Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
Unable to see Documents & Settings folder
Hi, I am using Windows XP on my PC and have 4 accounts set up. Why can't I see more than just my own 'My Documents' when setting up a backup with my new FreeAgent 250?
The " My documents" refers only to my user account (pete) and if I expand the C: icon it does not contain the "Documents and Settings" folder. As all my Photos are stored under the C: 'Documents and settings' folder along with the other 3 account's 'My Documents' it is essential that I can see all these folders when setting up the backup rules on the FreeAgent.
So my question is, how can I configure the FreeAgent to automatically backup all these files? Regards Pete
    Problem Solver:
  • 15 Answers
I don't know the software, but it sound to me like the other accounts have their documents folders set to private, or you have a limited account.
Either way you should go into user control panel and check the settings.
Start -> Control Panel -> Users
That's all I can suggest at this time.
Posted on Mar 17, 2008
Folders and files missing from My Documents
Hi, assuming you use WIn XP, I suggest the following: Log in as Administrator, browse to this folder : c:\documents and settings\ , you will find folders, one of them is made according to your user name -- now open that, there you will find a "My documents" folder -- now dig that folder and you will get you files. If not that folder!! then , right click on the "c:\documents and settings\" folder - then properties and see the size, from the folder size you can guess your files are where. And the size is very low and your my documents folder was not mapped to any other external storage then manually search you files.
This problem happenz when user profile get corrupted.
Thanks
Feb 10, 2014 | Microsoft Windows XP Home Edition
Tip
How to copy data from a corrupted user profile to a new profile
Create a New User Profile in Windows XP Professional loadTOCNode(2, 'moreinformation'); 1. Log on as the Administrator or as a user with administrator credentials. 2. Click Start, and then click Control Panel. 3. Click User Accounts. 4. Click the Advanced tab, and then click Advanced. 5. In the left pane, click the Users folder. 6. On the Action menu, click New User. 7. Enter the appropriate user information, and then click Create
Create a New User Profile in Windows XP Home Edition loadTOCNode(2, 'moreinformation'); 1. Log on as the Administrator or as a user with administrator credentials. 2. Click Start, and then click Control Panel. 3. Click User Accounts. 4. Under Pick a task, click Create a new account. 5. Type a name for the user information, and then click Next. 6. Click an account type, and then click Create Account
Copy Files to the New User Profile loadTOCNode(2, 'moreinformation'); 1. Log on as a user other than the user whose profile you are copying files to or from. 2. In Windows Explorer, click Tools, click Folder Options, click the View tab, click Show hidden files and folders, click to clear the Hide protected operating system files check box, and then click OK. 3. Locate the C:\Documents and Settings\Old_Username folder, where C is the drive on which Windows XP is installed, and Old_Username is the name of the profile you want to copy user data from. 4. Press and hold down the CTRL key while you click each file and subfolder in this folder, except the following files: • Ntuser.dat • Ntuser.dat.log • Ntuser.ini 5. On the Edit menu, click Copy. 6. Locate the C:\Documents and Settings\New_Username folder, where C is the drive on which Windows XP is installed, and New_Username is the name of the user profile that you created in the "Create a New User Profile" section. 7. On the Edit menu, click Paste. 8. Log off the computer, and then log on as the new user.
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
Tip
An error message informs you that you cannot move or rename the Documents and...
To specify a different folder for the Documents and Settings folder during installation, follow these steps: 1. Run Winnt.exe or Winnt32.exe by using the /unattend option, and then insert the following entry into the Unattend.txt file, where z:\foldername is the path and folder name you want: [GuiUNattended]
ProfilesDir = z:\foldername 2. Install Windows. The path that you included in the Unattend.txt file is used instead of the default Documents and Settings folder.NOTE: This method does not relocate any key Windows components. Use this method if you require only user-specific data to be moved.
After you install Windows XP, to specify a folder other than the Documents and Settings folder for a particular user's data, follow these steps: 1. Identify the user's profile path. You can identify the profile path either by user security ID (SID) or by user path settings. The user SID method is preferred. To identify the user's profile path by the user SID loadTOCNode(3, 'moreinformation'); a. Use the Getsid tool from the Windows Server Resource Kit to obtain the SID. At a command prompt, use the following syntax: getsid \\ComputerName UserName \\ComputerName UserNameFor example: getsid \\windowsxp joedoe \\windowsxp joedoeThe results look something like this: = The SID for account WINDOWSXP\joedoe is S-1-5-21-1708537768-1993962763-1957994488-1003 b. After you obtain the user SID, start Registry Editor (Regedit.exe or Regedt32.exe), and then select the user SID under the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList To identify the profile path by the user's path settings loadTOCNode(3, 'moreinformation'); a. Log on to the computer as the user, and then type set at a command prompt. Note the setting for UserProfile, and then quit the command prompt. b. Log on to the computer as an administrator. c. Use Registry Editor to add the UserProfile setting to the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList d. Click the registry key, and then click Find on the Edit menu. e. In the Find box, type the value of the UserProfile setting, and then click Find Next. 2. In the HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList registry key, change the ProfileImagePath value to reflect the new path that you want to use, and then quit Registry Editor. 3. Log on to the computer as the user, type set at a command prompt, and then verify that the path has changed.
Moving the entire folder loadTOCNode(2, 'moreinformation'); NOTE: This method does relocate key Windows components. Use this method only if you require the Documents and Settings folder to be moved or renamed and you cannot use the Unattend.txt file to change the name during installation.
