Question about Canon Office Equipment & Supplies
My MP830 will not feed the document through the ADF to copy. I have to lift the cover and push the rubber wheel on to the document, then it will feed it in. Otherwise the copier works fine for all other printing Thanks, John
  • jkidless Sep 26, 2009
    Hi, I probably wasn't clear enough. Blank paper feeds properly. It is when I want to scan a document to copy it. The Automatic Feeder will not pull it through to scan and copy. I can lift the lid and place the doc. on the glass to scan and copy.
    President:
  • 3,278 Answers
Hi, John.
First, check all the areas of the ADF to see if anything is stuck. Lift up the ADF cover where the "Grasp" point is located. It has a snap on each side to keep it locked in place during normal operation. Check all the rollers for any kind of paper jam or look for any roller that looks out of place. Carefully rotate the rollers if you can, and see if they turn up more bits of paper. They may not rotate so don't force them. If they appears sticky or dirty, use just a damp wash cloth and wipe them off. Try and clean the full feed roller. Check the paper position sensor and verify that it can easily move and can detect paper in the ADF.
If still a problem, here are the instructions to clean the ADF.
Source: MP830 Service Manual.
Follow this procedure:
1. Connect the power cord, and power on the machine.
2 Remove any paper from the Auto Sheet Feeder and Cassette.
3 Select the paper source with [Feed Switch].
4 Press [Menu] repeatedly until <3.MAINTENANCE> appears.
5 Use [Right cursor ] or [Left cursor ] to select <ROLLER CLEANING>.
6 Press [OK].
The machine starts cleaning the roller.
7 When cleaning has finished, repeat steps 3 to 6 for a total of two times.
8 Load A4- or letter-size plain paper in the Auto Sheet Feeder or Cassette and repeat steps 3 to 5 an additional three times.
Once you get this done, try to copy 2-3 sheets of blank paper.
If still a problem, take the ADF apart very carefully. There is a small hairpin-like wire that may be disconnected from one of the gears. Reconnect the wire.
Hope this helps.
Posted on Sep 27, 2009
    Brigadier General:
  • 3,513 Answers
Clean The Paper Feed Rollers Using The Unit's Operation Panel
If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit.
It sounds like there may be a mechanical issue with the back loading tray. I suspect a missing piece possibly. Unfortunately, I think you'll need to take the printer to a certified Canon tech to repair/replace parts.
Thank You for contacting Fixya.com
Posted on Sep 26, 2009
What is an adf cover
ADF cover refers to the Automatic Document Feeder cover. The ADF feeds your originals to the copy glass. The cover is opened to remove a jammed original. Just make sure the cover is closed.
Feb 20, 2015 | Office Equipment & Supplies
I have a message on screen sayng " ADF Jam" there is no paper jamming the system. I cannot make this message go away, and so i cnnot use any other function of the printer. How might I clear...
Hi travlynn2,
  1. The ADF
    unit is the grey paper tray located on the top of the scanner unit.
    Check the following points if it does not feed paper, or you receive an "ADF jam" error message:
  2. Check the position of the ADF document guide:
    1. Lift up the ADF unit. Locate the document guide on the underside, as shown here:
    2. The document guide should be tucked in behind the grey plastic casing, but a paper jam can push it out of position. Figure 8 below shows the correct (1) and incorrect (2) positions:
    3. If your document guide looks like example (2)
      on the right, lift it out on the right-hand side. Tuck it in behind the
      grey section, so that it matches the example on the left (1).
    1. Close the scanner unit.
    2. If the printer is displaying "ADF Jam, press start to continue", press the B/W Start button to clear the error:
    3. Test the printer by scanning or faxing via the ADF unit.
  3. Check the ADF edge guides:
    1. The adjustable paper tray edge guides must be set to the correct paper size for the paper you are loading. Otherwise, the paper may skew, misfeed and/or jam.
    2. Slide the edge guides to enclose the loaded
      paper (in the direction of the yellow arrows below), without causing it
      to bunch or crease. The paper should be aligned with the relevant paper size marker:
      Figure 9. The ADF edge guides.
