Question about Toro Blowers Rake and Vac - Electric Blower/Vac - 51573
Picked up a toro 524 there are some peices missing
Picked up a toro 524 snow thrower there are some peices missing on the carb any diagram of carb
boscia
  • 163 Answers
SOURCE: snow thrower won't throw snow
the problem could be the snow is to heavy for the motor to keep up, if thats the case you may need to upgrade to a more powerful model or try not to overload it. take it a little slower so the motor can keep up. but try tightening the belt. with your pointer finger push down on the belt it should have about a half inch give, if it moves more than that its too loose and probably slipping under load
Posted on Dec 13, 2008
wireguy212
  • 1627 Answers
SOURCE: I was able to start my 5HP Toro but it is running
Try taking off the fuel bowl and check for debris or ice in it.If there is hardly any fuel in it you may have a plugged or pinched fuel line,try blowing back through it[might get a littl gas in your mouth],turn off the fuel and remove the line at the carb and the tank.If niether of these pick up a new spark plug and try that.
Posted on Dec 07, 2009
  • 44 Answers
SOURCE: Toro Max 1028LXE Snow Thrower will not travel.
thank you for the reply. with the belt drive take a ruler and push the belt down you can use your finger as a referance point if you can push it past the half inch mark the belt needs to be tightend you can do that by adjusting the belt tensioner thats done by losening the bolt that holds it in place then moving it so there is no more then half an inch of play in the belt and retightning the bolt. and if the tensioner is at its stops then the belt needs replacement.
Posted on Dec 21, 2009
SOURCE: My toro 1128 OE snow blower wont throw snow the
I have a toro 98 cc powerlite snowblower model 38182 it was running fine one day then bog down and died after that i cant get it to start it has a good fire on the plug plug isnt very wet it pops threw carb once in a while help
Posted on Dec 27, 2009
SOURCE: toro 524 gas leaking out of bottom of fuel bowl,it
There is a "drain" valve on the bottom of the float/fuel bowl--it could have some debris holding it open or a bad gasket. When fuel is not fully contained in the fuel bowl, the engine will starve for fuel-thus the need to run the choke. Take the fuel bowl apart, clean the float-check for holes, and reassemble after cleaning.
Posted on Jan 08, 2010
I have a toro snow thrower 622 that is leaking fuel. its coming from under the unit fast. any ideas to why and how to repair?
a rapid volume leak could indicate a cracked/rotted fuel hose. Not uncommon for a gasoline engine that sits for long periods of time between use. If all hoses seem in order a stuck float valve(needle & seat) in the carburator would also cause rapid overflow of fuel. This willm require a carb overhaul to repair
Jan 07, 2013 | Toro Garden
My toro 1128 OE snow blower wont throw snow the auger turns but the thrower doesnt rotate. Does anybody have any suggestions
Dec 26, 2009 | Toro Lawn Mower With Toro Power Tools
I was able to start my 5HP Toro but it is running rough. It wouldn't start at first so I drained the gas and put in fresh. After several pulls it started. I started it because we are expecting a snow...
Dec 07, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Blowers Rake and Vac - Electric Blower/Vac - 51573 Logo
87 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
