Question about Futaba Toys
How do I program a Futaba T8UAF transmitter for mixing the rudder and elevator for a dual servo v-tail plane?
5 Suggested Answers
micromend
  • 748 Answers
SOURCE: hi i have a futaba gy401 gyro with a s9254 tail
Hi
If you put the gyro on another helicopter and have the same problem then you'll need to replace it. I've tried repairing these in my lab but just not worth the effort. Good luck
Posted on May 05, 2010
jyackle5
  • 8197 Answers
SOURCE: I think my GY401 is
Yes it does sound like the gyro is bad. I had this happen to one of mine also and I sent it to Futaba and they replaced it for me for free. I recomend that you do the same thing and send it in to Futaba. If you are moving the nose by hand and the servo is not doing any thing that means that it is not responding. I would also recomend you sign up with RunRyder.com It is a world wide helly site and people there will be able to help you out if you are trying to set the heli up for the first time. You also might find someone in your area to fly with. I am on there myself my name there is Jon Y here are my pictures on the link below.
http://rc.runryder.com/helicopter/gallery/27014/
Posted on Apr 20, 2011
  • 133 Answers
SOURCE: Throttle is operating servo on
It sounds like you just got it. Be sure your battery is fully charged. Its probably a "Lipo / ?". They put out very high current but drain quickly. On the larger copters, some functions will work partially or stop completely before other functions when they are low on charge. If its RTF out of the box and you just got, give the battery at least a 3 hour charge and try it again. If that doesn't work then, I would take it back for a replacement. If its not new and we need to trouble shoot, I have a lot of writing to look forward to. I fly an AH-64 attack chopper and a dual tower sky crane. I just finished repairing my crashed sky crane this morning. No more plastic for me. Let me know when you are ready. Today or whenever. We will get it done. Also. you will need a volt meter, small diameter Philips screw driver and a logic probe would be easiest to use if we need to check any PC boards. Good luck with the battery! I'm here if not. Roger
  • 30 Answers
SOURCE: Have a Spectrum transmitter and
its been a while since my rc days but did all the servos operate properly before you installed them in the plane and are they compatible with the receiver also check that you have compatible channels on tx and rx hope this is helpful and i,m not trying to teach you how to **** eggs lol
bob
Posted on Aug 08, 2011
Have a Spectrum transmitter and AR6000 receiver. Cannot bind in a plane. Motor will run; but neither rudder nor elevater will work. Tried 2 receivers.
bob
Aug 08, 2011 | Spektrum Toys
Regarding the BLS452: 1 What is the maximum (electrically driven) rotation? 2 What are the pulse widths for the maximum rotation? 3 What is the current consumption on 6V? 4 Is it digital, & if...
Some of the information you're requesting is at the following link.
http://www.helipross.com/futaba-bls452-brushless-ep-car-high-torque-servo.html
The current consumption will be dependant on the loading of the servo.
Digital Servos give and quicker resoponse to your input and provide a higher torque in a shorter period of time. Full explanation st the following link.
http://www.futaba-rc.com/servos/digitalservos.pdf
Jun 23, 2011 | Futaba Bls452 Brushless Ep Car Hi-torque...
2.4 radio problems
Hi
Call Great Planes service. There number is listed in the front of the Futaba manual.
Jul 08, 2010 | Futaba 7c Computer Radio Air R617fs S3152...
Hi i have a futaba gy401 gyro with a s9254 tail servo, i had a crash and since then my tail servo constantly wags from left to right every time i switch on heli, i have tried putting the gyro on another...
Hi
May 02, 2010 | Toys
Remote control plane not responding to transmitter.
I do not have a solution for this problem, but I have exactly the same problem! Is it a common problem for these airplanes?
Jan 01, 2010 | Sport & Outdoor - Others
Can't get new transmitter working on remote control car?
your receiver is old 89-92 and will not work properly with your newer transmitter. you need a R122JE receiver.
Sep 09, 2009 | Futaba Two Servo Trays For Standard Rc...
Crashed blade 400 repaired it unsure of servo settings helicopter tilts forward and tends to spin around
Try setting gain on Gyro (use small plastic screwdriver) to a straight up and down position.
Set Gyro setting in Transmitter to 75%. NOTE: before turning on helicopter, be sure to center all adjustments on transmitter
Side switch on GYRO to DS and make sure the servo is moving in correct direction. If not. reverse direction with switch on side of Gyro. You may need to reverse the controller of Rudder in settings on transmitter.
This worked for me on my Blade and using the same Gyro on a self build 450 heli.
Helimangler
Apr 20, 2009 | E-Flite Blade 400 3D RTF Electric Mini...
I have a Futaba T9CP transmitter sending to a FP-129DP receiver and on to 6 digital servo's 4 hitec and 2 futaba and they all appear to be delayed in there response to the transmitter movement and they...
have you got any expo dialled into the settings, this will delay or rather soften the response to your servos, the glitching you are getting may be due to you be close to the reciever and swamping the sinal hence the glitching, see if it goes when you walk away from the transmitter
Apr 22, 2008 | Radio Shack (15-2147) Remote Control
Toys Logo
98 people viewed this question
Top Futaba Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Futaba Toy Expert? Answer questions, earn points and help others