  4. Check the ADF unit feed rollers:
    1. Open the cover of the ADF by pulling up the grey lip, as shown below:
    2. Check thoroughly for fragments of paper and foreign objects. Take care not to tear any jammed paper when you remove it.
    3. Use the green gear (circled in yellow below) to turn the paper feed rollers and feed through jammed paper:
    4. Paper dust or foreign material on the rollers may cause paper to misfeed. Clean these parts with a damp, well-wrung cloth:
      1. The upper paper pickup rollers (circled in red, above top left). You can turn these by hand.
      2. The lower paper pickup rollers. These will rotate as you turn the green gear (circled in yellow above). See the inset for a close-up of the lower rollers.
    5. When complete, close all the covers.
    6. If the printer is displaying "ADF Jam, press start to continue", press the B/W Start button to clear the error:
    7. Test the printer by scanning or faxing via the ADF unit.
  5. Check that the ADF unit sensors are not obstructed.
    1. Open the cover of the ADF unit.
    2. Look at Figure 12 below. Check the position of the black plastic parts (the actuators) circled in red.
    3. If the black plastic actuators do not stick out from the ADF cover, they may have been pushed out of position by a paper misfeed and be obscuring the ADF sensors. Tap the back of the ADF unit firmly to release the actuators.
    4. When complete, close all the covers. Check and test the printer as explained in Step 6.d.vi.
Hope this helps.
Thank you for using FixYa.
Sep 21, 2011 | Epson ACULASER CX11NF All-In-One Printer
I have lines in printed material
If a print result of faxing, copying or scanning has uneven print density, or when copies and scans you make have vertical black lines, cleaning the platen glass may solve the problem.
  1. Turn off the power and disconnect the power cord.
  2. Prepare two clean, soft, and lint-free cloths.
    Note:
    Do not use tissue paper or paper towels as they may damage the machine.
  3. Open the document cover.
  4. Wipe the platen glass (D), the inner side of the document cover (white area) (C), the glass of the ADF (A), and the inner side of the ADF (white area) (B) with a clean, soft, lint-free cloth moistened with water
    (A) ADF Glass
    (B) ADF White Reference Area
    (C) Document Cover White Reference Area
    (D) Platen Glass
    Note: If you have trouble wiping dirt, use diluted mild detergent (for dish washing).
    Caution:
    * Never use volatile liquids such as thinners, benzene, or alcohol; these can damage the machine.
    * The d
    ocument cover white reference is easily damaged, so wipe it gently.
  5. Carefully wipe away moisture from each part with another soft, dry lint-free cloth. Do not leave any residue, especially on the platen glass.
  6. Close the document cover.
  7. Reconnect the power cord and power the machine back on.
Oct 26, 2010 | Canon MP830 All-In-One Printer
After switch on the toshiba e-studio coming uo
please do the following..
  • Open the ADF cover.
  • If shipping tape is present on the blue document feed-guide assembly, remove the tape.
  • Using the blue handle, lift the ADF rollers.
  • Remove the document.
  • Lower the ADF rollers.
  • Press the two tabs on the document feed-guide assembly to secure the assembly into the proper position.
  • Close the ADF cover.
  • Fax, scan, or copy again.
  • Jan 20, 2010 | Toshiba e-Studio 232 Black and White...
    I have a problem with my MP830 it is not scanning.
    - Confirm the connection
    - between the ADF motor and the ADF PWB, and
    - between the ADF PWB and the logic board.
    - Replace the
    - document feed unit, or
    - logic board.
    Oct 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
    When trying to copy papers do not feed but if you scan they will
    HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
    • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
    2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
    3. Close the ADF cover plate.
    • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
    1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
    2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
    3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
    4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
    5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
    6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
    7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
    9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
    Have a good day
    Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
    How do I copy a doublesided invoice using canon mp830 please advice
    Start by pressing the Two-Sided button that is to the left of the center screen. 2 sided=2 sided print should be highlighted (if not, use the arrows around the OK button to get to the right choice. Press OK to set. Follow the instructions on the screen. Use the document feed on top. (ADF). If this isn't enough info... ask more.
