Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Superautomatic esspresso machine problem
My new espresso machine is not working properly. Water does not come out of the brew head. Just a trickle of coffee. I cleaned the machine, changed the grind like the manual says. No luck. Now the digital display reads,"Ventilate". Any solutions? Thank You, Jennifer
  • 1 more comment
  • Anonymous Dec 21, 2007
    how do work this machine?
  • Anonymous Feb 06, 2008
    the coffee is coming out very slow and just a dribble
  • mitkin Feb 06, 2008
    we have cleaned the machine, the water still comes out very slow and it is just a dribble
You will probably find that the small holes in the filter are blocked with grounds of a perfect plug like size.
I carefully removed the filter plates and cleaned them thoroughly on mine and all was well.
Posted on Feb 14, 2008
What can I do to have the Ready to Brew light come on? I tried to slowly pour in water and fill water tank but doesnt work.
Be sure spray disk and brew gasket are properly installed in the
brew head.
Be sure the water supply is properly connected and the water
supply valve is turned
ON
Be sure the WATER TANK IS FILLED
BEFORE plugging the brewer into a receptacle, or otherwise
connecting brewer to electrical power
THE WATER TANK MUST BE FILLED
Place an empty decanter under the brew head. Lift
the pour-over cover then pour warm tap water into the pour-over
opening until water flows from the brew head. When water stops
dripping from the brew head, empty the container.
Once the tank is full of water,
connect the brewer to electrical
power. The heating elements will begin heating the water in the
tank.
When the water has reached the proper temperature, the
"READY To BREW" light will glow. http://www.cdccoffee.com/pdf/bloomfield-8571-8572-user-manual.pdf
May 12, 2015 | Bloomfield 8571 Coffee Maker
Tip
Superautomatic does not make espresso. Dumps dry grounds
Dosage lever or knob is to the max positive and the brew unit can not compress the coffee, so the machine dumps it into the dredge drawer to prevent breaking the machine. Reduce the amount by 1 click towards the minus side, and that should take care of the problem.
PS. It will usually work if the brew unit is clean, but when it is used once it will go back to dumping.
on Dec 17, 2009 | Coffee Makers & Espresso Machines
My saeco xsmall has red light continuously on after rinsing
You have to turn the button to the side where is the icon of the cup.
Then you have to wait until the machine stops running water by itself.
Jun 28, 2014 | Saeco Xsmall Superautomatic Espresso...
Last night I removed the brew head screen to clean it and then screwed it back in. (I did this because it was taking forever to get one shot of espresso). Now I can only get a trickle of water out of the...
HI
It sounds like you didn't get all the parts back in the head. The silicone head with the spring goes in first, then the screw. The spring has to touch the screw. Then the filter screws into the screw plug.
Jan 26, 2011 | Saeco VIA Venezia
After using steamer for milk frothing the red light comes on and cannot get esspresso to brew and no more steam or hot water comes out of the frothing nozzle, the water level is fine in reservior, beans in...
The tap valve is leaking inside the machine needs new seals.If moisture is escaped and hit the printed circuit card on the tap, the machine will stop you from doing other functions.
Feb 05, 2010 | Saeco Odea-Giro Espresso Machine
The espresso coffee is taking forever to fill a
Hi
When you push the water button, how is the flow? If it is OK its not your boiler. What happens when you press the pre-ground button but don't put any coffee in. If it brews correctly( not slow) your grind is too fine. Just push the lever below the bean hopper back 2 clicks. If you are still brewing slow you may have a plug of coffee in your brew head. A pinch of automatic dish washing detergent in the brew unit funnel, then push the pre-ground button again. This can break up the clog and allow a normal brew.
You don't want to use vinegar in your machine. It leaves a taste for a while. Citric acid is what you want.
Nov 04, 2009 | Saeco Magic Comfort Plus Espresso Machine
My Saeco Easy superautomatic machine will not finish the brew cycle. It gridns, tamps, and does not pump water. It dumps dry grounds into the dregs container. I have descaled the machine and lubricated the...
maybe your valve dont open water or your brew unit plugged out.unscrewed two screw on top brew unit and you will see sprin and small plastic ball ,clean inside and try
Aug 22, 2009 | Saeco Easy Espresso Machine
Cafe verona delonghi
You need to turn the knob on top to the steam logo. then turn the knob on the side to open the steam valve. then when you get all the steam you need turn the knob back to brewing
Sep 11, 2007 | DeLonghi Caffe Nabucco BCO70...
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
120 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
