Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
I have a husqvarna riding mover it will start but you put in gear it wont move!
    Problem Solver:
  • 5 Answers
It is probably the rusty disengage valve lever on the top of the transaxle. Spray with rust eater and lube with grease. You can get to it be removing the hitch plate.
Posted on Oct 01, 2009
Mover sometimes does not move and other time moves real slowly
ck belts that run hydraulic pumps for tire drive , it might have slipped a bit with chain caught , now belts skid instead of transferring power to pumps , also these pumps might have a manual pressure relief reset , I was thinking they only used them on bigger units , but you might have one as well ,hey its possible , this will need to be reset prior to continuing mowing (refer to manual for location )
Jun 23, 2015 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
Pedal is free- mover does not move
Two possibilities to look for.1. The linkage may have lost a connecting pin. Follow active rods from pedal to control arm on transmission. 2. There is a disengage rod to allow the machine to be pushed without the engine running. If this is in the disengaged position the transmission will not drive. Look at the rear and low down for a lever or rod which is connected to the transmission.
Sep 28, 2014 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Castlegarden TCR 102 mover wont get into gear
Hydrostatic or geared transaxle??
Mar 28, 2014 | Garden
Husqvarna not charging properly
you need to check the connections on all the plugs sounds like one is loose
Jul 03, 2012 | Husqvarna Garden
White smoke coming out of front of Husqvarna riding mower
it might not have been over filled with oil i have seen many needle valves not seating in the carb the gas over fills the carb and drains into the crank case thinning out the oil and if not caught in time i scores the cylinder wall
Jun 02, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
MY TRANSMISSION IS VERY WEAK, MOVER WILL SOMETIMES STOP, WONT MOVE, OTHER TIMES IT WILL CREEP ALONG. ITS ONLY HAS 300 HRS ON IT.
noted for frequent failure of hydrostatic transmissions, just search this site. you have to buy another transmission or lawn mower.
Sep 01, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
My 42" Husqvarna (model #917.279240
Remove the center dust caps from the rear axles, start the tractor up and put it in gear and observe the axles, if one of them is spinning freely inside the wheel, you have lost the 1/4" square key that pins the wheel to the axle. Replace the key and you can go back to mowing. Hope this helped Tim
May 15, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Riding mover 42" deck, clogs
Wet and or excwssively high grass? Blades sharp?
Apr 21, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Will not move forward or back
either the drive belt which connects the crank shaft pulley to the top of the transmission pulley has failed, or the hydrostatic transmission has failed. the first is easy to spot, a broken belt, and fix; the second problem basically means you will spend more to buy a new transmission than another mower will cost.
Mar 29, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
253 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
