Question about Kitchen Ranges
My whirlpool range ss630per-1 burners will ignite except of front right which give no ignitor sound at all, but the Rear Right works fine. any solutions?
    President:
  • 1,015 Answers
Each burner control knob has a built-in switch that controls the igniter. It appears the front right burner switch in the knob is possibly defective. They are replaceable but it requires dis-assembly of the range front. Are all the igniters in a sequence? Have you tried turning the front right burner on while another burner has the igniter on. This may let you ignite the burner automatically. When you have another burner igniter clicking try turning on that burner. If the range has rectification igniters that will not work.
Posted on Sep 26, 2009
Testimonial: "exactly what i found, and it works just like you said. the perfect solution. another way is that i just have to turn that knob hard at the end & works"
I have a Wolf gourmet 30" stove. it's about 10
Interesting, I'm looking for a solution to a similar issue. Our new (7 month old) 30'' Wolf Range has this issue. When both front burners are light, the back burner's electronic starter begins to click, but only when you put a pan on the front left burner. I believe the iron/steel in the pan is causing a magnetic field thats starting the rear burner to go off.. just don't know.. will report back after the repair person comes.
Jan 22, 2011 | Wolf Range 18 in. SPR-100 Gas Cooktop
No heat in oven. Burners on stove work fine.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
May 10, 2010 | Whirlpool SF362LXTQ Range
Tappan front right side burner gives out very little flame...
sounds like a ignitor problem or a dirty burner.clean all the holes of the burner and if you could see the oraphas clean that as well.
Mar 06, 2010 | Tappan TGF320 Gas Kitchen Range
The electronic ignitor on front right burner no longer works.
All ignitors should fire regardless of which burner is turned on. See if the right front will light up if you turn on another burner or look for a spark. If not, the ignitor is probably fouled and needs a good cleaning. If the right front burner will spark or ignite when a different burner is turned on, it is the right front control switch - not an easy fix. When cleaning the cook top, if you remove the knobs, any liquid that gets into the switches will short them out. Found that out the hard way.
Dec 20, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Viking with CRAZY Ignitor
Hi there, I am attaching your manual in case it helps you.
On page 53, in the troubleshooting chart, the ninth item down seems to suggest similar 'problems' - including possible 'cause / remedy' to the right in same chart.
The manual includes the manufacturers contact info on page 1 of this pdf (the back page of the manual itself.).
Or, the manual LINK is here:
http://www.vikingrange.com/MEDIA_CustomProductCatalog/m2730059_F20542.pdf
(and attached as noted above). Good luck to you!
(Hope this helps - please click below if so, thanks!)
Apr 29, 2017 | Viking VGIC305-4B Gas Kitchen Range
Top right burner on hotpoint gas range doesn't light
there is a spark ignition in the middle between the front and back burners....one for the left side and one on the right side. When it was cleaned i bet that the spark ignitor was slightly bent towards the front burner...now the gap is too big to fire the rear burner...the ignitor is very similar as the spark made in those push down lighters. so its safe to play around and adjust them as needed to make them work...Go ahead and take it apart and tinker with adjusting it...until you get both front and rear burners running again the way it was before.( peek at the otherside as a reference and try to make it match)
I hope this helps you out a little bit 8-)
Jun 06, 2009 | Hotpoint RGB745 Gas Kitchen Range
Igniter keeps sparking when it is shut off
Remove each of the burner caps from the cook top and wash in warm soapy water, using a plastic scrub brush to clean any grease or film from all surfaces.
So the same with the burner seat and ignitor knob on the cooktop.
The ignitor keeps striking because it cannot sense there is a flame.
Jan 23, 2009 | Whirlpool GS460 Gas Kitchen Range
Burner ignitor will not turn off after the burner lights Viking
replace the electrode that's the wire or pilot tip, it has a sensor built in, when it gets hot it stops automatically. if the electrode is between the front and rear burners, there are small holes on the burners going down on the side of the burner facing the ignition. they need to be clean. try a paper clip and insert the clip in side the holes.
Dec 14, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Replace burner spark ignitor?
Electric igniters are usually very simple installs since they usually only come with a common and hot wire, and the igniter clips on to the burners right near the burner top for ignition. The easiest way a DIYer can do this themselves is to slowly take apart the current ignitor after lifting the top of the range up and taking note of every thing's placement. If you have the direct OEM part, then it either work or will not, based upon the fact that it's either the ignitor or the switch for it that has gone bad.
To test if your igniter has gone bad, remove it completely. (it should only be a small cylinder with two prongs, and two wires coming out the other side) Be sure not to strip any screws as heat from the oven will make them hard to remove. From there, you'll need to jump the connection on the top of the igniter with a conducting piece (ie: aluminum foil or wire), then test the common/hot wires with your circuit tester or volt meter. A solid tone or light means that your igniter is good, and the problem lies somewhere else.
Feb 29, 2008 | KitchenAid KGST307 Gas Kitchen Range
Kitchen Ranges Logo
291 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
