Question about Sony Cameras
My lens will not close. The zoom will not go in our out
    Scholar:
  • 94 Answers
I'm sorry that the camera is not turning ON. Please make sure that the battery is fully charged and there are no dust particles near the lens which stops retracting. Check if you are able to access the Menu. If yes, then, please Initialize the camera under settings 1 Menu. If you are not able to access the menu, you may have to power reset the camera by removing the battery and press n hold the power button for 1 minute continuously. After that leave the button and insert the battery and check if it helps. If the issue still persists, your camera will require service.
Posted on Sep 27, 2009
My Fuji S1500 lens will not go in and out? It reads zoom error
Put a freshly charged battery in the camera. Lay it on its back on a firm smooth surface with a cloth between the camera and the surface. Hold the zoom button in and while holding it in, turn the power on the camera. If the lens moves tun the camera so the lens points down and continue to zoom in and out. That may free some grit or dirt wedging the lens in place. If that doesn't clear the trouble, look closely at the lens and the way it sits in the camera housing. Check to see if the gap around the lens is even. If it is not, gently apply pressure with your hand in the direction of the widest gap. Listen closely for a light snap. If you hear one, the adds are the guid pins snapped back in place and you may now try the zoom. If all this fails there is one more thing to try, but it may result in further damage. if you will probably trash the camera otherwise, try this. Remove the battery. Holding the camera firmly by the edges with one hand with the lens down, slap the camera into your cupped opposite hand several times. Replace the battery and try the zoom. If the zoom works this time, with the lens pointing down, zoom the lens in and out several times to try to let the grit or dirt jamming the lens drop out.
Mar 29, 2010 | Fujitsu Cameras
Is is worth fixing?
infopgdesign,
That's a close call, depending on how bad the housing is broken, there may be lens alignment issues, the adapter ring or the housing body may be cracked, take it in to a shop so they can look it over closely to help you decide if you should send it to Nikon for repair which depending on the severity of the damage will determine the cost. if it's close to what you paid for the lens, save your money and buy a replacement, maybe the VR version of that lens if it wasn't.
randy320sgi
Jan 18, 2009 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G ED...
Zoom lens wont close
Sounds like you broke a lens gear, or it is jammed with sand.
Nov 17, 2008 | Cameras
I just found my husbands old Minolta maxxum 5 AF Zoom lens camera. I don't know how to zoom in. I am trying to take close ups of my infant and it appears that I can only zoom in on objects 4 feet away....
It's not the fault of the camera itself, it's a lens issue. Zoom lenses can only get so close before the min focus is obtained. Unless you have a macro lens (not suited for portraits, which can focus down to mere inches. Most zooms aren't really designed for close focusing though there are higher end lenses that can be less than 1.5 feet.
Hope this helps!
Aug 31, 2008 | Cameras
What does my zoom lens fit?
The lens fits in vivitar, pentax,cosina cameras
Mar 10, 2008 | Vivitar V3800N Zoom 35mm SLR Camera
Digital camara zoom
samsung digitmax d73 zoom lens will not retract, just pull lens outward gently it will click, then turn on camra ,you should be able to zoom now turn off camra lens should return & close
hope this helps
Oct 17, 2007 | Samsung Digimax S600 Digital Camera
Cameras Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
