Question about Hand Tools
How to replace blade on keyhole saw
How to replace blade on Kobalt keyhole saw
2 Suggested Answers
  • 509 Answers
SOURCE: How to install new blade in buck Bros keyhole saw
There is a slot at the back of the blade. Bent the blade out enough to clear the notch in the handle and fold the blade down.
Posted on Feb 11, 2010
Need a blade guard for kobalt miter saw 0358938
Fixya does not sell blade guards for Kobalt miter saws.
Oct 11, 2017 | Blade Saws
A Kobalt 10 job site table saw, I raised the saw blade too high, it's now stuck. What to do?
Saw dust builds up around the working componets on the saw, usually a good cleaning is needed and blown out with air, then you can work it lose
Sep 19, 2017 | Blade Saws
Buying a Kobalt reciprocating saw quick lock replacement
Fixya does not sell replacement parts.
Sep 02, 2017 | Blade Saws
I need saw blade safety guard for 71/4 Kobalt Miter saw
Fixya does not sell saw blade safety guards.
Jul 22, 2017 | Blade Saws
My Kobalt miter saw blade does not slide far enough to finish the cut
the turn it over and cut from other side . they only saw so far you know .
Mar 05, 2017 | Blade Saws
Blade wont cut all the way down when cutting baseboard
the maximum cutting depth of a circular saw is the distance from the teeth to the drive washer hub of the saw blade
so on a 7 1/2 saw the effective cut would be less than 3"
if your base board is thicker than that get a bigger saw
it the board is a lot less adjust the cut depth adjustment for the saw base
Nov 19, 2016 | Saws
Kobalt SM2505LW 10 sliding compound miter saw makes grinding noise and slow saw stop
a bearing ,brushes or brake broke more likely the brake mechanism if blade coasts
Jul 07, 2016 | Saws
How do i replace blade on kobalt 12dual bevil miter saw?
I don't know the model of saw you have but they are made for fairly rapid and uncomplicated blade changes as users will change the blade fairly often as they cut different materials.
Some saws have a spindle lock which once engaged means the bolt retaining the blade can be loosened with a single wrench and some saws need the spindle holding with a second wrench which is usually fairly thin, in the order of 3 or 4mm, to engage on two narrow flats machined on the spindle.
The blade changing process is a fairly intuitive one and if you take the time to turn the saw over and observe how it is assembled I think you will soon get the idea.
Feb 03, 2015 | Saws
How do you change the saw blade on a kobalt keyhole saw?
You'll need a flat head screw driver and a pair of protective gloves. This saw resembles a gun. There are 3 key points to review. The first is in the front of the saw, there are 2 pivot points (one sits on top and other is on the side). They resemble dead bolt locks. The second point is in the middle, and resembles a round button. The last point is towards the back of the gun, sand resembles larger dead bolt lock.
Put on your protective gloves.
The change the blade, place the saw, blade side up on a steady surface. With your left hand, hold the saw blade down. Use the screw driver with your right hand and wedge the screw driver between the last point and the blade. Push down on the screw driver to create enough leverage to push the blade forward, past the final point. The blade will shift out of position, beyond the current locked position, and release the blade. It may need a little push, but it will eventually pop out of it's current position. Be careful when it unlocks, my saw blade flew across the room! Hope this helps.
May 16, 2011 | Garden
How to install new blade in Buck bros keyhole saw. It comes with two blades, with the wood blade installed. How do yo remove thw wood blade and install the metal blade?
Feb 09, 2010 | Hand Tools
Hand Tools Logo
534 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
