.
5.) Pull to start.
It should be that easy. If it doesnt start your problems may require a repair shop.
Aug 27, 2009 | Echo Garden
Echo pb 200 leaf blower want start
Turn on ignition switch, Choke, prime bulb 5 times (or until fuel flows), hold throttle down and pull starter cord sharply until it tries to start, then place choke in mid position pull cord sharply again until it runs then move choke to off when it will allow it.
Also you can go to toro.com then customer care, then manuals and parts then type in model no. and download an owners manual.
Apr 06, 2009 | Echo Garden
Chain saw emitted sparks and now does not start.
Hi
When the engine get warm and die(I suppose)check the spark at the sparkplug.You can let the saw run until it ran out of gas and you will not distroy the engine.Change the sparkplug.
best regards savumihai71
Dec 16, 2008 | Garden
Garden Logo
429 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