    Mar 23, 2009 | Canon MP830 All-In-One Printer
    Canon PC980 ADF PROBLEM
    not really familiar with this model, however, you should be able to open the cover (slightly) where the paper feeds in and you will see some rubber rollers (likely top and bottom), try cleaning these with a rag dampened with some alcohol (preferably), or water, and turning gently (do not force). If you use water, dry them afterward
    Feb 13, 2009 | Canon PC-980 Color Copier
    ADF for MP530 does not work
    Welp, I pulled out my screwdriver and fiddled around just a bit and got documents to feed again (yay!). I do not believe this is a permanent fix, though, but it was enough to get my document scanned in without me having to feed each sheet manually.
    Step 1: Open the document feeder cover. Easy to do, you just stick your hand under it and lift up. It has a little pressure because of the latch but it is designed to give way when you lift hard enough. Once it's open, pull out the little black plastic piece that keeps the cover from swinging all the way open.
    Step 2: Unscrew the ADF motor/gear assembly cover. There's a single screw holding it in. Once you unscrew it, you'll need to pull up on the left side of the cover until it pops upward, then you need to push the cover towards the left until it is freed up from the rest of the cover. This one was a little tricky. Several times I thought I might break it (before I realized that I needed to push the cover towards the left) so try not to apply unreasonable force while you're doing this.
    Step 3: Close the document feeder cover, put your documents in the feeder and start your scan. Use your fingers to fiddle with the gears while the ADF motor is running and trying to feed documents. I'm not sure if I flicked the little gear upward or downward to get the documents to feed, but one of those ways got the documents to start feeding. Once it started feeding the first page, it seemed to work well for the rest of the pages without me having to fiddle with it anymore.
    I am guessing that there is some level that controls the location of the middle gear that needs to be oiled, but I didn't go any further to try and make that happen. Hence this is probably just a temporary fix for now.
    Putting it back together is pretty straightforward. Just do the reverse of what you did to get it open.
    Hope this helps someone!
    Jan 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
    FAX will not print.
    I have the same problem. Found this solution on the Brother site:
    If the faxes you receive and the copies you make print half blank pages
    please follow the steps listed below:
    1. Unplug the power cord
    2. Lift the top cover up.
    3. Next, lift the two purple release levers located on each side of the
    metal plate. The print head will pop up.
    4. Remove the ribbon cartridge from the unit.
    5. Lift the plastic paper cover (located behind the black rubber
    roller).
    6. Carefully remove any paper that is jammed by pulling in an upward
    direction.
    7. Push the paper cover down (located behind the black rubber roller).
    8. Place the ribbon cartridge back in the unit with the ribbed triangle
    on the plastic casing furthest away from you. Make sure the cartridge
    gears rest in the white gear holders.
    9. Gently push down the print head until it clicks into place.
    10. Close the top cover securely.
    11. Plug the power cord back in.
    Test by making a copy.
    1. Place a document (with text on both sides) in the ADF (automatic
    document feeder).
    2. Adjust the paper guides on the sides of the ADF to fit the width of
    the document.
    3. Press the COPY key.
    If the problem continues and your machine is within warranty, you can
    locate a Brother Authorized Service Center (ASC) in your area using one
    of the following:
    Click on:
    http://www.brother-usa.com/support/ and then click on the "Service
    Center Locator" option located on the left side of the page or for
    automated assistance by telephone, dial 1-800-284-4357 access our fax
    back system. This system can provide you a printed list via facsimile or
    verbal listings of a Brother ASC in your area. You may also contact Brother Customer Service at 1-800-284-4329 Monday through
    Friday, 9:00am- 7:00pm EST, excluding holidays. If you are out of
    warranty, you need to contact a Brother Authorized Service Center using
    the information listed above.
    Nov 16, 2007 | Brother IntelliFAX 1250M Fax
    62 people viewed this question
    old marine
    old marine
