Question about Motorola Mobility L6I Cellular Phone
Just bought a motorola l6i,how to download from my pc through cables .how to access file manager from my pc?
Security code of motorola L6i
Motorola L6i Solution.
download the fullflash from this link
https://rs27l32.rapidshare.com/#!download'27tl4'19708271'R3443H1_G_0A.64.19R_PDS001_LP0015_DRM0201_JPJAVA_G_0A_L6_03_00_20R_GSVL6iT678DR03C_1FF.rar'12071'R~389A241D1C262AC27865CC592E190002'0'0
download rsd lite from here
https://rs35l3.rapidshare.com/#!download'35dt'21012706'RSD_LITE_3_5.rar'5835'R~0'0'0
install the rsd lite on your pc and extract the firmware you downloaded with winrar or winzip, remove and insert battery again, press *+#+power all at the same time, you phone should enter flash mode, conect to pc and open rsd, click browse and select the file you extracted, click start and wait till process completes and phone reboots. all will be ok. Note: all data will be lost.
Nov 09, 2011 | Motorola Mobility L6I Cellular Phone
My PC does not recognize my Motorola l6i phone when connected through the USB. cable
  1. Check your Device : Click start - control panel - device manager then look your motorola l6i phone usb if there you look ? not device you must install manual your driver motorola l6i phone if you want your OS read your motorola l6i phone in your computer
  2. Check your cable usb and port conditions
  3. Check compatibel your Phone Driver with your OS your Computer
  4. if you not driver you can download in http://www.gsm-mind.com or http://www.cnet.com
Apr 26, 2010 | Computers & Internet
My motorola l6i is connected to my computer but it is not showing
Go to the following website:
http://motoroladownloads.webs.com
Sign up to enter the site. (It's as easy as 1-2-3)
As a member, you can then download the Motorola Phone Tools (PC Suite) for your PC for free.
**Make sure you download the USB Drivers, too.
The download for the PC Suite is in .zip format. You'll need to unzip it to a new folder. (You can create a new folder on your desktop)
After unzipping the file to the new folder, double click on it to open > locate the >>
Setup884ac5e.jpg icon and double click on it.
This will install Motorola Phone Tools (PC Suite) on your PC.
Start the Phone Tools Program by double clicking on the icon on your desktop.
Download the Data Cable/Modem drivers and attach your phone to your PC with a USB data cable.
(You may also be able to use Bluetooth)
The PC Suite will include all of your options on the left hand side.
Mar 16, 2010 | Motorola Mobility L6I Cellular Phone
How to get the files from my phone
hi..you can get the files from your phone through
the data cable.
try this out..
thank u..
kindly rate my response..
Jun 10, 2009 | Motorola Mobility L6 Cellular Phone
My Motorola l6i not support mp3 file
Whats the size of those file? As far as I know motorola L6i has only 10MB internal memory. probably you dont have enough free space.
free up some space and try again.
Jan 04, 2009 | Motorola Mobility Mobile PhoneTools 3.0...
Motorola l6 connect to pc usng usb (no mobile phone tools cd)
I had the same problem and downloaded the Motorola Phonetools 5.05 from the rapidshare library.
Jan 01, 2009 | Motorola Mobility L6I Cellular Phone
Motorola l6i Mobile Tools installation error
Motorola no longer provides a download of Motorola Phone Tools from their website. Trial version of earlier releases are still available from elsewhere. Download MPT here.
I hope that helps.
____________________________________________
Motorola Phone Tools V4 Manual Download
Motorola Phone Tools V5 Manual Download
Dec 31, 2008 | Motorola Mobility L6 Cellular Phone
Software of motorola L6i
yes..u can transfer any files on both l6 and l6i motorolla...all u nid is to have the driver called motorola phone tools version 4.1 or something...like the one i have...
Mar 27, 2008 | Motorola Mobility L6 Cellular Phone
Motorola l6i
what you can do is go to motodev.com and register then download the usb motorola drivers
Jan 26, 2008 | Motorola Mobility L6 Cellular Phone
Motorola Mobility L6I Cellular Phone Logo
18 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
