Question about Fuji FinePix A850 Digital Camera
Is this something youve heard before
My digital camera will not turn on. When you hold down the power button and stick it up to your ear you can hear a clicking noise
    President:
  • 2,761 Answers
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Posted on Sep 27, 2009
My Canon SX120 IS digital camera won't turn on. I used it in the morning, set it down on a table, cam back and it wouldn't work. There is no damage. When I press the power button it does NOTHING. Is there...
If you're after a reset button there might be a little hole you can insert a pin into to reset it, look around the camera.
You should also try holding down the power button for a few seconds, it might have a function where doing that does a restart or something similar. Taking the memory card out and turning it on without it is also worth trying.
Mar 05, 2011 | Canon Cameras
Cannot find out how to turn the thing off;it says hold power button down for 5 sec;have done that,still flashes red.
Your button may be sticking or defective. However, an effective way to make almost any Bluetooth headset turn off is to plug it into the charger. Most Bluetooth headsets will disconnect from a phone when plugged in, and when you unplug it most headsets will turn themselves off.
Mar 05, 2011 | LG HBM 730 Bluetooth Headset Wireless...
Hi I have the same problem as a lot of other people with the lens sticking open and the screen saying turn power on and off, with a DSC W150. But mine doesn't sound like it is even trying to open or...
There is probably moisture in the lens assembly. This can prevent the mechanical gears, Iris and lens retractor from functioning. Store the camera in a dry environment for at least 24 hours and try again.
Nov 04, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Canon SD800 will not turn on.
If youve had it under a year you can try sending it back for warranty and see if they can fix it. However their warranty service sucks if its not actually something wrong with the camera. Maybe try and find a local store that fixes cameras and see if they can clean it out?
Jul 14, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
Lens got stuck
It sounds like the lens is now out of adjustment and in order for this to be resolved, you will need to take it to a camera repair shop. I have heard good reports about a company called Ritz Camera. Not much else you can do with it unfortunately.
Jun 09, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Faulty power button finepix
The on/off and picture buttons are run from a little ribbon strip that fits under the main pcb. I have pics to help you. Just click on "THE ONLY WAY I KNOW HOW " In the tips & tricks section for my email address.
Thanks
Apr 09, 2009 | Fuji FinePix A345 Digital Camera
Lens will not re-tract
you need repair lens or change lens ,I can repair or i can sell this part okay
Dec 18, 2008 | Sony Cyber-Shot DSC-P200 Digital Camera
Gmini XS 202s wont turn on properly....
I heard of that problem, it could be your charger circuit and it could be your battery. There's a interesting forum post on this at www.newmp3technology.com: http://www.newmp3technology.com/forum/viewtopic.php?t=700
But here's something else: I'll buy your xs202s if you want.. :)
For a reasonable defect-price.
I have one but the display is broken.
Had no luck trying to find that obscure 2" 128x128 backlit greyscale korean display in the IC-market here in Europe.
Sep 28, 2007 | Archos Gmini XS 202s (20 GB) MP3 Player
Camera wont turn on!!! i hear gears turning
Fuji Technical Support team website is the place to ask for further advice. But if the camera is more than a ear old - replacement is the only remedy.
Jul 01, 2007 | Fuji FinePix E510 Digital Camera
Camera wont turn on...gives beep sounds and green light glows when pressing power button
Does the lens extend in either of these cases? If there has been some malfunction in the lens and it fails to extend the situation can cause the camera to power-off in order to protect itself. Some cameras show error messages before powering off, others do not. Hold the camera up to your ear and turn the power on. Is there a series of mechanical sounds before the beeps? Hearing sounds but not seeing the lens extend indicates some sort of failure in the lens assembly. If you hear nothing then the problem most likely lies elsewhere, possibly a failed electronic component or something as simple as a loose connection. Check with your manufacturer for any recalls or technical bulletins, and see if they will service your camera under warranty. If not there are a number of repair facilitys available on the internet who generally have better rates than out-of-warranty service at the factory. David Millier Advance Camera Repair
Jan 08, 2007 | Samsung Digimax S500 Digital Camera
Fuji FinePix A850 Digital Camera Logo
122 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
