Question about Polaris 380 In Ground Pool Cleaner
Why does my polaris 280 stay tipped up on its nose with its back wheels suspended??
    President:
  • 1,015 Answers
It sounds like it might be getting too much water flow causing it to lift or the wheel rpm is too high. check to see if the blue restrictor disk is installed and if it is you may want to install the red disk to decrese the water pressure more. And check the wheel RPM. It should not be more than 32 RPM. If it is more then you will need to adjust the pressure relief valve by unscrewing it to release pressure and bring the wheel speed down to 32 RPM.
Posted on Sep 26, 2009
Polaris 280 wheels running but not picking up leaves
check side filter at connection if clean check inside Polaris to see if hoses came off
Apr 16, 2013 | Polaris 280 In - Ground Pool Cleaner with...
Polaris 360 belts in tact and fall off
see if inside unit debris obstructing paddle wheel or belts loose
Jul 09, 2012 | Polaris Pool & Spa
Polaris 280 wheel tilted
see if inside wheel mount broken or loose
Jun 10, 2012 | Polaris 280 In - Ground Pool Cleaner with...
My wheels are not turning on polaris 280
Make sure that your thrust jets are properly positioned. You will also want to check for any obstructions in the wheels or axles that would restrict movement. Often with these automatic pool cleaners, one of these two problems is causing restricted movement in the wheels.
Jul 02, 2010 | Polaris 280 In - Ground Pool Cleaner with...
My wheels are not turning on my Polaris 280, what can I do?
When my polaris wheels stopped spinning it was the water jet which spins the turbine was clogged. The in-line filter had failed and some small debris had passed through to clog the jet. Easy fix to take off the top cover then take off the turbine cover and examine /clear the hose (clamped on by zip ties) and the plastic jet.
Jul 27, 2009 | Polaris 280 In - Ground Pool Cleaner with...
Pool polaris 280
If the cleaner is going too fast then it is likely that there is too much water flow at the drive turbine. Is there a pressure relief valve in the water supply line (at the edge of the pool)? If so then change the tension on the spring to allow less water to get to the cleaner's drive turbine.
The speed of the Polaris is probably the cause of the front wheel lifting as well, however if (after adjusting the water pressure) the front wheel still won't stay on the pool bottom, then perhaps adjust the little jet at the back of the casing. Mine points a little "down" towards the pool floor and this tends to raise the bac k wheel (or alternatively keeps the front wheel in contact with the pool bottom or wall).
By the way, if you want to see how the cleaner works, then search for eHow and lookm at the repair/overhaul of the Polaris 180............. the mechanism is similar.
Good luck.
Feb 12, 2009 | Polaris 280 In - Ground Pool Cleaner with...
Polaris 280 - tank track keeps coming off
I battled with the track falling off for over a season. The pool guys said they fixed it. Tried the previous solution to adjust middle wheel but no luck. My solution was to remove the left wheel and the tank (to get to the screws). The wheel mount allows for minor adjustment but it is also reversible. Turn the mount around and this will extend the wheel base much more. Mine ran for several hours after doing this and so far the track stays on.
Dec 28, 2008 | Polaris 280 In - Ground Pool Cleaner with...
Polaris 380 In Ground Pool Cleaner Logo
475 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
