Question about Corvette Chevy Malibu 90-04 Car Radio Wire Harness
Electric power steering - Corvette Chevy Malibu 90-04 Car Radio Wire Harness
    Sergeant:
  • 316 Answers
Electric power steering???? no.
Posted on Oct 18, 2009
Have 2008 chevy Malibu Ltz.past few days the dash will say "power steering "of course wheel gets tight. it's electric..not sure if the pump is going out or if it's the lines..how can someone tell?
The system can be scanned for faults, in the is case you need that test performed. The pump only runs when the computer control unit commands it to run it is on demand, this information comes from sensors in the system..
Dec 11, 2016 | Cars & Trucks
2010 ford fusion hyprid power steering went out
Power Steering - Hybrid The electric power assist steering system consists of:
  • power steering control module
  • electric motor
  • torque sensor
  • rack-and-pinion steering gear
The electric power steering system provides power steering assist to the driver by replacing the conventional hydraulic valve system with an electric motor coupled to the steering gear. The motor is controlled by an electronic control unit that senses the steering effort through the use of a torque sensor mounted between the steering column shaft and the steering gear. Steering assist is provided in proportion to the steering input effort and vehicle speed.
your best bet would be to have the ford dealer check it out !
Dec 02, 2016 | 2010 Ford Fusion Hybrid
Electric power steering works intermitantly
'electric power steering'?
Power steering usually works by oil pumped by a manual pump driven from the serpentine belt. Your sounds like the Power Steering oil needs topping up. Make sure you use the correct ATF fluid as there are different types. It will be written on the cap of the Power Steering reservoir.
Apr 14, 2016 | Cars & Trucks
How to add power steering fluid on a Pontiac g6 2006
It may not have Hydraulic Power Steering , could be Electronic Power Steering .If you look up under the dash under the steering column an see a electric motor on the steering column, well then you have electric power steering ! If hydraulic look at the driver side of the engine , it runs off the cam shaft ! GM had a recall on the electric power steering a few years back ! Good luck ,hope this helps you out .
May 15, 2015 | Pontiac Cars & Trucks
Where is the fuse location for electric steering for 2005 Saturn Vue
The power steering fuse is part of the ignition fuse, it uses power from ignition to engage power relay system on steering column next to the electric powersteering motor. Check the two wire port for ground and power with vehicle running. Mostly all saturns with electric power steering are all under a safety recall, with free replacement.
Feb 27, 2015 | 2005 Saturn VUE
Power steering failure
I would have the power steering system tested, it is a possible steering rack issue.
Jun 02, 2017 | Volkswagen Cars & Trucks
WHAT IS THE AUTO MAKER PREPARIRED TO DO ABOUT POWER STEERING GOING OUT ON THEIR VEHICLES ? NO RESEVOIR FOR POWER STEERING FLUID , WHEN THEIR BOOK SAY THERE IS A PLACE FOR POWER STEERING FLUID !!...
This vehicle could have come with two different types of power steering ! One electric an the other hydraulic needing power steering fluid .
If your vehicle has no power steering fluid reservoir it has electric power steering .
Power Steering System Description and Operation (Electronic Power Steering)
Power Steering System Description and Operation (Hydraulic Power Steering)
An they did have a recall for the electric power steering !
Electric Power Steering
https://www.usatoday.com/story/money/cars/2014/03/31/gm-recall-steering/7127117
May 28, 2017 | 2006 Chevrolet Chevrolet Malibu MAXX LT
I need to put steering wheel fluid for my 05 chevy equinox don't know where to put it in. Can someone please help me?...
2005-2009 models used electric power steering assist exclusively. There is mo power steering pump, reservoir, or fluid on these models. Instead they use an electric motor mounted to the steering column to provide steering assist 2010 models still use the electric power steering on the four cylinder models but also use a conventional hydraulic power steering on the v-6 models. If you have no power steering assist check the 60 amp main fuse for the power steering in the under hood fuse block if that is o.k. You will need a scan tool to find out what is wrong with the system. It is not uncommon for the electric motors to fail or for the fuse to blow while jump starting the vehicle.
May 30, 2011 | 2005 Chevrolet Equinox
Where is the steering pump on a 2006 chevy Mailbu
THAT YEAR THE 2006 MALIBU HAD THE ELECTRIC POWER STEERING CONTROLLED BY A ELECTRIC MOTOR.YOU WONT SEE NO POWER STEERING PUMP ON VECHICLE. IF YOU CHECKED ON VECHICLE NEAR ALTERNATOR SEE NO POWER STEERING PUMP OR NOTHING THAT SAYS FILL WITH POWER STEERING FLUID MORE LIKELY YOU HAVE ELECTRIC POWER STEERING UNIT.
Nov 28, 2010 | Chevrolet Malibu Maxx Cars & Trucks
Low power steering fluid in a 2006 pontiac torrent
YOU DONT HAVE POWER STEERING PUMP FLUID RESERVOIR ANY MORE INSTEAD.YOU HAVE ELECTRIC POWER STEERING ASSIST MOTOR.
Jul 25, 2009 | 2006 Pontiac Torrent
Corvette Chevy  Malibu 90-04 Car Radio Wire Harness Logo
96 people viewed this question
Top Corvette Car Audio & Video Experts
Frank Mangiapane
Level 1 Expert
xxxxxx xxx
Libran Moreno
Are you a Corvette Car Audio and Video Expert? Answer questions, earn points and help others
