Question about Canon PIXMA iP1600 Printer
I have just had new hewlett packard computer and now printer is only printing very faded photos, also the printouts from internet are v small print although I have zoomed the them on the monitor.
    Sergeant:
    Champion:
  • 232 Answers
What you have to do firstly is to make sure the ink supply is ok
After , when you print photos your printer must be maintained regularely as ink does clog up the nozzles and need to be cleaned to have a decent printing result .
When you print something you have to make sure you select ( out of the printing window the size and view you want . zoooming on the monitor will not help unless you tick " print viewing page "
check all this and see how you go
Posted on Sep 26, 2009
Photo printing
Try, under Printing Preferences, Effects, check settings for "No Borders" or select a higher % of normal size.
Feb 25, 2014 | Hewlett Packard Printing & Imaging HP...
41.2 error hp laserjet 5200
41.2 error hp laser jet 5100
am from Ethiopia but when am check and replace the Formatter board ,beam not working but when am replacing the DC controller and all connecting cables to beam, then it was working god .
Feb 04, 2014 | HP Hewlett Packard LaserJet 5200 Printer
How to print wirelessly from android phone on hp laserjet p1102w
it dependes if you have local wifi where your HP printer is connected.
If yes, you only need to install HP ePrint app.
After you start the app ignore activate printing via hp cloud, you don't neet it. If you are with your Android on the same WiFi your app will identify the printer on the network and you only need to indicate the photo or file. Open it and print. Tha'ts all.
Sep 24, 2013 | HEWLETT-PACKARD Hewlett Packard P1102...
My HP C4640 prints pages of small type not what I select to print.
You might want to try using the HP Smart Print.
Click HP Smart Print to download and use it.
Apr 02, 2012 | HEWLETT-PACKARD Office Equipment &...
Printed pages are smeared with black
Sounds like a bad toner, or possibly the scanner is dirty. If you look where it pulls the paper through it can have a small speck, but since its on the scanner tself it will put black lines all the way down the paper.
If its larger and smeared the Toner itself is probably bad and you need a new Toner Kit, should come with new rollers and a new cartridge as well.
Mar 01, 2011 | Dell 5110cn Laser Printer
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
PRINTING ON PAGE IS VERY FADED AND SOME PARTS NOT PRINTING AT ALL
First, checkthat the USB cable is secure in both the printer and the computer and that theprinter is sitting on a flat surface. The printer may not work if it is tilted.
Next, run a printer check to make sure the printer is operational. To run aprinter check, turn off the printer and the computer and unplug the USB cable.Turn on the printer and press the Maintenance button. Use the down arrow buttonon the printer to highlight More Options on the display screen and press OK.Highlight Nozzle Check and press OK twice. If a page prints out, reinstall theR300 software on your computer.
Lines inPrintout
R300 mayproduce printouts with light horizontal lines that are not a part of theprintout. This is called banding and can have several causes. First, trycleaning the printer head to clear any clogged nozzles. To clean the printerhead on the R300, press the down arrow button to highlight More Options andpress OK. Use the arrow buttons to highlight Head Cleaning and press OK twice.The printer will take about 30 seconds to clean the print head, after which youshould run a printer check as described above. If the printout has gaps, pressthe STOP button to run the print head cleaning feature again. Once there are nogaps in the printout, press OK.
If the printout still has banding, open the Print window on your computer andclick on Properties. In the Properties window you can choose the print quality,speed and printer type. Select a higher print quality and a lower speed andmake sure the paper type matches the type you are using for the printout.
Finally, check that the ink cartridges are not empty or close to empty andreplace them as needed.
Faint Printout
If your printout looksfaint or faded when using the R300, try cleaning the print head. Next, replaceany ink cartridges that are old, low on ink or out of ink. Check that the papersetting on the computer matches the type of paper you are using for theprintout.
Another potential cause of faded printouts is incorrectly loaded paper. Sometypes of paper have a printable side that is whiter or shinier on one sidecompared to the other. The printable side of the paper needs to be loaded intothe printer face up.
Nov 20, 2010 | Epson Stylus Photo R300 InkJet Printer
Hi there. Problem with my HP laserJet 1600. The
please clean up the laser unit. afther that will work just fine. have a great day.
Aug 17, 2009 | HP Hewlett Packard LaserJet 1600 Printer
My hp laserjet 2420 printer won't print out my bottom text of my legal size document. when i preview my print it cuts off all text at 9.5'' . what's wrong? my margin's are all set to 1'' and i customized...
Do NOT use customized paper. Set your paper tray to LEGAL paper. Set the tray as LEGAL in the printers setup-menu. Make sure you choose LEGAL in the printout-dialog-properties. Then it should work. Good Luck.
Aug 14, 2009 | HP Hewlett Packard LaserJet 2420 Printer
Need to enlarge the print on my HP DeskjetD4160 - it's soo tiny
Are you using Internet Explorer, as you brower? If so go tothe top of an open browser window left click on "page", go down to text size and select the size you want. If you don's see "page" click on menu bar, it should open up the options available, there. It's right next to tools. that should do it. Also if you want larger text when viewing websites, click on View, and you can adjust the text the way you want it to look.
Dec 03, 2008 | Computers & Internet
Canon PIXMA iP1600 Printer Logo
old marine
old marine
