Question about Foxconn C51XEM2AA-8EKRS2H (0683562100229) Motherboard
No boot up or bios or image after installing the new mother board, Mr Bogdan
After I installed MB and all connection are made. No image or any boot up or bios displyed. I assumed ther is/are mistake/s or any other thing. Could you please help me.
Brand new board? Unlikely to have a problem. Are you sure you connected the small 4 pin power supply connector to the motherboard as well? (besides the main supply connector)
If you have any IDE drives make sure you have not reversed the orientation of the cable.
Regards,
Anand
Posted on Dec 17, 2007
Installed pentium d 940 duel core. Will not boot. need solution
Assuming the new processor is compatible with your MB there are several things to check. Do you have jumpers on your MB to identify different processors? Can you get to the BIOS with the new chip installed. There are several settings in there that could affect your boot process. Lastly, is your BIOS compatible with the new processor?
Feb 20, 2013 | Intel Pentium D 940 32GHz 800MHz 2x2MB...
TOSHIBA SATELLITE l.305 6050A2170401-MB-A03 NEED INSTALLATION GUIDE/HOW TO CLEAR CMOS UNABLE TO BOOT/RESET BIOS CLOCK
well this is not too much difficult ...1) go to bios and reset factory defaults ( i believe u know how to get access in bios ) 2) unassemble your mother board ... you will find a battery ( which we technicians call cmos battery) ..remove it and then insert it ( take 2 mint break)...
Jan 28, 2013 | Computers & Internet
Mother board p4msoo-m4
Hello download the manual here:
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=246#dl
You need adobe reader, to read content.
Look in the bios setup, for proper boot settings for the drives.
Good luck
Nov 04, 2012 | Biostar P4M80-M4 Socket 478 mATX MB with...
No video at all, no boot, unable to get bios boot setup, green light comes on but no boot, even with a FDD boot disc. Disconnected HDD and inserted boot FDD, no joy. M/B Asus A8V
Hi,thanks for using fixya,
Switch off the computer and open pc cover.
First check the ram, clean by eraser or with solvent and install again ,if the problem same install thre ram to another computer either it damage or not .If the problem is same change ram.
http://en.wikipedia.org/wiki/DIMM
http://www.pcbuyerbeware.co.uk/RAM.htm
If same as before, remove the cmos battery or clear the cmos jumper and hold " on off "switch for 40 seconds. Install battery again and start pc .
Now please check the "smps" by another new or by your "smps" to another pc to confirm either it damage or not.shibuda_44.jpgshibuda_43.jpgshibuda_42.jpg
http://site7.way2sms.com/jsp/Main.jsp?id=6BEFB035C72C9BC7795F7E8D4A2E60B9.a403
http://www.playtool.com/pages/psuconnectors/connectors.html
If same as before now please take a risk and ready to chip label repair,
1.Change all the capacitors, beside the processor, with the help by nearest technician.
2.Set an identification Mark, on the bios chip, by the permanent marker because you need to remove and install it.It could not be possible for all mother board .
3.Remove bios chip from base , clean with solvent and install it proper again.
4.For Intel mother mother ,install a flopy drive and switch on the power and,follow the flopy drives "led light", either it glow or not.
If the flopy drives led light on,download bios filre for your intel mother board ,paste on flopy.follow the bellow link for download.
5.Now don't switch off your motherboard at the time of updating the bios,so please use an ups,and insert the flopy, along with bios file.Set the cmos jumper in recovery mode( just change the normal position ),and switch on motherboard, hope, through this proceses, should recver the mother board.
If the problem is same, I will recoment you for new motherboard.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 24, 2011 | ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
I HAVE PUT NEW AMD MOTHERBOARD. BUT I MADE SOME MISTAKE IN BIOS SETUP. NOW THE M/C IS NOT BOOTING
If the BIOS was not over written or flashed, when the system trys to boot press the F1 key or ther right ket to enter the BIOS and choose default setting and save and exit.
Sep 28, 2010 | AMD Sempron 2800, 2.0 GHz 2800+...
My mother board is D915GEV when I connect inno3d Geforce 9400GL 1 GB video card to PCI-E slot and start my computer then computer does not boot neither it turn on the monitor. But in the same system if I...
It is possible that the 9400GL is not compatible with your motherboard. Might be possible that the max video memory is 512MB.
Maybe a BIOS update can solve this.
Sep 21, 2010 | Intel D915GEV Motherboard
Asus mb wl300 amd 64 4000+ won't boot to bios.
To make sure it isn't anything else, pull all cards, and drive cables from the board so the only thing left connected is the power connectors to the motherboard, the speaker, and the power button. Pull all the ram cards.
Now power up the computer. If you hear a series of beeps then the computer recognizes there is no ram on the board. At this point I would take the power supply out and have it tested. If you do not hear a series of beeps I would still have the power supply tested as it could be the 12v is fine but the 5 and 3.3 volt side is bad.
If power supply tests good then I would replace both the motherboard and processor. You take a risk of burning a new processor if it's the motherboard causing the problems.
Jan 08, 2010 | ASUS Computers & Internet
Gigabyte ma-770t-ud3p won't boot into bios.... is this adead board
There are several things you can check before declaring the MB dead.
1. Check the ram (is it the right kind for this MB? Is it in the correct slots?
2. Check ALL ribbon connectors Make sure all are connected firmly.
3. Check the power output on the power supply.
Make sure it supplies the MB with voltage it requires.
4. Unplug ALL cards and peripherals. (This includes any USB device)
Leave only monitor see if it boots into the bios at this point.
If it does, usually means SOMETHING is clashing.
Turn off, plug in one more device and test again.
Keep going like this until something causes it t fail again.
Does not boot, You just found your problem. :)
5. Check under the MB for any loose screws etc.
Something could be shorting the MB, preventing the bios to boot.
6. Last resort check/replace CPU with known working one.
If all this fails, consider your MB dead. :)
Good Luck!
Hope this helps!
Nov 26, 2009 | Intel Motherboard
My computer won't load...when you turn the computer on all you get is a black screen with a white blinking line in the corner. even if you press f8 while you're booting, it still does the same thing. I can...
The problem could be a damage to the MB by excessive heat produced by Nvidia GPU. The only way to fix this permanently is to take out the MB and reflow the GPU with heat. You can find a video on youtube how to do it. You must take out the piece of gel between GPU and cooling unit and replace it with copper bar or penny made prior 1983 - still made out of copper. Also clean the fan. Use heat transfer paste like arctic cool - not a glue, on both sides of the penny. Install win7. Win7 does not use the coprocessor and will help to ran the notebook cooler. Install speedFan 4.40 - free utility to see what the temp is of your GPU and CPU. If you did good job it will stay around 55C. If your HP notebook is still running check the temp. If the GPU is running 80C or more it will melt the connections on the MB and quit working sooner or later.
Oct 16, 2009 | HP Pavilion dv6000z Notebook
Foxconn C51XEM2AA-8EKRS2H (0683562100229) Motherboard Logo
280 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
