Question about Toshiba Televison & Video
How do i find out what lamp in need to fix my projection tv
  • 647 Answers
Get the model # of you TV - on the back cover or from your owners manual and reply to this message - I'll let you know the part # and where to get it.
Posted on Sep 26, 2009
I have a 42 inch toshiba 720 dlp hdtv, and it wont turn on. i press power to turn it on, it tries to fire up, the lights under power and lamp start blinkin green, and then orange, but then just stops and...
Tv "LAMP" LED light indication is blinking or lite up?The tv projection lamp insisde this tv now like 1 1/2 or 2 years already?Tv on and used daily like 4 or 5 hours everydays?Yes.The tv projection lamp life are over.The tv require a new tv projection lamp.Still have problems after this the tv board that call the Ballast board it is dead too,must require changing too.The Ballast board only job are to help to fire up the tv projection lamp and keep it lit.
May 01, 2011 | Toshiba 46H84 46" Rear Projection...
When i turn on the tv, it clicks on and the fan fires up for about two seconds then the tv turns off. then the red power light flashes three times, and continues to flash in that sequence. i have a sony...
Did you replaced/ took out lamp from tv to inspect it?
3 times red light flashing shows that lamp cover has not been fixed on tv, lamp cover is first thing that needs to remove to take out lamp from tv.
Please check lamp cover and make sure it is fixed properly on tv.
Thanks.
Mar 28, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Screen black, lamp light is blinking Help,,,, is there a manual how to fix ?
The"LAMP"LED light indication is blinking or staying on.Mean ur tv projection lamp life is over.Require u to change a new tv projection lamp.Try website like Youtube.com type ur tv make and model and type in tv projection lamp replacement.There will have a tutoring video by some body teaching u how to do the replacement of the tv projection lamp.
Nov 18, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
Just installed lamp and tv not working can u help me
Make sure lamp cover has been fixed back in place correctly, lamp cover is first thing that you removed from tv to replace lamp, it should be fixed properly after lamp replacement.
Are you sure replacement lamp is original from Samsung?
Thanks.
Sep 27, 2010 | Samsung HLP5085W 50" Rear Projection...
Samsung TV: lamp out
Yes,tries websites like Tvrepairworld.com,Partstore.com,Ebay.com to buy a projection lamp for the replacement.Tv have "LAMP"indication LED light is flashing or staying on.If the projection lamp on the tv now,been in used 4 or 5 hours a day watching the tv.The projection lamp has not been replace the last 1 1/2 or 2 years on the tv.The projection lamp life is over,require changing.The tv also making clicking noises,the Ballast board also dead,require changing too.The Ballast board help to ignite the projection lamp.
Aug 02, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
I thought i needed to replace my lamp so I did and now the green status light won't stop blinking with the lamp and the old lamp
Make sure to put back lamp cover in its position securely after lamp replacement in tv.
Hope this will help you. Without fixing lamp cover to its place, tv wont turn On.
Thanks.
Mar 31, 2010 | Mitsubishi WD-52525 52" Rear Projection...
How do you remove the lamp
To replace lamp in Panasonic PT-50LC13 tv, please follow this...
1- Place your fingertips under the front cover and pull it from the projection display.
2- Loosen the lamp cover screw using a screwdriver.
3- Using a screwdriver, loosen the lamp unit screw.
4- Grasp the lamp unit handle and slowly pull the lamp unit from the projection display.
5- Put new lamp and fix things in reverse order.
Now need to reset lamp timer as follows,
While pressing the VOL Down button on the projection display, hold down the PIP or SPLIT button on the remote control simultaneously for more than 5 seconds.
When lamp timer will reset, tv sill show "lamp time was reset to 0" message.
Hope this info will help you.
Thanks.
Feb 25, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I have a Mitsubishi WD-52725 projection TV .I replaced the lamp ,but the red lamp light still flashes and the TV does not turn on
the computer in your tv is bad, but someone can fix your problem , just need replace capacitors 1000 to 16 v
Jan 19, 2010 | Mitsubishi WD-52725 52". Rear Projection...
No picture, no sound on my Samsung 56" Projection TV
You probably need to replace the lamp. It's about $150, and if you buy it with the housing, it's a really easy fix, just unscrew and pull out the old one, and pop the new one in. Go here:
www.dlplampexpress.com
Jul 30, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Projection TV - Red Lamp not on
You can get a replacement Red CRT at the following link its used in good working order for 135.00 with free shipping compared to about 375.00 for new if available. The site also provides free step by step instructions on how to do the installation.
here is the link http://servicemanuals.vstore.ca/
Apr 04, 2008 | Televison & Video
Televison & Video Logo
43 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
