Question about Fisher and Paykel GWL11 Top Load Washer
Leaky washer. After every wash,it doesn't matter 1/4,1/2 or 3/4 load,I get cup or so of water under the washer on the floor.I've checked the hoses,all secure.Is there a seal somewhere I need to check? Thanks,Craig
  • 1 more comment
  • WETSOX Feb 18, 2008
    GWL LEAKS MORE THAN A CUP OF WATER. LEAKS DURING THE CYCLES, MACHINE IS LEVEL- AND EVEN LEAKS WHEN TURNED ON, LOW WATER LEVEL- NO CLOTHES IN WASHER.
  • joke40 Jun 06, 2008
    my washer leaks. its leaked for a few years now. However it never leaked before we moved. do you have any advice
  • Anonymous Jun 19, 2008
    I am having the same problem. my washer is 5 years old and leaks from the bottom. we have look at all fitting and all are OK...how do you fix it?????
    AG
Perhaps you could tilt the machine and unscrew the motor's rotating part. The plastic nut turns counter-clockwise to undo (i.e. normal), should only be hand-tight.
Then when you look at the motor coils, do you see water?
Is there water in the 'webs' of the tub base above? If so, is the water in just the web that has the drain hole at the top? That is the drain hole for the shaft seal, just above the bearings. If it leaks there, it suggests a faulty/mis-fitted seal, or that the shaft is worn after thousands of washes.
Otherwise, refit the motor rotor and check that the drain pump (next to it) is clicked into place properly. It twists and clicks to lock.
-Alex
Posted on Jan 17, 2008
I have an LG front loader. It washes fine, drum is clean ... no smells in the drum. After each load, I have a huge bowl of water that I have to get out of the little black hose (left side bottom). It...
There will normally be a few cups of water left in the hose although it should not smell very bad though as this water from the last rinse and should be fairly clean. If the drain is connected to the drain under a sink make sure the hose goes up as far as possible then down to the washer.
Apr 19, 2010 | LG WM-2277HW Front Load Washer
Water is pooling in the front of the top loading washing machine
If I got the issue correct the washing machine is leaking specially from the in front of your top loading washing machine.
Leaking water from a washing machine usually comes from hoses or connections. Be sure that water appearing to be a leak isn’t drain water from a backed-up standpipe. To prevent potential flood damage, which can occur if washing machine supply hoses burst, be sure to install “no-burst” stainless-steel mesh hoses and lever-type shutoff valves, as shown below. With these, you can easily turn off the levers for both hot and cold water between wash days.
1) Check the fittings where the hoses connect to the faucets and to the back of the washing machine. Also look for worn or leaky hoses. Tighten couplings or hose clamps if needed, or replace the hoses altogether. Be sure to turn the water off before removing the hoses, and drain them into a bucket after disconnecting them.
2) Determine whether the machine is overwashing, which can cause the machine to overflow. Reduce suds by pouring 1/2 cup white vinegar in 1 quart water into the washer. Then switch to either less detergent or a low-washing variety.
3) The machine may have a faulty basket gasket or tub seal and bearing that must be replaced; in this case, call an appliance repair person.
Thank You for contacting fixya.com
Oct 12, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Water was leaking out of the machine. My husband
Oct 12, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washing machine is leaking while filling and before rinse
2) Determine whether the machine is oversudsing, which can cause the machine to overflow. Reduce suds by pouring 1/2 cup white vinegar in 1 quart water into the washer. Then switch to either less detergent or a low-sudsing variety.
Oct 12, 2009 | Kenmore Elite 45986 Front Load Washer
Leaks behind the ciment cast
Oct 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
It is leaking under the washer tub
appliance repairperson.
Oct 12, 2009 | Washing Machines
Washer leaks from somewhere inside
Oct 12, 2009 | Kenmore 22422 Top Load Washer
Leaking water out of the bottom
Oct 12, 2009 | Frigidaire FWS833A Top Load Washer
Leak at the bottom of front door
Leaking water usually comes from hoses or connections. Be sure that water appearing to be a leak isn't drain water from a backed-up standpipe (see HERE for information on clearing clogged drains).
NOTE: To prevent serious flood damage that can occur if washing machine supply hoses burst, be sure to install "no-burst" stainless-steel mesh hoses and lever-type shutoff valves, as shown in the illustration. With these, you can easily turn off the levers for both hot and cold water between wash days.
1) Check the fittings where hoses connect to the faucets and to the back of the washing machine. Also look for worn or leaky hoses. Tighten couplings or hose clamps if necessary, or replace hoses altogether (be sure to turn the water off before removing hoses and drain them into a bucket after disconnecting them).
2) Determine whether machine is over-sudsing during wash loads-- this can cause the entire washing machine to overflow. Reduce suds by pouring a mixture of 1/2 cup of white vinegar and 1 quart water into the washer. Then switch to less detergent or use a low-sudsing variety.
3) Call a repairperson. The machine may have a faulty basket gasket or tub seal and bearing that must be replaced
Please rate this solution
RNJ VINODKUMAR
Oct 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
Mar 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
49 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
