Question about Dell 0Y3740 Keyboard
Certain keys are creating double letter combinations e.g. typing "y" yields "hy", "i" creates "ki", "r" "fr", and "o" brings "o9". the shift key has stopped working. replaced batteries. took off key caps & blew out dust. wireless kb and mouse.
  • 70 Answers
I think maybe some of your keys are stuck together. have you spilt something on it or is there a load of debris underneath keys if so just give it a wipe to clean it or blow on the keys to remove debris
Posted on Sep 26, 2009
Left shift key types symbols not capital letters
it could be set to do so in system settings, like a shortcut. or there could internally be something inside under the keys which causes it to do that
Nov 03, 2013 | Computers & Internet
How i can enble function key
HP laptops have the ability to lock the blue special function keys on, making numerical data entry easier on laptop models that do not have the room for dedicated numerical keypads. Because the key combination to lock the function keys is so simple, however, it is easy for those who wouldn't normally use this ability to do so accidentally. When the function keys are locked, pressing certain keys will result in numbers being typed rather than letters. Unlock the function keys to alleviate this issue.
Press the "Fn" and "Num Lk" keys on the keyboard simultaneously. The "Number Lock" indicator light should turn off, indicating that the letter keys will once again type letters when pressed. This combination should work on the majority of recent HP laptops. If it does not, try one of the alternate key combinations in this article's remaining steps. Press the "Fn" and "F11" keys simultaneously, then attempt to type a letter. If the combination does not work, continue to the next step. Press the "Fn" and "Scroll Lock" keys simultaneously, then attempt to type a letter. Continue to the next step if this does not work. Press the "Fn," "Scroll Lock" and "F11" keys simultaneously.
Jan 16, 2013 | HP 4440s Probook
Shift key and certain letters not working on my nx 9420
may be some dust cud be the reason for this..
or may be keyboard problem.. let allow to visit hardware person.
or check wether any typing software is not installed which preventing some keys to work
Dec 22, 2012 | Computers & Internet
I want to change what a key types e.g. the numeral 2 key has the @ sign but you need to use the ctrl key to get it. I want to use the shift key to get it.
Create a shortcut
Open the folder or directory that contains the program you wish to create a shortcut for.
Right-click on the program and click Create Shortcut.
This will create a shortcut named "Shortcut to <your program> in the directory you are in. If you wish to rename this shortcut, right-click the file and click rename.
Once the above steps have been completed, you can copy or cut this shortcut and paste it anywhere to execute this program.
Assign shortcut key to that Windows shortcut
Once the shortcut has been created to assign a shortcut key to that Windows shortcut follow the below steps.
Right-click the shortcut and click Properties.
Click the Shortcut tab.
Click in the Shortcut key box and press a letter. For example, if you press "p" the shortcut key will automatically be made Ctrl + Alt + P. Which means if saved when pressing Ctrland Alt and "P" all at the same time will run that shortcut.
also
http://www.snapfiles.com/get/mapkeyboard.html
freeware
MapKeyboard enables you to remap your keyboard and alter any key to function as a different one or optionally disable it as well.
The program can be quite useful for laptop users and people with keyboards that differ from the standard
hope this helps
Aug 22, 2012 | HP Computers & Internet
How does one access the @ in order to insert it into an email address when one sends an email? Pressing down SHIFT as I press the 2 key results in getting the " sign instead of the @ sign.
Hi, Solution 1: You can change the keyboard layot from the control panel Solution 2: Try the combination Shift+' button next to the Enter or try all the keys with Shift combination and find the @.
Mar 11, 2011 | Acer NSK8458AN Keyboard
How do I combine two word documents into one?
Dave,
Open document #1.
Click [Edit]
[Select All]
[Copy]
Open document #2
At the top of the document, or at the bottom of the document,
Press [Shift] and the [Enter] keys
(hold down the shift key and press enter)
This will insert a "new page"
Now, click [Edit]
[Paste]
[File]
[Save As]
Save the new "double document" with a different name.
*done*
Oct 24, 2009 | Microsoft Computers & Internet
I have a Dell Latitude E6500 and I think it has numerous shortcut keys that I did not define. Thus it zooms in on documents when I don't want it to, creates new documents when I do not want it to, will...
Most programmes utilise keyboard shortcuts.
It says which key combinations will perform which command next to the options on the drop down menus when you click on file, edit, view, etc.
These shortcuts usually a letter key in combination with ctrl key, alt key , sometimes ctrl+shift.
Possibly you are pressing the ctrl key at same time when you press the shift key?
Oct 15, 2009 | Dell Latitude E6500 Laptop
How to reprogram keyboard keys
Use Microsoft Keyboard Layout Creator to create a custom keyboard layout.
It is also possible that you can do some customizing in the software that was delivered with your keyboard
Mar 28, 2008 | Computers & Internet
IBM T40 Keyboard Question
Numlock is the keystroke to fix your problem.
Oct 13, 2007 | IBM ThinkPad T40 2373 Notebook
Dell 0Y3740 Keyboard Logo
265 people viewed this question
Alun Cox
