Question about KitchenAid KHMS155LSS 1000 Watts Microwave Oven
The microwave turns on radomly
The microwave display starts reading a number and then the word inches (I think this is a pizza setting) then starts on its on and keeps running. After unplugging for a while it works for a few days and then does this again.
  • 725 Answers
Call kitchenaid
you will need a touch pad and control... touchpad is shoring out causing it to turn on...
hope it helps
Posted on Sep 26, 2009
How to bake pizza in rival micro wave .??how to set it?
Unless the pizza was specifically packaged for microwave use, pizza cooking in a microwave is usually a bad idea. They don't turn out well. Although microwaves are referred to as "ovens", they really don't bake things, they boil them by heating the moisture in the product. Thus, pizza crust will not rise and get crispy unless the pizza was pre-made to be microwave reheated. Those pizzas will give instructions on how to microwave them.
Nov 06, 2015 | Rival Microwave Ovens
Panasonic microwave
I would check the cooking instructions on the side of the pizzas packaging. If microwave cooking is not listed I would not recommend cooking it in a microwave as this could make the food unsafe to eat.
But if you're short of an oven I have found a guide on barbecuing a pizza:
How to Cook Pizza on Barbecue
Mar 20, 2014 | Avanti Microwave Ovens
Convection oven does not get warmer than 200 degrees even when set on BROIL
The service manual is here: http://www.microwavecontrol.com/dcm24_r930ak_aw_sm.pdf
You may have a failed thermistor.
Contact me directly if you need more help.
- William E. Miller, AS-EET
pupista@gmail.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 01, 2017 | Sharp R-930AK Convection/Microwave Oven
Kenmore pizza microwave beeps constanly
This is not a solution, it is a clarification request, but it looks like FixYa took away that helpful option, too.
I would suggest you post a whole new help request and be sure to tell us:
1. The FULL model number from the tag in or on the microwave. A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
2. Let us know when it beeps. Is it only after cooking? While it's setting idle?
3. Next, let us know if the display has anything in it besides the normal clock time.
A good first step might be a hard reset, accomplished by unplugging the oven for a minute or two, plugging it back in, then resetting the clock.
Dec 11, 2012 | Kenmore 20" 1.1 cu. ft. Pizza Maker and...
WE PURCHASED A MAGIC CHEF MICROWAVE-PIZZA OVEN FROM OUR LOCAL MENARDS STORE IN JUNE OF 2010. THE MODEL NUMBER IS MCP13E1ST AND THE SERIAL NUMBER IS DJ10100288. OUR OROBLEM IS THE UNDER SIDE PLASTIC ON THE...
be you cooked something in the micro wave and pizza over at the same time - my wife did the same thing - on she had a towel on top and other things on top to not allow heat to release. hopes this helps
Feb 19, 2011 | Magic Chef Microwave Ovens
If you use the microwave and forget to clear the time remaining. Or, if you just leave the food inside, the microwave will start itself in the Pizza mode. I guess it thinks the pizza needs to be reheated??...
You should have a 'clear' button on your oven.
Try to not open the door with the oven running. This causes arcing at the door safety interlock switches and they will fail.
You will know they failed when everything works but there is no "heat". No heat because the oven will think the door is open ... even though you know the door is closed.
Enjoy your new oven ... they are great. I dont know how the Mrs and I would eat if not for the mocrowave!!!
Oct 20, 2009 | Jenn-Air JMC8130DDS Microwave Oven
3 yr.old Kitchen Aid microwave KMS155LSS4 - Unsafe has a mind of
This is an over the range microwave if I guess correctly. ( I couldn't find the model at KitcheAid)
The computer board is no longer sealed and has gotten wet from steam coming off of food being cooked below it. You need the computer control board replaced. My parent's GE over the range microwave had similar problems a couple times.
Sep 23, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Sienens microwave HFT879 fault
Exactly the same problem over here, but after our house was hit by lightning, so not really surprised about the cause of the problem. If you look closely, you can still see the displays on a very low light level. I can still choose a microwave program, turn the time etc, and see the time changing, but start won't just just work.
m.de.man att zonnet.nl
Jan 11, 2009 | Siemens HF87950GB Convection Microwave...
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
96 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