To specify a different folder for the entire Documents and Settings folder, including key system components, follow these steps: 1. Log on to the computer as an administrator, and then create a new folder. 2. In the current Documents and Settings folder, on the Tools menu, click Folder Options, and then click the View tab. 3. Under Advanced settings, click Show hidden files and folders, and then click to clear the Hide extensions for known file types and Hide protected operating system files (Recommended) check boxes. 4. Click OK. 5. Click and drag all the folders in the Documents and Settings folder to copy them to the new folder, except for the folder for the currently logged-on administrator. 6. Log off and then log back on, using a different administrator account from the one that you just logged off from. 7. Open the Documents and Settings folder again, and then copy the profile of the administrator that you just logged off from to the new folder. This extra step is needed because you cannot copy the profile of the account that is currently logged on. 8. Log off the computer, and then again log on to the computer as an administrator. 9. Start Registry Editor, and then click Find on the Edit menu. 10. Type documents and settings, and then click Find Next. 11. For every registry key or value that contains the original path, replace the value data or rename the value or registry key to the new path.IMPORTANT: You must complete this change in the registry for every instance of the original path, or your computer may not start. It is imperative that you update all registry keys and values with the new path.
12. Restart the computer. You can now safely remove the original Documents and Settings folder.
How to save and transfer favorites with windows XP
Hi dear!
Your favorites resides in the following folder
Systemdrive:\Documents and Settings\username\Favorites
SYSTEM DRIVE: THE DRIVE IN WHICH THE OPERATING SYSTEM IS INSTALLED (NORMALLY ITS C)
USERNAME: the name of the user account whose favorites you want to copy.
if your system drive is C and the uername name is SMB then the address would be:
C:\Documents and Settings\SMB\Favorites
hope answered the question
thanks
Jan 03, 2011 | Microsoft Windows XP Professional
Tip
This article describes how to copy user data from your Windows XP profile to a new profile.
When you copy user data into a new profile, the new profile becomes a near duplicate of the old profile, and contains the same preferences, appearance, and documents as the old profile. If your old profile is corrupted in some way, you can move the files and settings from the corrupt profile to a new profile.
Note The method that is described in this article may not transfer the Outlook Express e-mail messages and address user data that are associated with the user profile where you are transferring data from. When you delete the old profile, you may delete that data if it you do not first transfer it by using other methods. For more information about transferring Outlook Express user data, click the following article number to view the article in the Microsoft Knowledge Base:
MORE INFORMATION
7. Enter the appropriate user information, and then click Create.
6. Click an account type, and then click Create Account.
• Ntuser.dat.log
• Ntuser.ini
on Feb 07, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Access denied to documents and settings folder
The account that you are accessing; is it an Admin account, and now from the very account you are trying to access that account is a limited one, Is that so?
If that is the scenario, then there are ways through which you can get an admin access, but IF those files aren't there or are corrupted, then that is something else.
I'm waiting for your response...
Also get the properties of that account folder and tell me that folder size, to have an idea that is there something in it.
Regards, WAQAR.
Dec 12, 2009 | Microsoft Windows XP Professional
I have a dell latitude d610 lap top
Based on the build of a D610, I am assuming you're running Windows XP. I'm not sure your hardware can support Vista. That model was built before Vista was available.
That said, go to Start-Control Panel-User Accounts. Most likely a setting in there was changed, and my first thought is that it may have been after a Windows Update, in an effort to increase security.
See if the user you're trying to login with even shows on the list. If it does, click on it and change the password to <blank>.
If that user no longer shows then you will have to rebuild the profile for that user. I will caution you that if you have to rebuild the profile, you would want to make copies of the data attached to the old profile. You can do this from Windows Explorer. Start by making sure you can view all files. Then navigate to Local Disk C:-Documents and Settings, then to the folder for that username. Copy all of the folders and files to a safe place, like burn it to CD's or DVD's, or even to a flash drive. Do not save it to My Documents.
Sometimes the fastest way to rebuild the profile is to actually create a new one. Set it to administrator access. Then you can copy the contents of your old user's folders (but not the folders themselves) into the new user's folders.
Here's a recap:
1. Log in as admin or an account with admin permissions.
2. Select the windows START button and click CONTROL PANEL
3. Click USER ACCOUNTS
4. Select CREATE A NEW ACCOUNT. You may need to select pick a task first
5. Type in a new name for the account
6. Click create account and ensure it is an admin account.
4. Press and hold down the CTRL key while you click each file and subfolder in this folder, except the following files: Ntuser.dat, Ntuser.dat.log, Ntuser.ini
Jun 10, 2009 | Dell Latitude D600 Notebook
My administrator account is corrupt and i can not log into it, but luckily i have the guest account turned on but with this account i can not create a new account like an administrator one. so how do i...
Without using 3rd party pay-for tools, I would recommend locating the Windows CD that came with the machine. I would then boot to the CD, and use the Recovery Console option. When you get into the recovery console, you should be able to log in using the administrator password only. This doesn't load the Administrator profile, it just uses the password for permissions reasons. I would then navigate to the Documents and Settings folder (assuming this is XP) and rename the Administrator profile folder to something else. Once you rename this folder, restart the computer, log in as Administrator again, and Windows will create a new profile for the Administrator, and leave your old one alone. Once you're logged in, you can browse to the old profile and get your files and pictures back.
May 11, 2009 | E-Machines eMachines Desktop PC
Windows XP - 'My Documents" missing!
In windows xp there could be multiple profiles.
Check under c:\documents and settings\
Everything in that folder is a user profile. some are system profiles like "all users", "default user", "Network Service" All the other profiles should be user profiles. In each user profile there is a my documents or a user's documents folder.
You should check there to see if you can find your files.
Mar 22, 2009 | Microsoft Windows XP Home Edition
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
95 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
