Question about Kenwood KAC-9104D Car Audio Amplifier
On my amp the blue light dims and makes my sub pop insted of pounding
    Scholar:
  • 66 Answers
You're amp is not getting the maximium power then it once was. You must tighten the ground or reground it scrapining the metal. There is a lot resistance somewhere in your system. recheck your power connections making sure they are tight and not corroded already especially near the battery. take out the old fuse and replace it with a new one and see if the amp improves its power.
Sometimes the fuse internally breaks loose and has a bad connection without looking bad. You can measure this with a multimeter. See what the voltage on the side of the fuse holder away from the battery is. Is it 12 volts or does the voltage drop drastically.
Posted on Apr 09, 2010
What is the best amp for one 15" alpine type r?
sub spec 250watts per coil you should be just fine I have 2 typr 15s on orion hcca 2500 1 and it kicks a$$ thats 1000 watts over the rated limits of the subs only shut the amp down once these subs can take a lot more power than they say just use your common sence with the volume and gain levels
Jan 31, 2012 | Alpine Type-R SWR-1242D Car Subwoofer
The power button shows dim blue light instead of regular deep blue. the light panel shows yellow light insted of all bule lights
this could be a simple ram prob, try removing the ram via the back door underneath the lap top the try rebooting, or find the cmos jumper and reset the bios/ cmoss settings, if the ram is not the prob it may be the graphics card has died, hope this helps
Feb 13, 2011 | Toshiba Satellite A100-S8111TD Notebook
MTX Thunder series 7402 Amp cutting out at Hard pound.
Most likely the ohm load is too low, if you have the subs wired in parallel rewire them in series and see if that resolves the problem. if not then you do not have enough battery power to support the draw that the amplifier pulls. if the vehicles voltage drops below 11.5 volts the amplifier will momentarily shut off, similar to how the lights in your house dim when the a/c cuts on due to the sudden power draw. hope this helps. p.s. if you cant afford another battery right away, lowering the crossover frequency to around 65hz will greatly reduce the amount of current necessary to keep the amp pumping. (in my opinion it sound better that way anyhow.)
Apr 28, 2010 | MTX Thunder 81000D Car Audio Amplifier
My 1990 toyota corolla tail lights and dash lights stopped working after i hooked up a stereo and sub and amp system...i checked the fuse and its good..i cant find any wiring problems..help? anybody?
which fuse did you check. verify the wiring to the radio than comes from the light switch to the radio. if all this worked before , then it has to be work that you have done. the only link from the light switch to the radio is for inst panel dimming. first disconnect that wire and ck fuse for tail lights. make sure there is power on both sides of the fuse, use a test light.
Sep 19, 2009 | 1990 Toyota Corolla
My subs sound distorted and dont pound right 2 12in cvr kickers and a kingwood 2 channel amp think its not wired right
Are you sure the polarity is correct on the sub's connectors? This is very important as reversing them will cause the sub to pound inward instead of out. Make sure the wires are thick enough and that the amp's + connector goes to the red(or +) connector on the sub and that the amp is grounded properly to a clean piece of metal on the car's body. This ground wire should also be as short as possible. Also make sure the fine-tuning for the bass level on the amp is adjusted correctly and that the sub's enclosure is the correct specification ie. Ported or sealed, right size, etc.
Mar 09, 2009 | Kicker CVR12 Car Subwoofer
Kenwood KAC-8401 light goes from blue to red when turned on
Either the amp is ad or the sub got shorted? You can check itby disconnecting the Sub and seeing if the amp comes on blue then. If yes, then the sub is shorted. If no, then the amp is shorted. Also chck the voltage AT THE AMP. Make sure that it is above 12 Volts.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Dec 29, 2008 | Kenwood KAC-9152D Car Audio Amplifier
My Jbl mono amp cuts out
It's likely that the amp has blown output transistors. To eliminate other possible problems, read through the following page:
Amp Going into Protection Mode
Let me know if you have any other questions.
Sep 14, 2008 | JBL GTO75.4 Car Audio Amplifier
Amp makes subs pop
It sounds like your amp chip has gone bad, here is some thing you can try turn on your unit then start tapping on top of with your finger not hard see if the any of the pops matches your finger taps some times when the chip starts to go out it well act like that.
Nov 04, 2006 | Orion 2500D Car Audio Amplifier
Kenwood KAC-9104D Car Audio Amplifier Logo
145 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
