Question about Zanussi 24 in. DE6965 Built-in Dishwasher
The Zanussi Aquapulse (de 6965) Fault Code AL3.
The Zanussi Aquapulse (de 6965) dishwasher is not draining the water away at the end of a wash. Fault code AL3. What do I need to do and what is causing this problem? Help!!!!
Eureka! thank you FixYa. My Zannusi de6965 was failing to heat up andf finish the programe and showing Al3 read a number of your contributers and after stripping down the front of the DISH WASHER found my way into the main circuit board and there they were 2 two DRY JOINTS ( where the blue and orange wires connect) cleaned and re-soldered then re- assembled and tested.... Eureka! it worked just fine.Remember to take care when disconnecting the internal wiring from the circuit board. I colour marked each connector block and made a drawing. Thanks again hope this helps.
Posted on Jan 02, 2012
  • 3 Answers
I have this now- another site suggested its the heater, or rater the circuit board. I have just taken it apart and have two dry solder points that are identified quire easily by soot around the area. so now off to find my soldering iron!!
Posted on Sep 09, 2010
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
Zanussi Aquapulse DE6854 dishwahser programe lights not working
hi
got same probleme with my aquapulse 4744 slimline
Oct 07, 2009 | Electrolux Dishwashers
Zanussi ZWF1437W E23
E23 indicates Drain pump faulty; Wiring faulty; PCB faulty.
The service information also says it should stop with the door open.
Unplug the appliance and manually remove the water via the filter or front drain point if it's fitted.
Drain it into a shallow dish, tighten the filter when you need to stop the water (or plug the hose if draining via a hose) while you empty the container.
Once empty, try the door again.
Take the filter out and clean out any debris in it.
Plug the appliance in and put the machine on a drain programe.
Listen/look at the open filter to check that the drain pump is running.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 27, 2009 | Washing Machines
Is my zanussi aquapulse de 4744 dw hot or cold water fed ?
It is more than likely hot water fed. You can trace the line probably to under your kitchen sink and see where the line follows up to your hot/cold on your sink. There would be then another line coming off the hot which would lead to your dishwasher.
Jan 17, 2009 | Zanussi 18 in. DE4744 Free-standing...
AL3
Possibly tge heating element,I am having the same problem .When I check during the operation it appears that the water is not heating up. Only runs the rinse programme without the error message as I assume that uses cold water only?
Nov 21, 2007 | Zanussi 24 in. DE6965 Built-in Dishwasher
Zanussi aqua pulse de 6965
We have AL5 quite requlary. It seems to be related to the pressure of the water going into the machine. I think if it is too high this alarm can be tripped.
There are two main ways we rectify the problem:
1. switch off the inlet water supply. Disconnect the hose at the machine. Let any surplus water drain out (only a couple of spoonfuls). Reconnect and switch on water.
That sometimes resets a sensor inside that relates to the AL5.
2. If the above fails then we remove the panel where the inlet water hose connects to the machine (There are three screws). Then carefully left this panel away from the machine. It will not come right out as it is connected to various bits inside the machine but you can get some access inside. On the left hand side there is a pink pipe with a white stopper on the end. Remove the stopper and let an excess of water out (this might be as much as a cup full). Of course, this must be done with the machine switched off and un-plugged from the mains!! There are electrics inside.
Once the pink pipe is drained, put the stopper back on and reassemble and connect. 90% of the time this works fine.... but the problem does come back.
If it doesn't work after the second procedure has been done then try leaving it over night (with the water inlet switched off) and try again in the morning.
I have experimented with putting the inlet tap half on (i.e. to lessen the flow of water) and that seems to give us longer before the problem returns.
I checked on a site a while back which had suggested that Zanussi were aware of a design problem. Of course, unless cars, they have no recall policy. I have tried to ring them once or twice but have got nowhere. Its hard to tell at times whether you are ringing the right company let alone the right department!!
Aug 24, 2007 | Zanussi 24 in. DE6965 Built-in Dishwasher
Zanussi DE 6965
Hello Russel A L 6 Is Water Drain Time-Out Possible causes are; a) Domestic drain outlet unsuitable (obstructed) b) Motor faulty (pumps group/ drain impeller) c) Pressure switch faulty d) IWMS- Pressure switch tube obstructed e) IWMS- Sump vent hose obstructed f) Control board (Relay interrupt Regards David Marsh
Jun 04, 2007 | Zanussi 24 in. DE6965 Built-in Dishwasher
Zanussi Aquapulse DE6544 not emptying
Zanussi Aquapulse dishwasher - is filled with water inside, is not washing and the lights keep flashing on and off - has anyone any idea what may be wrong with it?
May 27, 2007 | Zanussi 24 in. DE6544 Built-in Dishwasher
Bosch
f is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
Apr 01, 2006 | Bosch 24 in. SHU6802UC / SHU6806UC...
Zanussi 24 in. DE6965 Built-in Dishwasher Logo
990 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
