Question about Garden
John deere lx188 cutting deck will not engage dont know if both wires to the drive pully should be positively charged .If it is the pully how do i remove it?
  • 389 Answers
With it plugged in to the feed wire coming from the frame, key on, engine off, PTO switch on, you should have power at both wires. With it unplugged, at the wire coming from the frame, one should be 12 volt the other should be ground (no voltage) plugging it in makes the circuit so it would be hot at both wires making a "circle" of electricity through the clutch.
If you have to remove it, you remove the whole thing (clutch, pulley, etc) as an assembly. First remove the belt then take out the bolt that goes through the center of the pulley into the crankshaft of the engine and you should be able to slide it down off the shaft but be careful, it is heavy. You may want to remove the deck to give yourself some working room.
Hope this helps you!
Posted on Sep 26, 2009
F525. Updated mower switch by John Deere is not engaging mower
The John Deere F525, a front cutting machine, has 3 fuses.
20 Amp
15 Amp
10 Amp
Check the 15 amp fuse. I believe this supports the PTO clutch. If you replace the fuse and it blows again, check the electric clutch. You will likely find burnt or melted wires. The bearings do go out on these clutches causing them to run hot and eventually burn up.
PTO Clutch will not engage: There is a very fine one page discussion on evaluating electric clutches at this site:
http://www.messicks.com/Articles/FixingElectricClutch.aspx
My JD tech manual, which covers the entire LA 100 series, agrees with the electrical specifications. It states that the Electric PTO Clutch should show the following:
Resistance 3.7 ohms
Current Draw 3.25 amps
It does not give the air gap.
It does include a note to check the PTO Clutch Key for damage or if missing. So there is a drive key between the PTO Clutch and the shaft. Additionally, it recommends checking the tightness of the cap screw. That's the screw or bolt that holds the clutch on the shaft.
Cap Screw torque 55 lb-ft (75 N.m).
If the fuse blows, I recommend you check the resistance of the clutch. If the clutch is shorting to ground it will show zero resistance when you ohms the connector wire to a ground position. In which case, you will have to replace the clutch.
Fixing Electric Clutches
Other possibilities.
On the F525 there is a cut-off switch in the hydraulic system. It is a low pressure cut off. If you were running the mower and deck and then it suddenly stopped, it may be low pressure in the hydraulics. It will not automatically reset as you are using the same volume for the drive pumps. Once the oil gets low enough it cuts out the deck drive 1st, then the drive pumps.
Apr 16, 2015 | John Deere Garden
Why wont blades stay engaged ?
Check the drive pin in the tractor belt drive pulley. If the pin is broken it will have enough pull to turn the blades slow but will slip when the gas is applied. To repair you will need to remove the drive belt and take the pulley off the drive shaft and get a new pin and reinstal.
Jul 24, 2014 | John Deere Starter Tractor Lx188 Kawasaki...
What is causing my enginge to stall when I try to engage my mower deck?
Check the seat switch it might be disconnected. It will cut the mower off if you leave the seat without disengaging the deck.
May 24, 2014 | John Deere L100 Series
I have john deere lx188 rideon mower when i engage the pto the engine cuts out.
This sounds like a seat micro switch problem, make sure the block connecter is fully home and the switch depresses when you sit in the seat, if all else fails replace the switch
Dec 09, 2012 | John Deere Starter Tractor Lx188 Kawasaki...
John deere lx188 48 deck belt size
Contact John Deere directly to inquire about belt size.
May 26, 2017 | John Deere Starter Tractor Lx188 Kawasaki...
1998 John Deere 325 belly mower 48" deck will not stay engaged.
There is a safety switch on the diferential that lets the tractor know that your not backing up that is likely defective,unplug it until you can get one in to replace it and you should be good to go.It's on th right side mid housing on the hyrostatic unit[rear diff].
Apr 12, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
726 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
