Need to repalce the hard drive in an HP A1637C desktop and cannot remove the old hard drive.
  • customers819 May 11, 2010
    Not sure what you mean that you can't remove the old hard drive. I
    Problem Solver:
  • 8 Answers
Well u may remove it with the data ribbon..... which is connected to the other end on the motherboard......
such ribbons r easily availible in the computer stores........ get one and put it the way it was.........
Posted on Sep 27, 2009
Remove hard drive from HP Pavilions a6230n
No you have to remove the media drive cage from the front the panel comes off. then pull on green tab to remove it completely then you'll be able to reach the harddrive
Dec 06, 2012 | HP PAVILION A6230N DESKTOP PC
Need to download data from old computer but need new power unit(bestec) computer 2003-5 vintage. have new windows7 how do I donwnload data from old computer
If your old computer is not working then remove the hard drive from the computer and connect it to an USB hard drive adapter. Plug this USB adapter into the USB port of your new computer and it will see the USB adapter with your old hard drive as an external storage device. You can then open the various folders and files and copy them to your new computer.
Apr 05, 2012 | HP Pavilion Media Center M1070n...
The computer would not boot with a 2nd IDE drive installed
Try setting the jumper on the IDE hard drive to SL (ie slave).
Mar 17, 2012 | HP (SHP) HP DC7100 CMT SRP US HP...
Have replaced computer. Motherboard dead on old one. Is there any practical way I can get pictures and such from old computer. It will not power up. Thanks
You should be able to tak the hard drive out of the old one and put it in the new one as a secondary drive. There is a good chance, though, that the drive won't fit. If it doesn't, you'll need something like this.
Mar 02, 2011 | HP Pavilion a450n PC Desktop
Why is it when i go to start my computer it doesnt wanna load windows, it says disk boot failure, insert system disk and press enter. My computer was working fine right before. can someone please tell me...
Hi, the computer is not detecting the hard drive or the hard drive is corrupt. At startup you are likely to hear a knocking sound if the hard drive is physically damaged. You can go to bios setup at startup ( could be F1 or Esc). Once there it should indicate if there is a harddrive or not. If it indicates none there the harddrive might have crashed and will need repalcing. I hope this helps.
Aug 12, 2010 | HP Pavilion a706n PC Desktop
How do you replace a hard drive in a HP Pavilion -Model 8674D?
The instructions for removing the back cover or front cover might be in the Owner's manual. You need to remove the access panel and once you remove it just uncrew the old hard drive and install the new one and recoonect the wires.
May 25, 2010 | HP Pavilion (PN153AAR) PC Desktop
Install hard drive in hp a1310n
You need to do a number of things:
1) You need to carefully remove the door and the whole front face of the desktop (the front face opens like a door it swings open from left to right)
2) Once you have the front pannel open take a philips screwdriver and unscrew the memory card readers that is show in front of the deskop (there is one screw holding this card reader in place probably on the upper right hand corner.
3) Carefully remove the card reader by jiggiling it lightly till the unit comes off.
4) After you remove the card reader, you will immediatly see the hard drive directly behind the reader that you just removed.
5) Now look inside the desktop (because you removed the right hand side door: the big one that alows you to see inside the pc) and remove all cables from this hard drive before you read #6 below
6) Inside the desktop, Locate the hard drive, put your hand on the back of it and lift on the green plastic part along side the hard drive where you can see the harddrive screw which is on a metal track stopped by a green plastic stopper.
7) Lift the green plastic stopper and push the back of the hard drive to the front of the desktop.
8) Unscrew all screws from old hard drive and rescrew them on the new one in the exact same spots at the old hard drive.
9)Once you finish screwing on the screws, slide the new hard drive back from where the old one was
10) reconnect all data cables and power supply cable.
11) follow steps 7 thru 1 to put unit back together again. Go thru steps 7 thru one backwards
I hope this helps
Mar 18, 2010 | HP Pavilion a1310n PC Desktop
I need to replace my keyboard on HP Pavilion 9700, Notebook
well in order to get the repalcement call hp tech support i.e. 8004746836 and pay $298+taxes to get it replaced...if the NB is oow
Oct 07, 2009 | HP Pavilion dv9700t Notebook PC
New pocket media drive is stuck in computer
Just a dumb answer try removing the screws, if it doesn't work use your strength and rip it out. If you can't, then open the computer and take out the bay, then rip it out. If you still can't, step aside and let a mad do it for you.
Jun 05, 2009 | HP Computers & Internet
HP Media Centre PC 7250 can I add a hard drive?
Here's a step by step guide for that HP 7250 model on HP's website about how to replace, or remove/add the Primary and Secondary Hard Drives (which pictures that help).
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00639696&lc=en&dlc=en&cc=us&product=1118243&rule=29389&lang=en
If your computer did not come with a second hard drive, you can install a second hard drive that you attach to the bottom of the inside of the computer tower.
Mar 29, 2009 | HP Media Center m7250n (ED842AA) PC...
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
