I have an old copier - single sheet at a time,
I have an old B and W copier - single sheet at a time, nothing fancy. I have gotten an error code "H". Nothing appears to be jammed, it has paper, and the copies have beendark, so toner is not low. What does "H" mean?
Thanks
  • 1,294 Answers
You don`t specify the copier models.If have one old Sharp or Canon the H codes refer to tha fuser unit:
H 2 : Thermistor open detection,thermistor open or the fusing unit is not installed correctly when the door is closed.
H 3 :Triac in the shortcircuit,heat roller abnormally high temperature.
H 4 :Heater lamp open,defective installation of thermistor,thermostat open,and causes the set temperature is not reached after turn ON the power.
Posted on Oct 04, 2009
What is code error e03
Printers & Copiers
Code error E03
Nov 14, 2014 | Office Equipment & Supplies
Cyan TCR Sensor adjustment failure
Replace the image unit code has nothing to do with the chip!!!
Feb 04, 2014 | Konica Minolta Bizhub c203 Copier
Load error
When trying to print on continuous stationery, the display may show "Online Single Load". This will occur if the printer is expecting to print on single sheet paper even though you may want it to print on continuous paper. To clear the error follow this procedure. • Take the printer off-line by pressing the Online key • Press the Setup key • Press the key under "Paperway" in the display • Select Tractor 1 (or Tractor 2 if fitted/required) • Press the key under "Set" • If the job still refuses to print try loading the printer with a single sheet of paper to clear the command. To do this remove the tractor feed paper and close the cover on top of the tractors but not the outside cover. You will see a guide into which put a single sheet of paper and press the key under "Load" in the display. • The printer should commence printing. If it does not, then press and hold the key under "LF/FF" to eject the single sheet. Now follow the instructions above again to select the Tractor. The display should read "OnLine Tractor Load". Load the tractor fed paper into the Tractors and press the key under "Load". The printer should now be ready to print. Check your software settings for the correct paper path type. Ensure that the display does not show "Manual" otherwise you will have to clear this error in the same manner as you have for Single sheet
Dec 06, 2011 | Tally Dot Matrix T2265C Printer
Service error code 6A00 Have disconnected power to and reconected but still cannot print a document.
This error refers to the sheet feeder unit. there is nothing you can do to correct it but fit another sheet feeder. To be honest you would be far better to replace the machine as only a trained Canon engineer would know how to do this. there is a critical alignment proceedure to follow and if not done correctly first time it will strip the gears teeth off the new sheet feeder. i am one such engineer and i have wrecked a couple of sheet feeders myself. ughhhh
May 28, 2011 | Canon Pixma MP500 All-In-One InkJet...
I've just bought a new kodak printer ESP3250 last week, and installed everything and got it set up fine. It was printing fine after I installed it but suddenly stopped after I had printed a few sheets. The...
Sounds like there is a sheet of paper jammed in it. Try taking off the roller access panel in the back (not the access panel by the cartridges). Make sure to only use clean sheets with proper humidity level to avoid jams. Also fan the sheets before feeding to disperse any static.
Mar 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Error code 3528 keeps coming up,telling me to remove back cover and remove paper jam then replace back cover.there is no paper jam,checked printer heads no paper anywhere?
I have this printed and if you read (carefully) through the manual it tells you it doesn't like single sheets of paper. If ever my paper feeder tray runs below say 3 sheets then this error will crop up so keep it topped up with paper. The same goes for photo paper too.
Sep 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer says out of paper but some still there
Dear Sir,
What is the weight of the paper? Sometimes if you use really thin sheets and only a single sheet at a time the paper sensor thinks it's out of paper early.
Did you remove the paper and replace it? If the paper sensor doesn't see the paper perfectly, it could error out like you are reporting.
Thanks For YOur Time,
Apr 13, 2010 | Office Equipment & Supplies
Wrong size paper error Dell 1320C
if you are printing letter size then setting the tray to a4 will produce an error... if you really need to print a4 then go into the driver and set it to print a4 and in print options set it for a4...and set the tray for a4
Dec 20, 2009 | Dell 1320c Laser Printer
k24674
