Question about Canon i860 InkJet Photo Printer
Canon i860 used ink cartridge full error message
    President:
  • 2,306 Answers
When the absorber is full, you need a shop to replace the absorber pads and reset the waste ink counter. In our shop the pads are $19.95 and the labor is $69.00. Sorry about the first stupid answer to your problem.
Posted on Oct 02, 2009
Cannon i860 giving error saying waste ink tank almost full, how can I fix it?
1: Unplug power and USB
2: Open door and hold power button.
3: Connect power.
4: Close door, then release power button
5: Connect USB and an press power to use.
http://social.technet.microsoft.com/Forums/en-US/itprovistaprinting/thread/a1e247a6-52d2-416e-8432-ce3e361a9547/
Hope this helps you.
Jun 19, 2011 | Canon i860 InkJet Photo Printer
We have a Canon Pixma MP280 printer and are getting an error message 6. How do we correct this.Please advise. Thanks!
r u sure that is e6?
There are bunch of error code for canon.
Pls check below and re-list your exact error code and can help you.
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 ? Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error ? USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error1
Apr 26, 2011 | Canon PIXMA MP180 All-In-One InkJet...
Says "Used ink tank full". Light blinks and won't print. No idea how to empty.
It sounds like you refiled an empty ink tank. The printer will refuse to accept ink cartridges that have been used and refilled. Unfortunately there is only one easy option: Buy a new cartridge. If it is a new cartridge and has not been refilled (straight out of the box), contact the supplier (where you got the cartridge from).
Good Luck!
Jun 20, 2010 | Canon i860 InkJet Photo Printer
Color not correct and lines in print
Have you tried the cleaning function? It is usually accessed via the Canon software that you would have loaded when you first installed it on your computer.
See Canon instructions:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=232&modelid=9387&kbpage=yes
Have a look here:
http://www.fixyourownprinter.com/forums/inkjet/59376
and here:
http://www.howtofixcomputers.com/forums/how-guides/canon-i860-print-head-removal-cleaning-210868.html
If you don't use the printer regularly the ink can dry up block the 'very' small inkjet nozzles. Occasionally people have problems when using generic non-genuine ink cartridges, but I have much experince with re-filling Canon ink cartridges and they are much more user friendly then the durabrite ink cartridges used in Epson printers.
Cheers,
Steve
Feb 16, 2010 | Canon i860 InkJet Photo Printer
One of the colors, yellow, on my canon i860 will not print
The Canon i860 holds the cartridges in an ink carrier.
Remove all of the cartridges, making note of the order that they go into the carrier.
Squeeze the sides of the carrier and lift it out.
Place a small amount of rubbing alcohol in a glass dish and dip the bottom only of the carrier into the dish.
Repeat this and see the old ink flow away from the carrier.
Blot the carrier on a paper towel by lifting and pressing it against the towel.
Once it is dry and clean, place it back into the printer and replace the cartridges.
While you are replacing the cartridges, look to see that they have liquid ink in the right side of the cartirsge. If not, replace that cartridge.
Jan 22, 2010 | Canon i860 InkJet Photo Printer
Our Canon Pixma MP150 is showing an error message E5 and previously E3. Can you tell me what these mean please.
here are the error codes for your printer
E2 - No paper (ASF)
E3 - Paper jam
E4 - No ink
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
E8 - Waste ink absorber full, or platen waste ink absorber full «ОК»)
E9 - The connected digital camera / video camera does not support Camera Direct Printing
E14 - The Ink cartridges whose destination are wrong
E15 - Ink cartridge is not installed
E16 - Ink remaining is unknown
E19 - Failed to scan head alignment sheet
E22 - Carriage error
E23 - Paper feed error
E24 - Purge unit error
E25 - ASF(cam) sensor error
E26 - Internal temperature rise error
E27 - Waste ink absorber full or platen waste ink absorber full
E28 - Ink cartridge temperature rise error -
E29 - EEPROM error
E33 - Paper feed position error
E35 - USB Host VBUD over current error - USB
E37 - Abnormal motor driver error
E40 - Other hardware error
E42 - Scanner error
Oct 16, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My Canon i860 just can't print out black words, it's frustrating
pull the ink cartage back out to see if a clear film is not on the cartage??? Check the area by cleaning the ink cartage with rubbing alchole, and also the area that the ink cartage goes into. Use a cotton ball the clean these area with.
Jan 31, 2009 | Canon i860 InkJet Photo Printer
The yellow ink doesn't print although the ink shows full
Hi there! are you using original canon ink cartridges? if so, your cartridge might have defects, try to replace your cartridge with a new one. If you're using compatible ink cartridges try to replace it with an original canon ink cartridge. Have a good day!
Apr 09, 2008 | Canon i860 InkJet Photo Printer
Canon i860 InkJet Photo Printer Logo
191 people viewed this question
old marine
old marine
