Question about Samsung CLP 300 Laser Printer
I have a paper jam. How do I open up the back of
I have a paper jam. How do I open up the back of the copier to get it out?
Paper jam
I havent used this model but there's a panel at the back that you need to open, behind the paper tray, in order to remove the paper jam
Mar 16, 2014 | Toshiba EStudio 223 Copiers
Where is this sensor(paper jam 0)?
For this you need to open back pannel of printer starting from page pick roller check the path of paper,check aroud when you'll open back pennel.
Mar 03, 2011 | Xerox WorkCentre 3119 Laser Printer
I had a paper jam. Got the paper out, but now
Some printers won't reset the jam condition until you open a specific door or cover -- even if you've gotten the jam out, they think it's still there until you open that cover. Try opening and closing all of the machines doors and access points, and even pull out the paper tray and push it back in.
If the jam condition still isn't cleared, turn the machine off and back on with the main power switch.
Jul 05, 2010 | Canon PC-940 Black and White Copier
Paper jam message does not clear after paper jam has been removed
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your copier
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the copier
5. Close all doors and put back all trays
6. Turn on your copier
NOTE: Please rate our help to keep this free service online.
Jan 08, 2010 | Canon imageCLASS D480 Black and White...
The printer keeps saying that there is a paper jam, but there is no paper jam! I disconnected it, fiddled with the encoder strip, plugged back in .. still same message.
Try opening up the back of the printer, usually paper jams are visible from the front when you open up your printer, but on some rare occaisions the paper can be stuck between rolling pins and to see that you must open the back of it by where the power cord is
Nov 12, 2009 | Dell 924 All-in-One InkJet Printer
How do you open the printer as i have paper jammed
Hello: Most printers have a door on the back for removing paper jams. Look on the back for a compartment to open and remove jammed paper. Also check for foregin objects in the paper path .
Oct 22, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Giving me jammed paper problem, where as the is no paper jam.
open the back cover there u can see paper exit sensor. that is misplaced . fix it correctly
Jul 16, 2009 | Brother DCP 7010 Multifunction Laser...
Paper will not feed through the printer . . , ''paper jam'' message appears . How can i open the printer to check for a paper jam? I have a Lexmark X83 printer/copier/scanner.
behind the printer there is the tray that can be opened easily to check if the printer is jammed in or the paper feed sensor is stuck up.just open the back tray of your printer and check.
get back if you require more assistance on this.
thanks.
Jul 08, 2009 | Lexmark X8350 All-in-One Plus Photo with...
I have a paper jam in the back of the machine how do you get the paper out?
open the back door,see where paper jam,could be wrapped around fuser.if no jam,fuser or output sensor faulty.
Jul 07, 2009 | Samsung SCX-4828FN All-In-One Laser...
My cannon super 63 image runner 1370f
look on the control panel if there is a diagram of your printer it will usually light up the area where the paper jam is located.
once you find location of paper jam there is normally a green knob in the area of jam that when you manually rotate it will release paper also open paper drawer check for jam or unplug and plug copier back in somtimes this will force paper out as it resets
Jan 13, 2008 | Canon IMAGERUNNER 6570 Copier
Samsung CLP 300 Laser Printer Logo
41 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
