Question about Jenn-Air JGR8875QDS Gas Kitchen Range
Oven won't work and the touch pad is diplaying "off"
  • 725 Answers
First try a Hard reset...
find the house breaker panel find the oven breaker should be a double 40 or 50 on it .. turn it off for 30 sec than back on....
let me know for it help if NOT please let me know and I will be glad to do more in depth.
Posted on Sep 26, 2009
After cooking my whirlpool Electric Range started to beep and shows EO F2. The range top is working ( and range top controls ) but the oven won't shut off and the controls are not working for the oven.
Here is what my online service manual for the F2-EO error code says
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock)
I hope this helps
Gene
Aug 01, 2011 | Whirlpool Kitchen Ranges
Touch pad for the oven does not work
eith touch pad or control board un plug the touch pad if it returns the board is bad if it dont the touch pad is
May 27, 2010 | GE Profile JTP56 Electric Double Oven
My oven keeps beeping & it was flashing F5 but now nothing is on the screen & oven won"t turn off.
depending on the make of your oven, it could be a door latch failure, or a stuck touch pad button.
if the door latch it wont heat when you put the unit to bake.
if the touch pad button, then you wont be able to program the controls.
Jan 10, 2010 | Ovens
F7 error on GE eledtric oven JKP20
This is a shorted touch pad. replace the touch pad or, if the touch pad is incorporated within the control board, replace the entire oven control board.
Jun 25, 2009 | GE JTP20 Electric Single Oven
Oven touch pad not working properly.
Hi. this will only get worse. i would replace this defective touch pad asap if possible.
Jun 23, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Touch pad does not work, clocke does, nothing else works
Hi this will happen when the touch pad circuits become unstable and damaged, due to abundant usage or , old age.
simply replacing the touch pad will fix this issue.
May 30, 2009 | GE JVM2070 Microwave Oven
Oven not working Message E0-F2- showing
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&&&
Apr 20, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Maytag gas oven touch-pad control panel does not work proplerly.
you can replace touch pad and not very hard to do,you may want to replace control board also.
Mar 12, 2009 | Ovens
GE JKP27WP1 Built-In Double oven - the start button on the touch pad doesn't work. Everything else works fine. Haven't received an error code.
Try gaining access to the touch pad and, try to free up the start button. if this is unsuccessful, replace the touch pad.
Dec 16, 2008 | GE JKP27 Electric Double Oven
Kitchenaid Oven won't work E0 F2 on the control pad
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
Jul 24, 2008 | KitchenAid KESC307 Electric Kitchen Range
Jenn-Air JGR8875QDS Gas Kitchen Range Logo
148 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
