Question about Karcher 2500 PSI Pressure Washer
Water shoots out intake - Karcher 2500 PSI Pressure Washer
Sears dishwasher not cleaning
You may have a bad pump, or the pump intake (inside the bottom tray, under the dish racks) may be clogged with crud from years of dirty dishes.
Jul 31, 2014 | Kenmore km 665.15765692 3376066 Det Latch,...
Bad intake manafold. water in the cylender
a cracked head or, damaged headgasket can cause coolant in the cylinder
Feb 18, 2013 | 2002 Pontiac Grand Prix
2007 yamaha GP 1300R, spout not shooting water out
Make sure that the water intake is clear. I once had a mud dobber build a nest in my intake tube causing low flow.
May 28, 2012 | Water Sport
Why does water shoot out of my window ac. it shoots our of the vents that blow the cool air?
1) Your AC has a VERY powerful blower. 2) The intake air filter is probably really clean (if not recently washed). 3) It is extremely humid... The water is likely condensation on the evaporator (totally normal), but because the air is flowing so well and fast, it doesn't have enough time to drip down.
Jul 20, 2011 | Gibson Thru-Wall/Window Air Conditioner
I prime the pump, and the sprinkler system does not hold pressure. I have also tried to prime the pump from the intake side. what happens there is that the pump actually begins to shoot water back out the...
You can't prime the pump with the same water source you are trying to build pressure in. Shut off all the water going to the house, use the neighbors hose or have several gallons (maybe 5) to prime the pump and continue priming pump until it starts to build head pressure then plug prime hole.
RJ
Jul 05, 2011 | Flotec Corrosion Resistant Shallow Well...
Corrosion around icemaker intake line and water squirting out
The water shoot is the water line on the back of the freezer where your water enters the icemaker. What has probably happened is the water shoot has filled with ice and left enough space for water to spray out. What you will need to do is get a blowdryer and aim it towards the water shoot till the ice has cleared. This should resolve your problem. I hope I have helped you.
Aug 31, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Where are my freeze plugs located on my 1996 gmc yukon? i have water shooting out right under the a/c compressor seems like its coming from inbetween the valve cover and intake
more than likely it wouldn't be the freeze plug but normally the these vehicles leak from the intake or the fitting for the heater hose going into the intake. but as far as freeze plugs there should be one behind the a/c compressor somewhere close by
Jun 02, 2010 | 1996 GMC Yukon
Back - siphoning when the pump turns off.
Make sure you dont put too much sand it will come back out.Put the correct amount and bump the pump correctly.
Jul 23, 2009 | Water Pik Flow Valve Assy. Series II...
Karcher 2500 PSI Pressure Washer Logo
54 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
